Like Tree1Likes
Closed Thread
Old 03-17-2012, 05:36 PM   #14131
Technically, the width of the footprint of the tires on the ground/pavement is called "track". Front track and rear track. Wheelbase refers to the distance between the front and rear axels. (axel centers actually)
Also, I think that the 6mm offset figure is for each wheel. The offset pushes the wheel and tire out so that the inside edge of the wheel does not rub on the suspension arms,linkage, etc.
Rufus2010 is offline
Old 03-17-2012, 07:08 PM   #14132
beemerfan's Avatar
Trader Rating: 34 (100%+)
My bad on the "Track." I knew that but was typing faster than I was thinking. Bad place to be. I believe you are correct on the off-set as well. The HPI bodies with a 210mm rear width fill out pretty well with the extra 12mm. They wouldn't do that if it were only 6mm.
beemerfan is offline
Old 03-17-2012, 08:32 PM   #14133
nashrcracer's Avatar
R/C Tech Charter Subscriber
vta at the roar carpet nats is great qual 4th .1 out of 3rd and I can't wait till tomorrow to get my run in. darkside/batboy/myron your missing it!!!!!!
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline
Old 03-17-2012, 09:45 PM   #14134
Flying Monkey's Avatar
Trader Rating: 54 (100%+)
Good luck bud. Myron not there? World coming to an end?
Really wanting to do some more VTA racing. We have to get a trip up there to you guys again soon. We got the SC10's to be able to race something locally but kept the VTA cars for when we can make it up there.
MONKEY BUSINESS RACING
Flinging poo at a track near you! Winning hearts and minds everywhere!
www.graphicmonkeydesigns.com
Brooksphotodesign.net
Flying Monkey is offline
Old 03-18-2012, 12:00 AM   #14135
wwddww34's Avatar
Trader Rating: 9 (91%+)
We had a Concourse contest at the 2012 ROAR Carpet Nationals yesterday. Here are pics of the VTA's that entered the contest.
wwddww34 is offline
Old 03-18-2012, 12:03 AM   #14136
wwddww34's Avatar
And the winner of the Concourse contest is... drum roll please...
None other than SOCAL's Tony Phalen with his 1969 Chevy Z28 Camaro painted with a Gulf Oil racing scheme. Tony is also TQ with his Hot Bodies TCX car. He is running a Novak Edge ESC with a Ballistic 25.5T. This guy is flat out fast!
wwddww34 is offline
Old 03-18-2012, 09:17 AM   #14137
competionpark's Avatar
Send a message via Yahoo to competionpark
Originally Posted by NovakTwo View Post
The reason it's 120.00 is because the Ballistic isn't in the Combo.....
This our new, affordable combo with the Ballistic:
EDGE 2S /Ballistic 540 Brushless Systems
Our Club combos are designed for beginners who can later trade/upgrade when their skills improve.
has the new club combo been approved for VTA use officially? I was checking the rules website and it does not mention it yet? Not trying to be pessemistic, just trying to get some clarification before I order a few of them only to be told no at the track.
competionpark is offline
Old 03-18-2012, 02:00 PM   #14138
LasagnaCat's Avatar
Trader Rating: 143 (100%+)
Send a message via AIM to LasagnaCat
So is there an optimum track width for a VTA car, front and rear?
I tried using 17.5 setup sheets as a starting point last year and kept running into problems with ride height, front tires rubbing the bottom shock ballcup, etc. I'm assuming at least some of those are because the setup sheets are geared towards running the identical width front and rear standard TC tires.
When trying to 'move' a setup sheet over to a VTA application, where do you make changes to compensate for the wheel offsets (if at all?)
Well if it seems to be real, it's illusion
For every moment of truth, there's confusion in life...
LasagnaCat is offline
Old 03-18-2012, 04:30 PM   #14139
Trader Rating: 24 (100%+)
The offset question has been answered. Each rear wheel has 6 degrees of offset and each are 31mm wide.
Optimal track ? not that I'm aware of. Never seen any published numbers and doubt there's any defined standard. The Schumacher site has some videos featuring world champ Chris Grainger. One of them answers the question of differing wheel tracks front and rear. Yes, it is used as a setup variable. As for "moving" setup sheet info, many of the basics like castor, spring and shock rates, kick up and anti dive could be left alone if you already have a successful chassis that's been running 21.5 or 17.5. Keep in mind that VTA, like other spec classes, may require a completely different thought process to setup simply because it has such different requirements. Going slower doesn't mean a great 17.5 setup will work for a VTA car. Spec tires, Heavier weight requirement, different handling characteristics all translate into different setup.
Most of all, remember that the slower speeds allow you to really see the car doing things. Don't over think it. It's really just getting back to basics. Start with a box stock setup and adjust from there. Inside of wheel rubbing ballcup ?....put a spacer on the axle.
Evoracer is offline
Old 03-18-2012, 06:00 PM   #14140
LasagnaCat's Avatar
So is it a matter of setting the front width so nothing rubs and then making the rear roughly 10mm wider than the front? If I'm reading that correctly, assuming everything else (caster., camber, etc.) is set correctly, you're saying that the exact relative front and rear track width isn't a big deal? We're still in the (asphalt) off-season here in the Chicago area, so actually going out and trying this stuff still isn't an option for a while.
Old 03-18-2012, 07:32 PM   #14141
Track width is a big deal on ANY car.
Generally, widening the rear provides more stability.
Narrowing the rear will make it a bit more reactive with more steering.
Widening the front gives you stability into the turn and more steering on exit
Narrowing the front makes the car more aggressive on entry and less steering on exit.
So YES, simply adjust things to clear ball cups and such. On my MI4LP, the track is approx 185mm front and 195mm rear. I do have a 1mm washer on each front axle to push the wheel out a bit from the camber link ball cup.
I started with a Schumacher provided setup for asphalt and technical layout. Other than the shim washer for the front wheels, my car is spot on that setup; which happens to be for a 10.5 with tc tires.
I was more concerned with the track details than what motor was used. At best, I might have to lighten the shock fluid, use lighter springs or lighter roll bars.
Evoracer is offline
Old 03-18-2012, 10:01 PM   #14142
DARKSIDE's Avatar
so who is the 2012 ROAR VTA Champ?
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/OTT/1UP
Apex Raceway and Hobbies
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline
Old 03-18-2012, 10:03 PM   #14143
DARKSIDE's Avatar
thanks friend
DARKSIDE is offline
Old 03-19-2012, 07:51 AM   #14144
DARKSIDE's Avatar
congads to you...you did a great job getting VTA into this event...and did some really good promo...
do you know what everyone was running?
DARKSIDE is offline
Old 03-19-2012, 09:33 AM   #14145
trytowin's Avatar
Change of pace question:
With the 2012 Carpet Nats having been run. ( nice pics btw ) In their rules it shows " Any ROAR Approved 25.5 motor "
Problem is ROAR does NOT show any 25.5 motors listed on their Brushless Motor Approved List. ( I checked before posting this ) Now, USVTA dictates that only Novak motors can be used. ROAR does not dictate what brands to be used in any class of racing, just guidelines that manufacturers have to follow in order to obtain approval.
With the Elec On-road Nats coming in Aug @ Leisure Hours Raceway, Joliet, Il. With VTA being one of the house classes being run. Would it be run with the USVTA rules, or some kind of mixed bag from both parties ??
I'm just here to discharge my battery.
trytowin is offline
Closed Thread
Georgia Vintage Trans Am Racing shadow102 Georgia Racing 725 02-24-2012 09:56 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Thursday Vintage Trans Am racing at Victory in Green Bay Brian F Wisconsin & Illinois Racing 13 05-10-2008 08:37 AM
