Like Tree1Likes
Closed Thread
Old 01-24-2012, 02:26 PM   #13441
Trader Rating: 24 (100%+)
This should help.
http://www.gearchart.com/index.cfm?f...n=chart.create
You're at 4.0 right now. I'd start there. Check motor temp after 3-5 minutes. If need be for the larger track change spur or pinion to get down into the 3's. 1 or 2 teeth at a time is always a smart bet. If you read up, you'll find that many VTA drivers rarely see motor temps above 135. Personally I shoot for between 125 and 135.
Evoracer is offline
Old 01-24-2012, 03:29 PM   #13442
Big Features's Avatar
I'm running around 3.8 un my TC6 on a med size track with temps in the 118-125 range.
Mike
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix FDJ Sauce
Big Features is offline
Old 01-24-2012, 05:53 PM   #13443
nf_ekt's Avatar
Trader Rating: 113 (100%+)
Originally Posted by Evoracer View Post
I went to the XXXS for stock thread to try and find you some help. First page I came across this
http://www.rctech.net/forum/electric...lasses-17.html
Check out John Stranahan's comments about "push". It might help and comes close to what you were asking about regarding softer front vs. back.
Thanks, sort of forgot about that thread. I just found a NIP, MF low roll center (rear) block set on ebay for 18 bux shipped. I'm going to work on getting this car to be as flexible possible for VTA. The potential is there. That with a different spring set up (soft F hard R) should have me close. I'm hoping that having more chassis roll out of the rear will compensate for running stiffer rear springs, and keep the traction up.
P.S I might move back to Fla in a few months... if so, I am hitting up Brevard county!
nf_ekt is offline
Old 01-24-2012, 06:12 PM   #13444
Come On down !! You'll be welcomed.
Check out that thread a bit. There was some good setups in there. I ended up using a combination of 2 of them. Silver springs front and Pink in rear. No roll bars to start but ended up putting them on after going to the MF low roll center blocks front and rear. 1 thing I found that you might check. Using the Rear hinge block in front also narrows the front a little. If the wheel track width is narrower in front then in back she'll push badly. I had some of the Losi long axles (The threaded end. Apparently they made both short and long versions) and used a modified (made center hole larger for xxxs axles) set of JRXS offset wheel hubs. That solved the problem and the push went away.
Evoracer is offline
Old 01-24-2012, 06:26 PM   #13445
nf_ekt's Avatar
Damnit man, that is what I have been doing, running the MF rear block up front!!! I knew the advantages of doing this, and with a GT/TC set up is was good since massive steering wasn't needed for the track I'm running (super hi traction asphalt-indoor) but yeah now that you mention it, this is probably killing me in VTA! I was inch perfect with the local fast guy untill the tires got too hot or the tire dope wore off, then he would start pulling slowly away .
I will look for some wider front hexes or other way to space out the front. Glad you mentioned this, I do believe you are correct. I found some AE hexes in my pit box that are wider and will give them a go.
nf_ekt is offline
Old 01-24-2012, 08:03 PM   #13446
DARKSIDE's Avatar
4.0 fdr is a good starting point
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/OTT/1UP
Apex Raceway and Hobbies
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline
Old 01-25-2012, 11:58 AM   #13447
MCSEDanny's Avatar
Default What settings did you change on Novak Edge?
It looks like the only real setting that could use changing is the Drive Frequency. What did you change it to and did you change anything else?
Team Turtle Trax / Loganville RC Raceway
Mugen MBX6TR / Bonito
Kyosho MP9 TKI3 / Plus 4
Kyosho MP9 TKI3 / Electric / WTF
AE B44.3 / ORCA VXX / D4 7.5
MCSEDanny is offline
Old 01-26-2012, 09:10 AM   #13448
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Having trouble fitting enough lead on your chassis to make weight? Want to quickly/easily change your F/R bias without the hassle of pesky stick on weight? Into hiding your chassis under a towel while it in the pits, "Green Gas Tank Syndrome", or outright subterfuge?
Okay, seriously, considering I put something like 150 grams into my XXX-S to get it to 1552 and I only use about 1200mha in 10 minutes, this is kinda cool.
http://www.teamorion.com/weight-transfer-system-en.html
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline
Old 01-26-2012, 09:29 AM   #13449
DARKSIDE's Avatar
thats cool
DARKSIDE is offline
Old 01-26-2012, 09:37 AM   #13450
DARKSIDE's Avatar
set full...and took out the drag brake
DARKSIDE is offline
Old 01-26-2012, 12:38 PM   #13451
That Orion pack looks like a darned good idea. And some say that Shorty lipo's aren't going to change things !! Hah !!
Evoracer is offline
Old 01-26-2012, 12:41 PM   #13452
MCSEDanny's Avatar
What is this I hear that you will not be running VTA on Sunday??????
Old 01-26-2012, 01:15 PM   #13453
orcadigital's Avatar
Trader Rating: 61 (100%+)
He doesn't want to make us cry.
Desoto Racing * Serpent America * Boca Bearings
"I was doing fine until about mid-corner when I ran out of talent."
orcadigital is offline
Old 01-26-2012, 05:17 PM   #13454
Hey All, If anyone has a 25.5, legal esc OR both for sale please PM me. We have a new driver looking for a VTA ride so I'm trying my best to help him and his son out.
Already posted in the "wanted" section. Thanks !!
Evoracer is offline
Old 01-26-2012, 06:29 PM   #13455
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Default Almost time for the longest week in R/C
The Snowbird Nationals is almost here! For those of you attending, please feel free to contact me with any questions about running the USVTA class at the 'birds. At Mike Boylan's request, I will be at the scoring booth or in tech throughout the event to support this class.
Why don't we endurance race more often?
Greg Sharpe is offline
Closed Thread
Georgia Vintage Trans Am Racing shadow102 Georgia Racing 725 02-24-2012 09:56 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Thursday Vintage Trans Am racing at Victory in Green Bay Brian F Wisconsin & Illinois Racing 13 05-10-2008 08:37 AM
