Like Tree1Likes
Closed Thread
Old 01-04-2012, 07:21 PM   #13216
Mad Hatter's Avatar
Originally Posted by k_bojar View Post
as i was once told by a local 'fastguy' and Reedy ROC champ, for the motors we use, the higher C packs don't make a difference because the motors don't pull enough out of the packs to benefit from the higher C ratings..
so because of this tidbit of advice, i've stayed with my 'lowly' 35C reedy pack and have every bit as much power and performance then they guys that are running higher C rated packs
I run an Orion 5000 mah 90c and really dont see an advantage over the lower C rating packs. I actually think my car felt better with my 3800. I am only putting 900 - 1000 ma back in when I charge it.
1987 Excite Bike Champion
Mad Hatter is offline
Old 01-04-2012, 07:43 PM   #13217
GLwagon's Avatar
Trader Rating: 22 (100%+)
Originally Posted by mooby64 View Post
...Other than the tread pattern,...
What is this thing you call "tread"?
GLwagon is offline
Old 01-04-2012, 08:14 PM   #13218
Originally Posted by snoopyrc View Post
You know sometimes if a fast guy puts vaseline on his motor wires and then wins a race, other people are going to try it to see if it works. Its better to just stay out of the head games.
Right now we enjoy the standard of one tire. You know if your buddy is faster than you, its not the tire he is using. Its something else.
I was looking for a simple answer to a simple question, not a smart a** comment from the peanut gallery.
Knowing that VTA will be run at the ROAR paved Nats this summer, another tire may be an option.
Goals Achieved....Running at the End and Not Dead Last.
mooby64 is offline
Old 01-04-2012, 08:55 PM   #13219
Scottrik's Avatar
Trader Rating: 245 (100%+)
Your question was answered, after a fashion.
The reason the alternatively treaded tires have never been approved is not that anyone actually expects there to be any advantage (or disadvantage), but to keep one more potential for PERCEPTION that you're being beaten because you didn't get this tread or that tread. If everyone is running the same exact tire there is no question.
Your question DOES bring up an interesting "challenge" though...ROAR specs the tire by dimensions and that tread must be showing. No other mfr. makes tires to these dimensions but HPI do, in fact, make two different treaded tires that meet ROAR's rules.
That said...all the smoke and hubbub about "ROAR won't go for a single mfr motor or tire" is likely meaningless noise. For YEARS there was a spec (i.e. one particular manufacturer's motor) at big races. Yes, even at ROAR nats. It was usually handled as a "handout motor", but the fact is that single mfr motors have been a fact of life as long as I've been in RC (26 years and counting...). Same with tires...there are "spec tires" at almost any rubber tire event. JACO blues have been the common choice for a few years, now the Sweep 32's seem to be taking over the "spec" duties.
Race organizers are allowed a LOT of latitude for these events, at least as far as Regionals go (our club has never put on a National event). For our Region 11 carpet champs in April we clearly identified that VTA would be run under USVTA rules and there was never a question about it.
Seems like a lot of hue and cry over what is really a non-issue...unless the organizers of the 2012 Nats are trying to rationalize not following USVTA guidelines.
Scottrik
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline
Old 01-04-2012, 08:58 PM   #13220
Simple answer is (not being a smart a**) the rules don't allow them. Longer answer is that choosing one spec tire keeps the field level and even. Costs go up when you have to have multiple tire sets for a single class. Leave tire problems to the tc guys. Besides I have been told that the performance tires wear even faster then the vta tires currently being used. While I am glad that roar has recognized vta I am starting to wonder if this is going to have some very ill side effects such as your tire inquiry. The debate seems like its going to become " well roar says its vta legal so why can't I use it". Keep this class simple guys. Its great as it is. No need to change.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline
Old 01-04-2012, 09:02 PM   #13221
Scottrik's Avatar
Keep in mind that the only reason the ROAR rules are in any REAL substantive way "different" is that they haven't been updated since the change to the current rules (announced two years ago, in place 18 months now). I'm guessing that's one of the items on Rob K's plate now that he's the "electric chairman"...especially since he's the guy who got ROAR to adopt the VTA rules in the first place.
Scottrik is offline
Old 01-04-2012, 09:10 PM   #13222
bigdadracing's Avatar
long time no see scottrik are you guys having your race over in billings mt this year. rummor has it you guys are doing regonals this year .
anywayssorry for hijacking the tread!!!!
rcamerica/xray/ team powers/bsr tires/ slapmaster tools/ bigdads garage/cheep beer/ mykeart paint works / team pop a top
suport your local hobby shop because ebays track is hard to find !!!!!!!!
Russ Jacobson
bigdadracing is offline
Old 01-04-2012, 09:18 PM   #13223
I thought there was something about roar not being brand specific but rather conforming to an outline of equipment specs without regard to manufacturer. Sure roar can write rules to favor a manufacturer but they can't call then out by name.
Don't know if this is true just asking about what I heard.
Serpent S120 13.5
Old 01-04-2012, 09:49 PM   #13224
Bandit17's Avatar
Originally Posted by 414MPH View Post
You are half correct Rob. When I wrote the original VTA rules with Scotty (Trackside Hobbies) in October of 2007, http://www.rctech.net/forum/wisconsi...ing-class.html (Scotrik had the same idea before me), the idea was to just have some fun without all the high tech wiz bang of the day with cool looking vintage cars.
Some people get it, some don't. I like to win as much or more than the other guy, but my philosophy on cheating is:
If I cheat and loose, that means I really suck, and my ego is way too fragile to handle that. Therefore I will never cheat!
After a few months off, I went from one of the top 21.5 VTA guys, to a B main 25.5 VTA guy because I was behind the knowledge curve. I know what it feels like, believe me. Every time I had my butt handed to me, I looked inside to determine what "I" had missed, and every time I found what I missed and what could be done to improve.
In my years of experiences in RC, I found that there is very little rule breaking that goes on and the folks that complain the most about others success have not learned to dig deep to learn to improve the their set-up skills and driving skills to compete. Unless things have changed dramatically since I last turned a wheel, most VTA guys are very willing to share many of there insights on these subjects if someone asked them.
In my experience, I worked and studied hard for years and with the help of others and some luck thrown in I did pretty well racing RC. I found if and when you get to the top you may become the target of the "You Cheat" accusation few. After sharing set-up philosiphies and data, some of the same "You Cheat" folks rejected the facts, rejected the help, kept their special "personal" set-ups, struggled in the back, and kept firing the "Cheater" cause I can't beat you accusations. Others listened and learned and did much better.
There is only one winner at any given race, and I'll bet he works harder than most.
A good friend of mine with 26 motorcycle land speed records has a saying, "The harder you work, the luckier you get". (212 mph on a Sprotster in 1971 was his fastest)
If you keep getting bested, I suggest you bust your but and learn how to catch-up if it is important to you. If you don't want to do that, maybe RobK is correct on both accounts.
Well said Marty! I used to think that everyone was cheating, not so much cheating, but altering equipment to make it faster. So after tons of practice (almost everyday) and the guidance of a great wise teacher (Marty) I started getting better and better. Eventually you'll end up on the other end of it, and feel pretty stupid about the accusation.
My advice: Spend less time wondering what others are doing to cheat, and more time learninghow to make yourself better!
Trackside Hobbies ~ CRC Hobbies
HPI Blitz ~ Custom Works Rocket & Outlaw ~ Tamiya 414M ~ TA05-IFSR
Bandit17 is offline
Old 01-04-2012, 09:56 PM   #13225
[QUOTE=6376vette;10125176]Simple answer is (not being a smart a**) the rules don't allow them. Longer answer is that choosing one spec tire keeps the field level and even. Costs go up when you have to have multiple tire sets for a single class. Leave tire problems to the tc guys. Besides I have been told that the performance tires wear even faster then the vta tires currently being used.
The HPI "performance" vintage tires are the same rubber and cost as the standard HPI vintage tires. They WOULD NOT be a flavor of the week type of tire. I was asking because , at times, the standard tires will be out of stock, while the "performance" tires are sitting on the hobby shop shelf, collecting dust.
I guess my question is now, hey Robk... why do the rules don't allow them?
mooby64 is offline
Old 01-05-2012, 12:00 AM   #13226
CraigMBA's Avatar
We had a similar problem at our last club race before Christmas. Several new racers would of come over to run VTA, but were unable to find front tires anywhere.
If I believe the order status at Tower Hobbies, they will still be on backorder till middle of this month. This isn't a VTA problem per se, but if you can't get the legal tires, you can't race, and that's no good for turnout.
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline
Old 01-05-2012, 12:02 AM   #13227
robk's Avatar
Just for all the reasons above. The original tire works fine, everybody knows exactly what it looks like, so there is no reason to have another tire added to the list.
I don't have any of the "performance" tire to look at, but one thing in the ROAR rules is a tread depth requirement of new tires. I do not know if the performance tire has the same tread depth (.5mm)
Honestly, I have never even bothered to try them simply because there really is no need outside of possible backorder issues you bring up. At the same time, once the three sets are gone off the shelves, the problem is exactly the same. Even if we allowed the second tire, there is no guarantee HPI will not run short on that one too, as it happens with the normal tire.
BTW the performance tire is on backorder at HPi too
robk is offline
Old 01-05-2012, 12:13 AM   #13228
robk's Avatar
HURRY!!!
http://www.stormerhobbies.com/cgi-bi....pl?pn=HPI4793
http://www.stormerhobbies.com/cgi-bi....pl?pn=HPI4797
http://hobbypeople.net/hpi-vintage-r...-compound.html
http://www.ebay.com/itm/HPI-Tamiya-S...item20c0ecf34a
http://www.ebay.com/itm/HPI-Kyosho-S...item2eba720c56
robk is offline
Old 01-05-2012, 12:22 AM   #13229
CraigMBA's Avatar
Easy there, Turbo. I got tires. I'm just letting you know what I heard, and when I went and checked at my preferred vendor, it, well...seemed legit. Our last race was three weeks ago, maybe their shipment hit between now and then.
Don't shoot the messenger!
CraigMBA is offline
Old 01-05-2012, 12:30 AM   #13230
robk's Avatar
I'm not worried about you. Inquiring minds want to know. Darkside is probably upset now that he only has 15 extra sets of tires in his race bag....
robk is offline
Closed Thread
Georgia Vintage Trans Am Racing shadow102 Georgia Racing 725 02-24-2012 09:56 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Thursday Vintage Trans Am racing at Victory in Green Bay Brian F Wisconsin & Illinois Racing 13 05-10-2008 08:37 AM
