Old 01-06-2002, 11:19 PM   #451
shockwave's Avatar
Send a message via ICQ to shockwave
I;da made the A if I didn;t DNF the last heat and my car was setup for the 1st 2
shockwave is offline   Reply With Quote
Old 01-08-2002, 11:11 PM   #452
chrisman's Avatar
Send a message via MSN to chrisman Send a message via Yahoo to chrisman
Hi Shock Wave,
Next time.... you'll get another chance.
Hey when do you think you be able to pick up the TbO1?.
E-maill me or call me.Thanks.
Chrisman.
chrisman is offline   Reply With Quote
Old 01-09-2002, 11:50 PM   #453
MonSoon's Avatar
chrisman .. i will be ready for the 19th ... remember to bring ur pit wizard
MonSoon is offline   Reply With Quote
Old 01-10-2002, 10:41 PM   #454
MonSoon's Avatar
here is a question... do u guys think i can make 5 mins on 2400's with a 10x2 or 13x3?
Old 01-10-2002, 11:34 PM   #455
Mopar's Avatar
Hey Shockwave / Chrisman, where in BC do you guys race? When I visited family in the Vancouver area a while back I couldn't find any tracks. And none of my cousins are into R/C so they had no ideas. If I get another chance to visit soon, I'd like to try the scene there. Found 1 track out in Langley, but it was closed when I called. I have since heard of others, but would be nice to know for sure. Race schedule too, please? Thanks!!!
Schumacher KF2se, Associated B5m CE (sold), Hot Bodies D413, Associated T5m, Axial Exo Terra, Schumacher Mi5, CRC 1/12, 3Racing FGX full suspension, Associated 18r
Mopar is offline   Reply With Quote
Old 01-11-2002, 01:19 AM   #456
chrisman's Avatar
Hey Monsoon,
You may make it with the 13T but 10T,pending how u drive.U may just dump at 5 min.Got to try to see...2400 is good for sssssssssstk.I thought u have 3000??....
Hi Mopar,
We all race indoor in a big church/gym hall.When you come by Vancouver,look up for One Stop Hobbies in Abbotsford.They can give you directions from there.The track is in Abbotsford.So it's not too far from Langley.I'll try to post the address here but if anyone out there knows,please post....thanks. see you around when you are in town.
Chrisman.
Old 01-11-2002, 01:22 AM   #457
chrisman's Avatar
Smile Here's Schedule.
Here's schdule,
The date for the rest of the year are...Jan 19, Feb 9,23 March 30 and the Western Touring Car Championship is April5,6,7. With guest driver Mark Pavidis from Team Associated.
Set up: 1:00
Practice 2:30
Racing 5:00 until about 11:00
$10 first class
$5 second class .
Phone #. 604-852-6497 [email protected]
Address to come next.
Old 01-11-2002, 07:38 PM   #458
Mopar's Avatar
Thanks Chrisman, got the address from R/C Car Action.
  • 33228 S. Fraser Way
    Abbotsford, British Columbia v2s 2b3
I can't make up there until summer, I stay with my cousin and family in Surrey, so it's not too far. What tires do you use, rubber or foam. Thanks!!!
Old 01-11-2002, 10:17 PM   #459
chrisman's Avatar
Hi Mopar,
Glad to see you ready to come up when the weather is better..
Summer is usually busy.............racin at a few local places will be outside on pavements.No schedules yet but definitely will post them when they are ready.
Tires be rubber for sure,but bring foams for gas/nitro.Looks like this year will be foam for nitro classes but rubber are allowed.You take your chances.
Electric T/C rubber tires for sure.No foams.Until then,drop in and say hello sometimes....
Chrisman.
Old 01-12-2002, 12:08 AM   #460
shockwave's Avatar
Angry
The guy sends me e-mail after e-mail about wanting my car. I get my car back and now he says. nah I don;t want it!! I'm PO'D!!!! Now I can;t get the freaken TB till I sell my Pro2!! DARN IT ALL!!
Old 01-16-2002, 06:28 PM   #461
Hi guys, I have a question to ask. I am in the process of building my kit and I ordered the plastic diff outdrives for the rear diff. I don't exactly understand what's going on here. Am I supposed to take the bearings and rings off of the aluminum one and put it on the plastic diff? I managed to pry the little plastic bushing looking thing off of the plastic one, is this what I needed to do? It looks like it would work, but wanted to make sure before damaging anything. Any other tips related to this are definitely encouraged. Thanks alot guys!!
lizard is offline   Reply With Quote
Old 01-17-2002, 01:52 AM   #462
sonneteer's Avatar
Default 7even and shocks
Hi all,
Has anyone tried different shocks on the 7Even? I liked the original ones but since I got several differen pairs so I thought to have them all set up slightly differently so on track I can easily swap them instead of changing the settings.. (like oil and springs etc.... or am I nuts?)
The shocks I have cumulated are TC3 FT threaded shocks, Tamiya Pink shocks and Tamiya Gold shocks...
And what springs do you guys run on twisty tarmac?
sonneteer is offline   Reply With Quote
Old 01-17-2002, 09:30 AM   #463
Default Plastic diffs
The rear diff will come assembled. You have to take it apart and soak each half in some kind of solvent. I used paint thinner for a minute or so and the diff rings come loose.
You need to then glue those rings onto the plastic outdrives with contact cement. You can get it at a grocery store or hardware store (not rubber cement). Put it on each piece, wait a few minutes (it will get tacky) press them together and hold for a bit. That should keep intact now. If you want to take them off just start the process over again.
Inside the outdrives are plastic bushings...one seems to come out easy (fall out) and the other needs to be pried out. Use the bearings from the orginal diff and assemble it the same way as the instructions for the orginal diff.
Steve at SpeedtechRC.com said he was testing out the outdrive blades, they go over the dogbones to protect the outdrives. I would order some of those if you can. The plastic outdrives wear quicker then the normal ones....so that would help.
_neas_ is offline   Reply With Quote
Old 01-17-2002, 09:40 PM   #464
shockwave's Avatar
chris can ya give me a ride this wekend?????
Old 01-18-2002, 04:25 PM   #465
over gear's Avatar
Trader Rating: 15 (100%+)
Arrow 7Even for sale
I have a RCLab 7Even Pro 6.0 for sale. Check it out
http://cgi.ebay.com/aw-cgi/eBayISAP...item=1691854096
over gear is offline   Reply With Quote
RCLab 7even 6.0 Pro II SteveM R/C Items: For Sale/Trade 0 10-14-2003 06:21 AM
RCLab 7even 6.0 Macky R/C Items: For Sale/Trade 2 03-04-2003 01:37 PM
f/s RCLab 7Even Evo II seaball R/C Items: For Sale/Trade 3 12-08-2002 07:42 PM
For Sale: RCLab 7Even Pro 6.0 over gear R/C Items: For Sale/Trade 0 01-18-2002 04:23 PM
