Old 06-16-2003, 04:38 PM   #1
Send a message via AIM to tdragon
Default glitching
hey im getting some glitching between my esc and my reciver can ne one tell me how to fix this they r as far apart as they can b they r in a xxx-s reciver is a novac nerzx and the esc is a intellispeed 8t racing esc
tdragon is offline   Reply With Quote
Old 06-16-2003, 05:09 PM   #2
Do you have the small capacitors on your motor. Some of the newer moters have them built-in. Also make sure your antenna wire not near the battery wires or the ESC. You didn't cut the antenna wire, right?
Headbanger is offline   Reply With Quote
Old 06-16-2003, 05:26 PM   #3
i just installed a new antenna wire and its a bit longer the the other about 1and a 1/2 in longer
Old 06-16-2003, 05:54 PM   #4
The antenna wire needs to be the same gauge wire and length as the old one. Try trimming it down to the same length.
Old 06-16-2003, 06:52 PM   #5
the antenna is the right size and gauge and it still glitches.
Old 06-16-2003, 07:08 PM   #6
Keep any control wires (servo wires, antenna, ect.) away from power wires (battary wires, motor wires, ect.).
If you have a graphite chassis make sure that the antenna doesn't touch the chassis.
Don't mount the reciever on the servo.
Mount the reciever on two or three layers of servo tape.
Make sure that there are capacitors on your motor or the ones on the motor arn't damaged.
Check to make sure you don't have a smoked motor, running a car with a smoked motor can cause it to glitch.
Make sure there is not metal vibrating on metal, but since its an electric car I don't think there would be any, especially in a xxx-s.
racerdx6 is offline   Reply With Quote
Old 06-16-2003, 07:33 PM   #7
Default Re: glitching
Try mounting you reciver next to you servo, 3 pieces of tape and make sure your reciver is closer to your servo away from your motor, also you could use a piece of fuel tubing to run the ant wire through to keep it off the chassie... Works for me.. I ruan the same car....LOSI good luck racing...
Mark Barden .
mb racer is offline   Reply With Quote
Old 06-16-2003, 10:54 PM   #8
ijnek's Avatar
Send a message via ICQ to ijnek
check ur wires for any cuts.wat type of chassis r u using on the xxxs?...the graphite 1 will conduct electricity...
ijnek is offline   Reply With Quote
Old 06-17-2003, 04:19 AM   #9
i have the stock chassi therre r no breaks in the wires
Old 06-17-2003, 11:00 AM   #10
Did you try all the things I suggested? Here are some more to try:
Make sure your transmitter has fully charged battaries or replace the current alkalines with new alkalines if they're low.
Try a new set of crystals.
Try all the things I said before.
Make sure the wires tha connect to your motor are not frayed at the end.
Old 06-17-2003, 11:03 AM   #11
Here are a couple more I just thought of:
Mabey your module in your transmitter is damaged.
Your reciever could be damaged.
There could be a poor connection between the little metal pins in your reciever and the plugs from the servo and esc. Have someone at your local hobby shop or track rewire the pins in your reciever.
glitching help! aus jd 2703 Electric On-Road 6 05-24-2007 05:43 PM
GTB Glitching Vegaspilot Electric Off-Road 4 06-11-2006 10:28 AM
SD glitching Techart27 Electric On-Road 26 03-22-2004 10:31 PM
Glitching Help CraigHandley Australian Racing 6 02-29-2004 11:56 PM
Glitching on my 3PK FUK_WRX Electric On-Road 10 08-15-2003 09:50 AM
