Old 07-14-2002, 05:08 PM   #661
sonneteer's Avatar
Chrisman.... how did you did you find the mid-steering mod perform against stock positions?
Also are those holes you drilled on the motor bridge? I have the same idea but instead thinking of drilling it from the flat sides and on from top to lose weight and add cooling....
BTW, you guys must run 2 cars... one for show only... cos no matter what I do I cant get mine that clean!!! LOL
sonneteer is offline   Reply With Quote
Old 07-14-2002, 09:33 PM   #662
Joe
Joe's Avatar
antoniop, you must race on a gigantic track! BTW, What are the HPI equivelant of Yok orange springs?
Joe is offline   Reply With Quote
Old 07-14-2002, 10:19 PM   #663
chrisman's Avatar
Send a message via MSN to chrisman Send a message via Yahoo to chrisman
Hey Antoniop,
Crisp clear pics dude....nice.
Sonneteer,with the mod on the mid steering I find it best for full time 4x4.Steering is precise and quick.This all depends on the track condition too.Overall it's a good mod.
Rear upper links extend it to the furthest hole and inner lwr shock tower hole.Traction at rear is un beliveable.
Again this is tested with full time 4x4.Tried with oneways today...it's corner speed is way faster with 17/37 stock geared at 122x43.No brakes....will be good for carpet racing.
As for the motor mounts,the way it's drilled so I can retain it's structure strength without damaging it from stress and impacts plus air comes from the frt to these holes.
Chrisman.
chrisman is offline   Reply With Quote
Old 07-14-2002, 10:40 PM   #664
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
chrisman,
with the split plate in back, did you find the car to push on power due to the crazy traction it provided? i would think to do this with the oneway only. what kind of rear traction? on and off power? just curous.
seaball is offline   Reply With Quote
Old 07-15-2002, 03:48 AM   #665
antoniop's Avatar
Hi Joe,
I found them very close to HPI Light Yellow Linear (302gf/mm) but the Yoks are very short. I'm going to change to the HPI coz I don't need the big spacer clips I'm using.
The track is realy gigantic. It's used by 1/8 cars and 1/10 200 competition cars. These last one sometimes do a shorter version of the track.
The straight must be close to 300ft.
New toy (almost as fun as a car...) here it is
antoniop is offline   Reply With Quote
Old 07-15-2002, 09:34 AM   #666
chrisman's Avatar
Hey Sea ball,
With the rear plate cut..I have experienced ON Power steering....it's alot of traction.....full time 4x4..but with the oneways in the frt it's easy to drive in corners....try it or cut/dremel it a little to see what u like.
Old 07-15-2002, 04:20 PM   #667
seaball's Avatar
what do the yok springs turn into as far as spring rates? i've got a separte thread for this, but i want to order some. from blue to red in terms of soft>>>hard. some of which are for the gt-4. are all of them the same length?
Old 07-15-2002, 05:23 PM   #668
Nuno's Avatar
Send a message via ICQ to Nuno
Default yokomo springs
António,
Yokomo orange springs are 282 Gf/mm, the closest matches are:
- HPI linear pink (272 Gf/mm)
- HPI progressive white (298 Gf/mm)
cya
Nuno
Nuno is offline   Reply With Quote
Old 07-15-2002, 05:56 PM   #669
sonneteer's Avatar
the TC3 blue ones are probably the closest you will find, but i am not sure if the diameter is OK or not as I think they are a little smaller in diameter....
I use the HPI yellow or pinks.... however I am now using TC3 threased shocks I a I dod not get on with the original LAB shocks.... and the TC3 threaded shocks are the best shocks I have used ever.... using the RCLAB plastic shock bits with the TC3 shock...
Old 07-15-2002, 06:47 PM   #670
Nuno's Avatar
hi,
tc3 blue springs are 304Gf/mm
Nuno
Old 07-15-2002, 06:47 PM   #671
antoniop's Avatar
Wow, I have very sensitive fingers
I was going to say that it must be close to the white Progressive (judging by my "two finger test") but they are 29 mm long and that's too long for the front shocks.
Considering that I already tried Pinks, I got a set of Yellow Linear from HPI (302g) and the results were the same as the Orange Yok. The added benefit is that they are longer than the Yok spring not needing huge spacer clips.
The result is the same in terms of handling (that's what I felt).
I was looking at a few setups from RC Lab UK and I can see that a lot of drivers are using the Yellow HPI springs but with the lighter oil (???) . I found the rebound to be unacceptable and that's why I went to a heavier oil.
I guess I will stick with the Yellow (#6850) 70 wt oil combination.
Old 07-16-2002, 12:11 AM   #672
chrisman's Avatar
More pics of my 7even.
Thats it for now...enjoy the pics.This car just ran outdoors with good results.It's very responsive.
Old 07-16-2002, 12:16 AM   #673
chrisman's Avatar
Here's what kind of springs on this car.It'a HPI's Pro Linear springs.Blue in the rear(264g) part # 6847 and frt red's (238g) Part #6843.They are 27mm in length.
Tires used was Sorex 32's all around...Cheers.
Chrisman
Old 07-16-2002, 09:47 PM   #674
rcspeedo's Avatar
Exclamation
Just to let you guys know that RCLAB UK has released a complete set of RCLAB SPRINGS!! WOHOOO, finally! , it's worth the wait!.
Chrisman - Going to the third leg of the Tri City?
TTYL.
rcspeedo is offline   Reply With Quote
Old 07-16-2002, 10:19 PM   #675
seaball's Avatar
mother of god. what will be the rates, and length? i must know soon, as i am about to get a bunch of yok springs. please.
RCLab 7even 6.0 Pro II SteveM R/C Items: For Sale/Trade 0 10-14-2003 06:21 AM
RCLab 7even 6.0 Macky R/C Items: For Sale/Trade 2 03-04-2003 01:37 PM
f/s RCLab 7Even Evo II seaball R/C Items: For Sale/Trade 3 12-08-2002 07:42 PM
For Sale: RCLab 7Even Pro 6.0 over gear R/C Items: For Sale/Trade 0 01-18-2002 04:23 PM
