Like Tree1Likes
Closed Thread
Old 07-03-2008, 10:24 AM   #1471
Keith Sawyer's Avatar
It's a lot more fun when everyone is running the same speed so it all comes down to setup and driving.
NP about the teching
Keith Sawyer is offline
Old 07-03-2008, 10:37 AM   #1472
shadow102's Avatar
Trader Rating: 21 (96%+)
Anybody else having issues with the front splitter on the cuda and camaro bodies. Mine has gotten so flimsy that it drops and drags. Is it withing the rules to cut it off or is that part of the "cut along the body line" rule
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline
Old 07-03-2008, 12:52 PM   #1473
padailey's Avatar
That is a problem I've run into also. A lot of guys are leaving a little extra body for support in the front. Guess I never thought of it as against the rules but it doesn't directly follow the "cut along body lines". I can't really explain it but here are some posts that have pictures. Look at the front end of some of the cars and you'll see the "extra" lexan left for support. #852, #840 (last picture), #724
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline
Old 07-03-2008, 01:17 PM   #1474
speedsterblade's Avatar
I put a coat of sho-goo on the inside of the body on that 'air dam' or what ever you call that front spoiler...I also coat the inside of the fender wheels and anywhere you typically get cracks from crashes. Saves the paint also. Mine is still in good shape...hasn't crack or hangn off yet! tip: moistn your finger and it won't stick to you finger that much and speads easier...
speedsterblade is offline
Old 07-03-2008, 02:42 PM   #1475
Flying Monkey's Avatar
Trader Rating: 54 (100%+)
Another good method is cutting the fuzzy off 1 end of a Q-tip and using the cut end to spread the shoe goo. Works every time for me.
MONKEY BUSINESS RACING
Flinging poo at a track near you! Winning hearts and minds everywhere!
www.graphicmonkeydesigns.com
Brooksphotodesign.net
Flying Monkey is offline
Old 07-03-2008, 05:28 PM   #1476
Trader Rating: 21 (100%+)
Default shoo goo
Suggestion .... put a peice of window screen on also. Sho-goo, silver window screen, shoo-goo. Black screen will show thro a light painted car.
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline
Old 07-03-2008, 05:39 PM   #1477
hi just wanted to know if any one is using a tt-01 in this class? i had a tt-01 and did my first vintage race last weekend. what a blast. but i had to run a six cell instead of a four cell. the gearing is way off. does any one know what kind of gearing i need to run ? thanks jay
lewis2000 is offline
Old 07-03-2008, 06:18 PM   #1478
shadow102's Avatar
what motor are you running? Suggested gearing is under the "rules" section of the trans am web site
www.nexusracing.com
www.go-rc.org
Old 07-03-2008, 06:24 PM   #1479
KAHUNA's Avatar
Cool
Here U go Mr. Lewis !
Motor Specifications:
Option 1: 27-turn ROAR stock motor: No FDR limit, bearings are not allowed.
Option 2: 17.5 brushless: Motor timing advance is allowed. 12.5 mm rotor diameter maximum (no "tuning" rotors are allowed).
Option 3: 21.5 brushless with 2C LiPo: Novak SS21.5 Pro brushless motor (pn:3421) ONLY combined with any ROAR-approved hard-cased 2C 7.4v LiPo pack up to and including 5000 mAh capacity.
All house track rules regarding LiPo usage apply. Final drive ratio is to not exceed 4.2. Motor timing advance is allowed.
Suggested gearing FDR recommendations:
27t brushed/4-cell: 5.4 - 5.7 FDR
17.5 brushless/4-cell: 3.5 - 3.7 FDR
21.5 brushless/LiPo: 4.2 - 4.3 FDR
http://www.usvintagetransam.com/
Team Scream Racing Middle River Hobbies GQ AMERICA Diggity Designs Castle Creations ✦TheRCShack✦ www.castlecreations.comwww.teamscreamracing.com www.diggitydesigns.comhttp://www.gqproduct.comMini www.middleriverhobbies.comTom Brown The Rev 7 XRAY ✦ M05 Surfs Up DudeMiddle River Hobbies
KAHUNA is offline
Old 07-03-2008, 06:54 PM   #1480
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
It's within the rules as long as it doesn't completely change the look of the front end. In the case of the HPI bodies, most of the front spoiler areas are in need of a little help. Newer bodies I have seen are a LOT thicker up front, so at least it appears as though HPI is aware of the issues.
Here's a good example of how to help the 'Cuda...
Another tip if you don't want to use the ShoeGoo trick is to cut the corner inside the spoiler with a little curve inside, instead of a square edge. The square cut will rip EVERY time, while a rounded corner has much less stress on it...
Both versions are mine, and both survived a lot of front impact. Leaving a little meat on the corner certainly helps, no matter how much is left there.
You probably won't have much gearing help with your setup, as no one uses a 6-cell in this class. It's a 4-cell class only, otherwise you are using 21.5 brushless motors. I'd think as long as you can gear the car so your speeds are close to the other cars, you should be fine to get yourself up to speed in the class, before you decide what power choice you want to run in it.
-doug
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline
Old 07-03-2008, 07:04 PM   #1481
thanks. can't wait to race again
Old 07-04-2008, 04:15 PM   #1482
pejota's Avatar
Here's a question...
Down in here in Florida they are allowing 17.5/lipo instead of 21.5/lipo...
Does anyone have any experience in running that combo? Frankly, i was looking forward to the 21.5/lipo because i have a 13.5 now and it is CRAZY fast. As a new racer, i'm not coordinated enough to handle that. Will the 17.5 be a significant step down in speed? As far as i know, there's no FDR limit. Fortunately i didn't buy a 21.5 yet or else i'd be CHAPPED.
pejota is offline
Old 07-04-2008, 04:20 PM   #1483
keepitmovin504's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to keepitmovin504
That combo is like running a stock motor on 6 cells
Do 4cells/ 27turn run with 17.5/lipo?
AE T5M/B5M/B44.3
TLR SCTE 3.0
keepitmovin504 is offline
Old 07-04-2008, 06:39 PM   #1484
squarehead's Avatar
Check with the race management to see if their current rules are their long-term plans. I know at least one Florida group planning to run the official USVTA rules this upcoming season, so it would be worth it to find out where they stand.
There will be big benefits in this upcoming winter season for running the official rules, so it's going to be more rare to see tracks not following along with the rest of the country.
doug
Everything depends.
Nothing is always.
Old 07-05-2008, 08:45 AM   #1485
sportpak's Avatar
Trader Rating: 26 (100%+)
Our track in Ft Wayne is going official VTA rules, I think it'd be foolish not to be. It also helps with the _itching that always happens over the rules, this way your explanation simply is "we are inline nationally with the official organization".
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline
Closed Thread
Georgia Vintage Trans Am Racing shadow102 Georgia Racing 725 02-24-2012 09:56 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Thursday Vintage Trans Am racing at Victory in Green Bay Brian F Wisconsin & Illinois Racing 13 05-10-2008 08:37 AM
