Old 06-17-2003, 11:13 AM   #16
traxxasdude's Avatar
Default perfect gear ratio
run 1 battery pack and at the end of the run you should be able to touch the motor for 3 seconds
traxxasdude is offline   Reply With Quote
Old 06-17-2003, 11:58 AM   #17
Gee wilickers Traxxasdude you can copy the tips and tricks section from RCCA!!!
The whole point of this is to offer fresh tips and tricks unlike the old rehashed crap from RCCA....... BTW: the silly putty trick is very laughable.... a T-Maxx or 1/8th truck or buggy diff will chew that stuff up!!!!!
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 06-17-2003, 12:02 PM   #18
OHH wait a minute.... in a pinch you can use paper clips for body pins!!!! Or old CD's as set-up wheels...... or maybe an old pill bottle to hold spare screws!!!! WOW!! I can think of a hundred things I read in RCCA!!!!! Yeah look out this thread is going to 100,000 posts in no time!!!!!!
Old 06-17-2003, 02:18 PM   #19
Cracker78's Avatar
Send a message via AIM to Cracker78
Actually i never thought of using cd's for setup wheels.... thats a pretty cool idea... i just might give it a shot someday
Cracker78 is offline   Reply With Quote
Old 06-17-2003, 02:22 PM   #20
R/C Tech Charter Subscriber
Default Steering Slop and Window Bodyshell detail
Put a plastic bag between the ballcup and balljoint and snap it shut, the bit of plastic trapped inbetween keeps the joint smooth but gets rid of slop!
Use Real Car trim tape to detail around bodyshell windows rather then paint them or cutting out the decals you get with the shell.
keithander is offline   Reply With Quote
Old 06-17-2003, 05:27 PM   #21
I just posted it for people who might not get RCCA
Old 06-17-2003, 07:10 PM   #22
Steevo's Avatar
Default EMPTY FILM CANISTERS FOR STORAGE
I use empty white plastic film canisters for storing my screws, circlips, brush springs, and any other small parts that have a habbit of getting lost. I use small computer labels to mark each one so that I know whats in them.
I also use film canisters to store any spare armatures that I have. I use the white canisters and drill a hole in the centre of the top and bottom. You can then place the arm in the canister where it will be held perfectly in the centre. Once again I use sticky labels to Identify the type of arm.
I recommend the white canisters over the black ones because the lids snap on nicely.
Steevo
Steevo is offline   Reply With Quote
Old 06-18-2003, 06:54 AM   #23
Default perfect timing
hook up your motor to a constant suply source at 5 volts, loosen both screws on the endbell (don't screw them all the way out) and twist the endbell until you hear the revs drop and then twist it back to where you heard the highest rpm.
Old 06-18-2003, 07:23 AM   #24
Exclamation Motor timing!!!!!!!!!!!!!!
OK That was really bad advice ..... at the point where you here the highest RPM's under no load you will be at about 40 degs. of advance timing!! This is not only the absolute lowest torque range, but also the least efficient, and hardest o all of your equiptment from batts to speedo, brushes, and comm!!!
If you don't know how to properly set your endbell timing please just leave it at the factory presets or find someone REPUTABLE to do it for you!!!!!
Old 06-18-2003, 10:59 AM   #25
popsracer's Avatar
Default 3M products
Originally posted by howard hudson
I agree with the 3m tape.. the blue stuff. easy to work with and gives a nice crisp mask line. only down fall is it is a little more money.
If you ever have the choice between a '3M' product or brand "X" product, ALWAYS cough up the extra cash and buy '3M'. Their products simply out perform anything else on the market, from Tapes, Adhesives, Sandpapers,Threadlocks, etc, everything they make is just better. Slightly higher price, but at a MUCH greater quality.
popsracer is offline   Reply With Quote
Old 06-18-2003, 11:11 AM   #26
Default Re: Motor timing!!!!!!!!!!!!!!
sorry, but it seems to work for me and I can still run it for 5 min.
Old 06-18-2003, 05:54 PM   #27
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
yea it works, but how well
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 06-18-2003, 09:25 PM   #28
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
Default Re: EMPTY FILM CANISTERS FOR STORAGE
Steevo
speaking of packaging. alot of our club members use pringle cans to store tires. they are the perfect size. and i think they have enough for just enough 2 sets (8)
this might be common
pringles those chips in those long tubes (edited) just making sure
Calvin Ng is offline   Reply With Quote
Old 06-19-2003, 07:37 AM   #29
traxxas dude thats what i do than if i want a little more torque id retard the timing a bit
trf man is offline   Reply With Quote
Old 06-19-2003, 09:31 AM   #30
Default number of battary charges
If you are running at a all day just for practice so you are almost always recharging battaries (unlike some race days where you only recharge a few times) , every time you charge a pack put a small plastic clip on it like the ones that come on bags of bread, than when you get to three clips for one pack, retire that pack for the day. I've been told that you can damage a pack if you run it more than 3 times a day, but if you only like to run a pack 2 times per day than after there's 2 clips on the pack retire it. You can clip the clips onto the wires on a pack. But if you're hardwiring, you might have to be inventive .
racerdx6 is offline   Reply With Quote
X-ray T2, Tips and Tricks trailranger Electric On-Road 4 05-17-2008 02:44 PM
M11 TIPS AND TRICKS!!!!!! S-T-R-l-K-E-R Electric On-Road 11 08-11-2005 11:32 PM
tips and tricks XXX-NT streetstock Electric Off-Road 2 05-13-2005 10:50 AM
JRX-S Set up tips, tricks, and set ups bigdog xxx-s Electric On-Road 5 04-20-2005 10:12 PM
Tips And Tricks rctc3 Electric On-Road 36 03-10-2002 10:54 AM
