Like Tree1Likes
Closed Thread
Old 02-28-2012, 11:05 AM   #13906
Trader Rating: 17 (100%+)
Originally Posted by 6376vette View Post
Gearing sounds good to me. I'm running 3.84 right now. For the punch what are your esc settings? Are you running a spool up front? The punch control in the esc and a spool will both help with corner exit torque.
Man I feel stupid. I did not realize there was any adjustment there on my GTB2. I think everything was reset to the default after I did the throttle epa settings and yes I am running a spool.
429racer is offline
Old 02-28-2012, 11:31 AM   #13907
Company Representative
Our upcoming Club esc is really One-Touch and Go!™:
The Novak Club ESC features Novak’s newest breakthrough for the club racing market: One-Touch and Go!™. Simply complete the One-Touch programming and the Club ESC is ready to run! No adjusting, tuning, or customizing.
Novak has taken input from our team drivers, racing customers, and our test team to select one of the most universal, throttle profiles to date. This means you have nothing to worry about or tune on your ESC. Novak has done all the hard work for you, and has customized the ESC for optimal non-timing spec or “blinky” class racing.
NovakTwo is offline
Old 02-28-2012, 12:01 PM   #13908
MCSEDanny's Avatar
Not to interrupt the drama of tires MIA, but can some people chime with an average timing and fdr for their 25.5? I believe I am a little off the pace and would feel much better in knowing which direction I should go with my motor and gearing. I am running an fdr of 3.93 and timing one mark from being maxed out on a 96 x 40 track and it feels as if my punch is lacking and my top speed is close, but not quite there. Any advise or pointers would be great. THANKS!
Have you cycled your battery packs to check the IR? Have you checked the numbers on your stator to see how close or matched they are? Have you dyno tested your motor and then dyno tested at each tick mark on timing to see where it performs the best?
Sorry 429 completely using you to mess with some of the others on this thread.
I will tell you on a 70x45 track I am geared at 3.4 FDR, single large Novak fan pulling heat away from motor taped to chassis (nothing attached to motor) and temp is about 145-155 after 8min race.
Team Turtle Trax / Loganville RC Raceway
Mugen MBX6TR / Bonito
Kyosho MP9 TKI3 / Plus 4
Kyosho MP9 TKI3 / Electric / WTF
AE B44.3 / ORCA VXX / D4 7.5
MCSEDanny is offline
Old 02-28-2012, 12:08 PM   #13909
cdwilliams1's Avatar
Trader Rating: 38 (100%+)
What's the release date on that?
I race at www.mncarpetoval.com !
cdwilliams1 is offline
Old 02-28-2012, 12:34 PM   #13910
Late March. The Club Combo 25.5T has a 'street price' of $119.99.
I think that the price point and simplicity of our Club offerings will be great for getting new customers into spec racing.
NovakTwo is offline
Old 02-28-2012, 01:43 PM   #13911
Trader Rating: 41 (100%+)
AGAIN!!! Novak comes thru for the VTA class WOW I am always amazed with the speed at which Novak comes out with Products WE ACTUALLY WANT!
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline
Old 02-28-2012, 02:39 PM   #13912
Agreed! This is what I want to pick up for the new vta ride I'm building! Did the VTA guys clear it and add it to the approved list, or will that happen closer to the release date?
Old 02-28-2012, 03:06 PM   #13913
Hey no problem, I am used to being used like a guinea pig lol. Cycle lipos I will not, did not know there were numbers to match (haha) and dyno not so much! From the sounds of it maybe go up one more gear and turn up my minimum drive a little bit as well or turn down timing and crank up the gearing HMMMM!
429racer is offline
Old 02-28-2012, 03:17 PM   #13914
+1
Especially since the startup costs involve buying a (new) motor/esc combo at 3-4x the price of a used TC3 chassis . This is something I would definitley buy when building my third VTA for my younger son as its price point places it comfortably within reach of families/racers on a tight budget.
shogun121 is offline
Old 02-28-2012, 03:54 PM   #13915
Robudda723's Avatar
Trader Rating: 24 (100%+)
Ok, Picked up a TC4 to run our local VTA class. I searched this thread, I searched the TC4 thread, and searched on line, and can't seem to find a good starting setup for the TC4 chassis. Am I missing something? Anyone have a link to a good starting setup?
Thanks,
Rob
Robudda723 is offline
Old 02-28-2012, 04:27 PM   #13916
Thanks,
Rob
I run the FT TC4 but similar setup
First if your track low traction or high?
My Setup
Front
Blue springs
35 wt oil
stock pistons
2nd outside hole up and outside hole rear
-.5 camber
4 degree caster blocks
.025 shim under the trailing a-arm block
2nd from longest upper camber link 2mm shim under ball stud
Rear
silver springs
30wt
stock pistons
second from inside hole up and outside arm
2.5 degree toe in block
.025 shim under forward a-arm block
Longest upper camber links with 1mm shim under ball stud
-1.5 degrees camber on worn tires but fresh I use about 2-2.5 but I have to play with it to get the traction I want
Jason Deadman
jdeadman is offline
Old 02-28-2012, 05:29 PM   #13917
Robudda723's Avatar
Our Track starts off low/medium traction, but has pretty good traction by the main.
Thanks for the setup. I did plan on running those springs and 35 weight oil all around, but will pick up some 30 for the rear before racing Saturday.
Thanks again for a starting point.
Rob
Old 02-28-2012, 06:05 PM   #13918
bigblack's Avatar
Default tc5 vta gearing ???
im trying to figure out what gearing to start with for my tc5, pinions and spurs.. any help would be greatly appreciated!
thanks brandon
i tend to learn lessons the hard way.. man this is gonna get expensive.
bigblack is offline
Old 02-28-2012, 06:06 PM   #13919
bigblack's Avatar
bigblack is offline
Old 02-28-2012, 06:16 PM   #13920
Flying Monkey's Avatar
Trader Rating: 54 (100%+)
100 spur / 50 pinion gives you a 4.0...any 50% combination will give you a 4.0 which is a good starting point
MONKEY BUSINESS RACING
Flinging poo at a track near you! Winning hearts and minds everywhere!
www.graphicmonkeydesigns.com
Brooksphotodesign.net
Flying Monkey is offline
Closed Thread
Georgia Vintage Trans Am Racing shadow102 Georgia Racing 725 02-24-2012 09:56 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Thursday Vintage Trans Am racing at Victory in Green Bay Brian F Wisconsin & Illinois Racing 13 05-10-2008 08:37 AM
