Old 10-13-2003, 09:42 AM   #1156
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
Default rclab
Originally posted by seaball
kreator - i'd go witht the new car if it's not too much hassle. the new car will allow more adjustments, and will be better supported by those running the lab cars. 90+% of the 6.0 parts still fit, but how they fit is what is changed on the 7.7. if you intend to race competitively, you'll thank yourself for the initial work. the price is comparable, but i can't imagine not wanting to spend the additional $ to allow you change roll center and antidive, and perhaps inboard toe in the future.
ha haa!!!! ill keep it instead .. audiaudi count me in for the next shipment.!!
as for Rclab My congrats on your A main trophys. Keep up the good work .!!!
TA04ss / TA04TRF / TB EvoIII/ TB02 /DF02 / M03L / TRF414m2 / TRF415 / TRF415MS / TRF415MSX / MRE
KREATOR1 is offline   Reply With Quote
Old 10-13-2003, 09:18 PM   #1157
audiaudi's Avatar
Send a message via ICQ to audiaudi Send a message via MSN to audiaudi
Originally posted by SteveM
If you need a test driver, just let me know. I'll run a Mini Xpress for you.
Hey man, they are all well tested
You can just buy one, assemble it, and shoot those Yokomos and X-rays out...
https://www.facebook.com/aldusdesign
Trying very hard to jump back into RC with CRC Xti-wc.
audiaudi is offline   Reply With Quote
Old 10-15-2003, 12:12 PM   #1158
audiaudi's Avatar
News for the lab, the new light weight centre shaft will soon be avalible. Please look forward to it and it will improve your car's speed quite a lot.
Old 10-15-2003, 12:16 PM   #1159
audiaudi's Avatar
Default Re: rclab
Sure, just let me know....
The new 7even GT3 run in the A-main in HK quite frequently, and have some wins as well, when competiting with the SDs and TBIIIs, and those races have some national class racers join... GT3 is great...
Old 10-15-2003, 07:56 PM   #1160
KREATOR1's Avatar
Default shaft
light weight centre shaft?!!!!!! Rclab now no longger runs on belt?
or is it the CVDS/.
audiaudi any pictures
Old 10-15-2003, 08:02 PM   #1161
audiaudi's Avatar
Nope..
That's the shaft holding the pulleys on the centre motor mount, so it is the center shaft.. that's how we call it in our place.. but we are not english speaker..
Old 10-15-2003, 08:24 PM   #1162
KREATOR1's Avatar
Default Re: Re: rclab
what painted body shell u used on your rclab?come on show us your nice body.hehe!!!!
Some people says that alfa is better than the stratus.
Old 10-15-2003, 08:52 PM   #1163
audiaudi's Avatar
Some of my own bodies are on my site.. I use the same scheme on every car of mine....
The Alfa have better traction then the Stratus, most cars will become pushing in the corner when have the inner spill-platesinstalled. But if without those spill-plates the car will get more steer even then the Stratus. But the most important, the rear spoiler will be disqualify by racings under rule of JMRCA or IFMAR 1/10 EP touring class... too wide...
I like the Stratus, the car seems more stable then the Alfa... and I have already used to the Stratus, I don't wanna setup the car again...
Old 10-21-2003, 11:19 PM   #1164
ta03 tuner's Avatar
Trader Rating: 30 (100%+)
I just received my 7even NR kit but man...there is something seriously wrong with it...I think the rear holes for the rear arm bulkhead were drilled incorrectly or something...There is way too much toe in on the right rear hub and wheel. So much that it touches my stick pack plate....Has anyone had this problem? This sucks because I was planning on racing this weekend...I rebuilt it with new arms, bulkhead, and rear hub and same result everytime...Are the instructions wrong or something? Hmm...Here's a pic of what I mean..
ta03 tuner is offline   Reply With Quote
Old 10-21-2003, 11:34 PM   #1165
Herminator's Avatar
Send a message via ICQ to Herminator
Do you have a setup station to measure the toe in?
I take it the stick pack holders are off another car, with teh Lab the cells are pretty far back, I wouldn't like to run with stick packs even if there is clearance, it still looks very close on the left. Those holders could easily deform while racing and rub on the tyres. If you must run stick packs your best bet may be to use strapping tape, that way you can get the cells further forward and use the slots in the chassis which are there for using tape. If there isn't a rule requiring stick packs, saddle's are a much much better idea, the chassis was designed for them and it will lower the cg a lot.
Herminator is offline   Reply With Quote
Old 10-21-2003, 11:46 PM   #1166
ta03 tuner's Avatar
The 7even NR is especially made to accept stick packs...check it out on the HK website...I went through and did all measurements of the holes and they seem pretty accurate...what is going on here? I also forgot to mention that the bulkheads too are plastic unlike the aluminum ones on the Pro kit...maybe there distorted but I swapped all four and still no luck...I'm stumped...
Old 10-21-2003, 11:55 PM   #1167
Herminator's Avatar
Hmm stick packs holders must be a HK thing, not seen them on UK kits. If you've swapped out all the plastic parts then it may be the chassis isn't drilled correctly, but thats not very likely. You need to make some precise measurements I think to get a good idea of where the problem might be.
Old 10-22-2003, 12:05 AM   #1168
ta03 tuner's Avatar
measurements all check out....its gotta be the plastic bulkheads...also, does it matter which hub carriers and what direction they are placed? Mine have two stamped 1.5R and two 1.5L...I'm assuming its right and left but I tried every possible combination and the right rear still toes in...dang it! Let me know how you are setting yours up...
Old 10-22-2003, 12:11 AM   #1169
Herminator's Avatar
Yes the hubs are right and left handed. If you want to check the bulkheads try and find something like a long wooden scewer and put one in each hole, this will exagerate the angle of the holes so you can see if one is badly drilled. The rear should have some rear toe in, it helps to keep the rear end planted on the track, anything between 1 and 3.5 degrees is used on most cars. Don't have my Lab any more so don't know what stock settings are.
Old 10-22-2003, 12:20 AM   #1170
ta03 tuner's Avatar
Hmmm...the chassis checks out okay....I fear the bulkheads may be the culprit...here's a pic of bulkheads and chassis...I guess I'll wait and get the aluminum ones or who knows...a new car...I worked over 8 hours on this car and had to tear the whole thing apart...Sketchy craftsmanship...
RCLab 7even 6.0 Pro II SteveM R/C Items: For Sale/Trade 0 10-14-2003 06:21 AM
RCLab 7even 6.0 Macky R/C Items: For Sale/Trade 2 03-04-2003 01:37 PM
f/s RCLab 7Even Evo II seaball R/C Items: For Sale/Trade 3 12-08-2002 07:42 PM
For Sale: RCLab 7Even Pro 6.0 over gear R/C Items: For Sale/Trade 0 01-18-2002 04:23 PM
