Old 01-31-2003, 06:04 PM   #931
chrisman's Avatar
Send a message via MSN to chrisman Send a message via Yahoo to chrisman
Seaball,
I used to use the big kimborough servo saver until I found out I'm actually grinding it off at the bottom...from cornering to hard.SO I used the stk ones instead but it binds up after a few usage..The ones I using now is from Tamiya..the option heavy duty servo saver...smooth and small.I'll stick to this for a long time.Check it out...
chrisman is offline   Reply With Quote
Old 01-31-2003, 06:27 PM   #932
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
no.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 01-31-2003, 06:44 PM   #933
Herminator's Avatar
Send a message via ICQ to Herminator
Well I've never been to the GP before, any event in Scotland isn't that big really, sounds like you get more people at some of your clubs It's only about an hours journey for me, although it's been snowing badly the last couple of days in the UK, some people were stuck in snow drifts on a motorway overnight glad I wasn't stuck in my little car, I would of forzen to death.
Looks like I've found a KO Vantage at a reasonable second hand price, still 160 but thats 100 less than new.
Herminator is offline   Reply With Quote
Old 02-01-2003, 02:28 AM   #934
Painy's Avatar
haha..yeah G"C" sort of made the race's go his way..with positions and things..
Also he moved me into a really bad heat..pritty much all new drivers.. So i found it hard to get a clean run.." I DIDNT" but i just scraped into the A...
Now i had some clean drivers..time to get it on..But being at the back of the pack i found it difficult to get the the lead...
1st final got to 3rd. with a mad battle but tangeld and finished 4th..
2nd final..drove like a tool.. and ended up 5th..then in the
3rd final.." had a big talk about race ethics with my setup helper BOB..and then i cranked it..all the way to first ..my car was hooked..and had Speed to boot..thanks to the RACE PREP...Pulled into 1st and left the field ..buy half a lap almost..and yeah Peter was HAPPY..
But then in the Points..G "accidently forgot to give me my 1st place ,,and i didnt get my top 3 finish,,but it will be fixed up for the racing mag...if i have my way.
ok my setup is.
Painy is offline   Reply With Quote
Old 02-01-2003, 02:52 AM   #935
Painy's Avatar
Default SETUP FOR SUMMER NATS..in Aus.
Car. 7 RC LAB.
Tyres. "foams" SHORE 40f-40r
Weather: SUNNY
Surface: Smooth
traction: Med
Track: Asphait
Body: Trinity Stratus
Motor : Race Prep 27T
Brush: H cut race Preps
Spring: Green Race Preps.
Spur/Pinion. 95/34
Radio: Futaba 3pk
Servo: Futaba s9402
ESC: LRP Quantum Comp
Battery: SMC 3000HV's
"FRONT SHOCK SETUP"
Oil: 20wt
Spring: Black Venom
Shocks..Standard setup
Shock Mounting: B-lower 1-higher..graphite shock tower.
Camber Link Position.. #2 Graphite Shock Tower
"REAR SHOCK SETUP"
Oil: 20wt
Spring: White Venom
Shcks..Standard Setup
Shock Mounting: B-lower 2-Higher..plastic shock tower
Camber Link Position..#1 plastic Shock tower
"FRONT SUSPENSION"
Camber: 1deg
Caster: Standard
Kickup: Standard
Toe in: 1deg
Ride Hight: 4mm
Droop: 1.5 mm
Sway Bar: 1.4
Long Camber link...
Sterring Linkage: #1 hole
"REAR SUSPENSION"
Camber: 1deg
Kickup: Standard
Toe in: Standard
Ride Hight: 4mm
Droop: 2mm
Sway Bar: 1.6
Camber Link..Standard #1hole
"TYRE SETUP"
FOAMS..40f's and 40r's
"OTHERS"
FRONT ONE WAY..
47 grams of lead weight added...limit of 1500grams
20 grams on each battery strap
7 grams on the front top deck.
Old 02-02-2003, 04:30 PM   #936
Painy's Avatar
The doesnt seam to be much talk in here at the moment??
Is anyone else running the Express Light Weight Aluminuim CVD's in there car...i am running them in the rear of the car..as NOFX found aout that if you run them in the front..they can bend quite easy... I spose thats why they recomend them a REAR ONLY PART..
Also iam using the HARD titanium Screws,,,
Have you gouys found any other parts that are inter changeable in the car that could boost performance?
Old 02-02-2003, 04:47 PM   #937
chrisman's Avatar
Painy,
Yes I 'm using the alloy rear diffs right now.If you choose to run them in the frt,you have to use the blades.It will help the frt from binding,wear and bending the out drives.The alloy ones ae very durable for its weight.Xpress do have th eplastic ones...which I don't recommend as they wears fast and breaks..no we donot want that when you are in the mains..
I'm using blue anodized alluminium screws on one of my 7 cars.The other one is with full stainless screws.I found out weight savings the most is the aloy ones,but compare stainless to titanium..not a difference.Stainless are cheaper to get..and when polished..it's like a mirror.
The outdoor set ups looks good for foam.We over here run rubber tires on outdoors.Foam is only used indoors for mod.Spec classes uses rubber tires to keep everyone the same.
Old 02-02-2003, 05:12 PM   #938
Painy's Avatar
Ok no probs...
Well iam going to a big meeting "INTERSATE" in the next week..it is on tarmac with controle tyres/...taleoff 27's
Could anyone give me a good base setup for this track..is very short and technical....with rolouts "for stock at 28mm"
The track is also Indoors and its a sealed surface,
Old 02-02-2003, 06:10 PM   #939
Hi Paniy,
this is my first post in here, how are you?
I did own a Rclab 7even before but now just sold because it getting really old. Are you talking about the Melbourne Hopper Crossing Indoor race on 15-16 Feb? If so, Try the total standard setup in there, the Rclab was "born" from a Indoor super tight track.
Here is the link of Rclab indoor carpet basic setup, you will love it
http://www.rclab.com/rclab/setting/s.../lobo10415.htm
Keep in contact, my e-mail is [email protected]
Express CVDs and diff are perfect fit on Rclab as well, but Express CVDs are weaker than the Rclab one, if running with 27T motor it should be fine, but for any Mod motors they are not durable enough.
Think about the Tamiya 42mm type CVDs (for 414M, EVO 2 & 3), they are much durable but we found a bit heavier than standard Rclab CVDs, very good choice for the front end if running in Mod class.
DanDan is offline   Reply With Quote
Old 02-03-2003, 01:06 AM   #940
Painy's Avatar
Zenkins..how's it going man..
Hey thanks for the info.. yeah it the hoppers crossing event iam going too..will you be there?
So the Tamiya ones work..thats great.
I have heard the traction is awsome? would you recomend any traction compound at all?> what about tyre warmers..are tyres heating up quickly?
Old 02-03-2003, 05:47 PM   #941
Hi Paniy,
actually, do I know you before?? hehehe..
So what day will you goto Hopper for practice, let's make a time so I mgiht be able to come and chat with you? are you living in Melbourne?
If running CS-27 tires, I don't think tire warmer is need but tire juice is good idea if the track become clean. Track was quite dusty but still being to gain the traction after some runs on there, and the track will be awesome during race days coz they will clean the track very well soon.
Remember, try the totally standard setup first!! NO PAIN!!
Old 02-03-2003, 09:52 PM   #942
Painy's Avatar
hey man..yeah will deffinately be there on the friday practice
We havent met befor but peter Stitt...was saying that you were driving an lab in VIc..and you liked it..so i figured it was you..
Yeah man i will try the standard setup..its a good setup and hopefully it will be dialed..
Any way iam a tall skinny guy with brown hair..cant miss me..
Old 02-04-2003, 12:14 AM   #943
Hi Painy,
You mean this Friday? or the week before our race day?
Also, have you check out there is new hop up options avaiable for Rclab?
- New 3 degree front hub carrier
- New 3 degree rear hub carrier with 3 new roll center adjustment
Ask Peter about it and he might be able to get these stuffs for you before indoor champ. I heard that the 3 degree front caster work really well.
Yar, bring your swaybar sets as well, I reckon will be good in Hopper
Old 02-04-2003, 01:02 AM   #944
chrisman's Avatar
DANDAN.....welcome.Nice of you to drop in. so what's shakin from down under..... got any pics of your car or race track?...some of you out there must have something to post here for us to share...
Old 02-04-2003, 04:30 AM   #945
Here is some what I can share with, is my old Rclab 7even.
This is the modify for Tamiya servo saver, just cut out the standard Rclab servo saver top bite and mount it on, easy to do and servo run smoother.
RCLab 7even 6.0 Pro II SteveM R/C Items: For Sale/Trade 0 10-14-2003 06:21 AM
RCLab 7even 6.0 Macky R/C Items: For Sale/Trade 2 03-04-2003 01:37 PM
f/s RCLab 7Even Evo II seaball R/C Items: For Sale/Trade 3 12-08-2002 07:42 PM
For Sale: RCLab 7Even Pro 6.0 over gear R/C Items: For Sale/Trade 0 01-18-2002 04:23 PM
