Like Tree1Likes
Closed Thread
Old 06-27-2008, 09:17 AM   #1381
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Yeah, I think it would be too small on asphalt. You'd be better off with a cheap-o Futaba analog like a s3010 for $22. It'd be enough torque and size with a little trade-off in speed.
With anything like this, the more you pay, the more strength, torque, speed and quality you are going to get.
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline
Old 06-27-2008, 10:44 AM   #1382
padailey's Avatar
Originally Posted by TimPotter View Post
Did you guys have a quick change system for the batteries ? Or a minimum pit time.... like 1 minute ?
No not really... I don't think anyone tried anything special for the battery changes, and no minimum pit time. The only rule concering battery changes was no body modifications. We also ran a mini enduro the same night and the previous enduro someone cut out their mini body around the battery to help with battery swaps, so that was not allowed this time. Since we only ran one car per team that helped draw in some guys not racing regularly since they only had to drive rather than have a car all set up. It was a nice turnout for the regular club night in the summer.
We ran a mini enduro also and the big thing as far as pits were concerned was the Mini's had to have a mandatory motor change, and the TA's a mandatory tire change. If you had two sets of tires he marked the second set which had to be on the car at the end. If you didn't have two sets he marked one side and those had to be on the other side at the end.
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline
Old 06-27-2008, 04:16 PM   #1383
never mind, found the answer
outlandr91 is offline
Old 06-27-2008, 04:17 PM   #1384
RCknight's Avatar
Default Quick need some help?
What pinion would I need to get a final gear ratio of 4:40 uisng a 64p 100t spur gear, EU 008 with 20t pulley and Vintage tires. Thanks.
RCknight is offline
Old 06-27-2008, 04:36 PM   #1385
IL_AudiRacer's Avatar
Trader Rating: 58 (100%+)
Check out this site make sure your speakers are turned up
www.gearchart.com
IL_AudiRacer is offline
Old 06-28-2008, 08:05 AM   #1386
Keith Sawyer's Avatar
I am running a TC3 in our VTA class and I just got a 17.5 setup for it, I am having problems getting the 3.5 to 3.7 gearing. The largest 64p pinion I could find is a 56 tooth which calls for a 79 or 80 tooth spur, the smallest I could find is 88. anyone know where to get a 79 or 80.
Keith Sawyer is offline
Old 06-28-2008, 08:15 AM   #1387
PRS ( precision racing systems) goes down to a 76 Pt# prs6476pl and robinson goes to 78 PT# rrp-4178. I had my TC4 geared at 49/78
Team Novak,Gravity RC,
ercwhtsd is offline
Old 06-28-2008, 08:17 AM   #1388
squarehead's Avatar
Thumbs up
Tires have no relevance on FDR.
FDR = SPUR / PINION x INTERNAL DRIVE RATIO
For your car, a 38t pinion will give you a 4.474 FDR and a 39t pinion will give you a 4.359 FDR.
PRS and Robinson both make tiny spurs, which is what you need. There were a few TC3s and TC4s at the Nationals running 17.5, so it can be done. You have to relieve the chassis a little with a Dremel in the pinion area for the chainsaw pinions to clear, but not very much at all. I want to say that the gears that were used were 78t-spur and a 52t-pinion.
HTH,
doug
Everything depends.
Nothing is always.
Old 06-28-2008, 08:22 AM   #1389
TimV's Avatar
Trader Rating: 49 (100%+)
Originally Posted by BobWoodhouse View Post
For the TA class, I will be trying out a Futaba S9650, a "high-torque" 12th scale servo.
Definatly go for a standard sized servo. The durability on the 9650 is not good enough for the TA class. Take it from someone who has already tried it, and stripped out the gears in the servo. It seemed fast enough for me, but just not durable. I only got 1 weekend out of it, and stripped the gears in practice the next weekend.
PRS makes pinion gears up to 65t. I don't know if you have a limit in the car where you cannot run one that size or something, but the larger pinion gears are definatly out there.
- - - Express Motorsports - - - MW Designs - - - Mimi Wong Clan - - - Final Thoughts Racing - - -
- - - Team AKA - - - RDsquared - - -
It's the year 2010. Shouldn't vacuum cleaners be quieter by now?
TimV is offline
Old 06-28-2008, 01:27 PM   #1390
Thanks for the info guys.
Old 06-28-2008, 04:04 PM   #1391
Flying Monkey's Avatar
Trader Rating: 54 (100%+)
mmmmmmmmmmmmmmmm sexy!
MONKEY BUSINESS RACING
Flinging poo at a track near you! Winning hearts and minds everywhere!
www.graphicmonkeydesigns.com
Brooksphotodesign.net
Flying Monkey is offline
Old 06-28-2008, 04:25 PM   #1392
snoopyrc's Avatar
You dont need to be any faster.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline
Old 06-28-2008, 04:28 PM   #1393
snoopyrc's Avatar
Monkey thats a neat shell. Definitely the only one at PT.
snoopyrc is offline
Old 06-28-2008, 04:34 PM   #1394
lol thanks. it has too look good to detour away from the poor driving ability
Old 06-28-2008, 04:34 PM   #1395
Scottrik's Avatar
Trader Rating: 245 (100%+)
OK--you can have your money back. Send it home. Good thing you didn't "mount" it.
You're gonna have to cut those sides WAY up on a TC chassis. I'm trimming and mounting mine before paint. In fact my paint guy has been riding my case to git 'er done.
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline
Closed Thread
Georgia Vintage Trans Am Racing shadow102 Georgia Racing 725 02-24-2012 09:56 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Thursday Vintage Trans Am racing at Victory in Green Bay Brian F Wisconsin & Illinois Racing 13 05-10-2008 08:37 AM
