U.S. Vintage Trans-Am Racing
#121
FSEARA will be having the first race of our 2008 season next week. We will be running the Vintage T/A class for the first time as an option class. I have recieved a lot of feedback that we shoud be looking at two heats full of cars. We will report back, during the weekend.
#124
Ok, one of the questions I have been asked a lot is, "how are we supposed to tech FDR with unknown cars?"
I created a simple Excel spreadsheet of as many touring cars as I could find. You can use it as a simple print out to figure out if a questionable car is legal or not, or—if you have a computer with Excel—you can use the chart as a calculator to figure out what the FDR ratio is in the car. Or, to see what gear combos will work for you, plug in a spur and a pinion to see how you can get close to 4.0 with the 17.5 motor.
This rule will be GREATLY built on the honor system, and while it is not infallible, it should keep the playing field pretty level. All cars need not be teched for this FDR, but 17.5 cars with obviously too much speed can be systematically checked, as needed.
There are two files attached, both are essentially identical. One is a straightforward Excel .xls file in a ZIPPED archive, and the other is a generic .xml file that should work in any spreadsheet reader, including older versions of Excel.
The XLS format in a ZIP file is now also available on the website in the Rules section.
doug
doug
#127
I love the idea of break-out racing, but on road courses, it seems to be more potentially problematic than helpful.
#130
Awesome pics of TA's except Solara's. You better put Shoe Goop on the back of that sucker because I'm going to ram it!!
Andy..as a Mustang fan I cannot help you :P
That spreadsheet is awesome Doug. Can you edit the file so that the first two rolls do not scroll with the rest? I forgot what that's called in Excel. That way as the user scrolls down to find his car the field names stay in place.
Otherwise...awesome.
#132
Who can make this race? I might try and get the pass for this early.
Would be fun to race 1/12th and Trans Am. The TC class seems to be foam so I'd probably skip that. Hmmm
Michiana RC (in Mishawaka, Indiana) will hold the first annual "King of the Road" on-road trophy race on January 27th, 2008.
Time: Sunday, January 27th. Doors open at 8:00am, racing starts at Noon
Website: www.michianarc.com All track information is there, including class rules, etc.
Location: Mishawaka, Indiana (outside of South Bend, IN)
Track: Track is 36' x 60'. Carpet is CRC Ozite (two seasons old).
General: Three heats and a main. Re-sorts will be done after the second round. IFMAR qualifying in all classes. Scoring done with RC Scoring Pro software. Personal transponders are not only accepted, but recommended. We do have house transponders.
Cost: First class will be $15.00, second class $10.00, any additional class is $5.00.
Registration: We will do (and recommend) an advance registration. We will have the signup sheet available soon, and signup will be able to be done either online or in-person at the track. We will RESERVE PIT SPACE based on registrations. We have plenty of pit spaces available, both in two lofts, or on the track floor. We will begin registrations THIS FRIDAY. Entry form is available here.
Classes and Rules:
I'm planning on bringing both of my cars out there on the 27th. It should be a little over 2 hours or so from the Chicago area and is close enough for Michigan, Illinois, Ohio and Indiana touring car guys to come and get a taste of this great class. Hope to see you there.
Classes and Rules:
- 12th Scale Stock Advanced: This class follows ROAR rules for all car specs. Motors allowed are ROAR-legal Brushed Stock Motors, or 17.5 Brushless systems (no tuning rotors allowed) Batteries are a 4600mAh limit. 8 minute heats and mains.
- 12th Scale Novice: This is a Michiana RC Class that runs all the same rules as stock, but uses standard Mabuchi 540 motors. (We sell them at the track dirt-cheap) This class is intended for the novice racer. 5 minute heats and mains.
- Touring Car Stock Advanced: This is a FOAM TIRE class (although rubber tires are permitted) Cars follow ROAR rules. Motors allowed are ROAR-legal Brushed Stock Motors, or 13.5 Brushless systems (no tuning rotors allowed) Batteries are a 4600mAh limit, or LiPo batteries that fit the criteria listed HERE. 5 minute heats and mains.
- Stadium Truck Novice: This is a Michiana RC class that runs on the carpet with full carpeted jumps & a tabletop. Foam tires are recommended (although rubber tires are permitted, but any SOFT knobbies must be ground down to a slick-like status) Trucks follow ROAR rules. Motors allowed are ROAR-legal Brushed Stock Motors, or 13.5 Brushless systems (no tuning rotors allowed) Batteries are a 4600mAh limit, or LiPo batteries that fit the criteria listed HERE. 5 minute heats and mains. This is intended for the novice racer.
- Stadium Truck Stock Advanced: This is a Michiana RC class that runs on the carpet with full carpeted jumps & a tabletop. Foam tires are recommended (although rubber tires are permitted, but any SOFT knobbies must be ground down to a slick-like status) Trucks follow ROAR rules. Motors allowed are ROAR-legal Brushed Stock Motors, or 13.5 Brushless systems (no tuning rotors allowed) Batteries are a 4600mAh limit, or LiPo batteries that fit the criteria listed HERE. 5 minute heats and mains. This class usually has a competitive 1-2 lap separation, and is intended for advanced racers.
- Mini (18th Scale) Open: This will be an open class for any mini car or truck. The class will race in an ON-ROAD configuration (no jumps). Scalpels, Xray's Mini, 18T's, and the like can run. Motors are open (brushed or brushless). Batteries are open to most anything. LiPo's, however, are NOT allowed in this class (no hard cases)
- U.S. Vintage Trans Am: This will be an exhibition class for this race, and will run based completely on the U.S. Vintage Trans Am rules and class structure. Please see www.usvintagetransam.com for complete rules and contact information.
#133
Sign-up form
Man, I'm glad to see some interest here! I had to update the form on our site..I had the wrong date..duh... and I also made it an editable form.
Form can be found here...
http://www.michianarc.com/index.php?...id=5&Itemid=29
Hopefully..seeya'll later.
Aaron
Aaron
#135
doug
doug
I'm a bit confused regarding the 17.5 FDR.
I currently run an S400 with a 96s and 41p. It's blazin' fast in TC 13.5/6 cell. With your spreadsheet, I can go up to a 53p using the same spur before I break the 4.0 FDR. I have a 17.5 on the way. Even with a 17.5/4 cell package, I can't see how this setup isn't going to be very fast.
Is the FDR max 4.0, or is 4.0 the minimum? Either way, I've never geared that tall. Am I missing something?
Allan
