Old 06-19-2003, 09:35 AM   #31
Default never hardwire a pack backward
If you hard wire packs than you can be at risk of installing a pack backwards because you may not notice which end of your pack is negative and which end is positive. Write a + symbol on the positive end of the pack and a - symbol on the negative end of the pack so you can easily tell which end is which. You could even write the + symbol with a red permanent marker and the - symbol with a black permanent marker if you really wanted to.
racerdx6 is offline   Reply With Quote
Old 06-19-2003, 08:22 PM   #32
badboy's Avatar
Trader Rating: 14 (100%+)
Default SPEEDO QUESTION???
Can i use the LRP SR for mod racing? If yes, do i need to adjust anything?
thanks!!!
slow is fast . . .
badboy is offline   Reply With Quote
Old 06-20-2003, 12:22 AM   #33
ChrisO's Avatar
Send a message via AIM to ChrisO Send a message via Yahoo to ChrisO
Default Re: SPEEDO QUESTION???
thanks!!!
sorry mate wrong thread.
ChrisO is offline   Reply With Quote
Old 06-20-2003, 05:15 PM   #34
fatdoggy's Avatar
R/C Tech Charter Subscriber
This is a tip,
Put sunscrean on if you race outdoors.
fatdoggy is offline   Reply With Quote
Old 06-20-2003, 05:19 PM   #35
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
lol agreed fatdoggy.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 06-20-2003, 10:25 PM   #36
Originally posted by fatdoggy
This is a tip,
To me it is the best tip I have seen on this thread!!!
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 06-20-2003, 10:30 PM   #37
ChrisO's Avatar
Default Sunscreen
This is a tip,
I dont know if this works or not, but ya can use sunscreen on foam tires.
Old 06-21-2003, 08:46 PM   #38
-CriMinaL- |RC's Avatar
Send a message via AIM to -CriMinaL- |RC Send a message via Yahoo to -CriMinaL- |RC
Default REEF OIL
Reef Suntan Oil works well on foams .. only problem is it takes ages (1-2 days) to properly soak in.
-CriMinaL- |RC is offline   Reply With Quote
Old 06-23-2003, 01:25 AM   #39
GTMilenko's Avatar
Default Re: perfect mesh.
Originally posted by traxxasdude
take out 1 motor screw and put a iece of paper in between the spurr and pinion, then press the piniion as hard as you can against the spur, then turn the gears to remove the paper.
i have seen this tip about a thosand times! and i don't know about you guys but it doesn't work for me, even if i use 2 peices of paper it still turns out to tight!
so heres what ya can do, put a pinion on that has 1 more tooth than the pinion you actaully want to use, press it up tight as ya can, then take it off and put on the pinion with one less pinion(the one you plan on running). the result is a "perfect mesh"
btw - i can't take credit for this, i read it in another thread, but i thought this would be a good place for it.
GTMilenko is offline   Reply With Quote
Old 06-23-2003, 01:52 AM   #40
Steevo's Avatar
Default Re: Re: perfect mesh.
Sounds like a good idea. Does it work for 64 and 48 DP gears??
Personally the paper trick has worked for me to date and I have managed to achieve "perfect Mesh" (or near enough) every time..
Steevo
Steevo is offline   Reply With Quote
Old 06-23-2003, 02:03 AM   #41
Regional Moderator
Addict sa RC's Avatar
I dunno if you can do this on the XXXS though.
Addict sa RC is offline   Reply With Quote
Old 06-23-2003, 02:07 AM   #42
GTMilenko's Avatar
Default Re: Re: Re: perfect mesh.
Steevo
i've only tried it with 48p, but i see no reason that it wouldn't work for 64p.
btw what a great thread!
Old 06-23-2003, 02:12 AM   #43
GTMilenko's Avatar
Default More traction for stock mini-z
heres one for the mini-z racers.
take the tires off and turn them inside out(then put them back on). its amazing how well this works!
mine had a bad case of oversteer so i just turned the back tires inside out, now it has a little understeer insted. much easier to drive and way better lap times!
Old 06-23-2003, 11:56 PM   #44
fatdoggy's Avatar
Default Re: Re: Re: Re: perfect mesh.
For 64 pitch you'd need to use something thinner like plastic wrap. I eyeball gear mesh every time, paper trick just never worked for me, it always felt too tight or too loose.
Old 08-04-2003, 06:38 PM   #45
Default Save money on foam body protectors
I know that we don't spend a lot of money on foam body protectors that protect your bodies where they rest on your body downstops. But I was looking at the X-Ray T1R and noticed how it included foam pieces ontop of their body downstops. So you can do that buy buying the body protectors and just sticking them on top of your body protectors. Than just cut the extra foam off. And you will never need to buy new body protectors again!
X-ray T2, Tips and Tricks trailranger Electric On-Road 4 05-17-2008 02:44 PM
M11 TIPS AND TRICKS!!!!!! S-T-R-l-K-E-R Electric On-Road 11 08-11-2005 11:32 PM
tips and tricks XXX-NT streetstock Electric Off-Road 2 05-13-2005 10:50 AM
JRX-S Set up tips, tricks, and set ups bigdog xxx-s Electric On-Road 5 04-20-2005 10:12 PM
Tips And Tricks rctc3 Electric On-Road 36 03-10-2002 10:54 AM
