Like Tree1Likes
Closed Thread
Old 12-16-2011, 06:52 PM   #13021
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Originally Posted by TeamGoodwrench View Post
Can you post your "road course standard setup" ?
I run Losi, but if I had a TC3, I'd use this to start:
http://www.rcracing.com/David_Goss_T...orlds_1488.cfm
The first thing I would do is run a few laps and then have a helper adjust the left rear shock one round tighter, and then run a few more laps. Repeat as necessary. Once I got the car to handle where I wanted it, I'd put it on my chassis scales and weigh it and write down the corner weights so I'd have a baseline to adjust back to (in case you hurt it or had to take it apart). I race oval so I have scales:
http://www.lefthander-rc.com/catalog...oducts_id=1685
If you don't want to buy or build chassis scales (really, you could get by with just one for the LR tire) you should measure the ride height (all four corners) which will get you fairly close. On my oval car, I do both (check ride height, scale) every time I leave the track so I can make sure I didn't hurt/bend something, and to keep the wedge the same as the tires wear down.
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline
Old 12-16-2011, 06:58 PM   #13022
TeamGoodwrench's Avatar
Thanks .
I don't have a TC3 -- it's a TC4, so it's close
I also need to get a new 2S USVTA-legal LiPo -- what's a good one out there now ?
LEFTHANDER R/C www.lefthander-rc.com
"I've got 4 on the floor and a fifth under the seat"
TeamGoodwrench is offline
Old 12-17-2011, 06:05 AM   #13023
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Thanks .
you can't go wrong with any of the Thunderpower packs, for both price and performance...
I personally like the reedy 35c 5000mah pack - http://www.teamassociated.com/reedy/parts/details/709/ - been using that for a couple of years, and hasn't even had any kind of voltage fade
Bodies By Bean | Team Belly
k_bojar is offline
Old 12-17-2011, 06:06 AM   #13024
k_bojar's Avatar
on a different note...
anyone see these yet??
HOBBYPRO Left Hand Driver Kit HD201L
http://store.hkshobby.com/product_in...oducts_id=9179
the driver actually looks period correct as well
k_bojar is offline
Old 12-17-2011, 06:26 AM   #13025
robk's Avatar
The sweetness..oh yes!!!
robk is offline
Old 12-17-2011, 09:09 AM   #13026
DARKSIDE's Avatar
hey USVTA racers...just giving an update on
The 4th Annual Thunder Jam Championships..(Birds Warm-up)
It will be Sunday Jan 29th, Doors open at 8am
this is a great race for you guys that are going to Snowbirds, and need a good size track and competition to get ready....
its also good for you guys that are not going to make it, and get to have a big race, with alot of competition...
flyer and pics form 1st Thunder Jam posted below...hope you make to the NEW (new carpet and floor) Thunder RC Raceway for this race....
http://www.hobbytalk.com/bbs1/attach...4&d=1319516457
and be on the look out for the 2012 USVTA plus Southern Nationals in Music City,USA coming in Sept
U.S. Vintage Trans-Am Racing-thunder-jam-2009-061.jpg   U.S. Vintage Trans-Am Racing-thunder-jam-2009-064.jpg   U.S. Vintage Trans-Am Racing-thunder-jam-2009-065.jpg   U.S. Vintage Trans-Am Racing-thunder-jam-2009-060.jpg   U.S. Vintage Trans-Am Racing-thunder-jam-2009-005.jpg
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/OTT/1UP
Apex Raceway and Hobbies
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline
Old 12-17-2011, 09:59 AM   #13027
Company Representative
You can add your race reminder here:
TeamNovak Facebook
NovakTwo is offline
Old 12-17-2011, 10:21 AM   #13028
DARKSIDE's Avatar
thank you...I will....also Ill be in contact soon about the 2012 USVTA plus Southern Nationals in Music City, USA...got some things I want to try...
DARKSIDE is offline
Old 12-18-2011, 02:56 AM   #13029
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Is anyone else running a T3 '11 in VTA?
I was working on one today and it seems the outside wheel hits the outside shock shaft ball cup before the inside wheel reaches full throw (when the steering knuckle reaches the c-hub)
I have been running a 009 for a year+ in VTA and I am pretty sure I was able to dial in full lock without rubbing the shock shaft ball cup.
I suppose it has something to do with the change to the dual bell-crank system, but I can't see why. I tried from 0-4 mm of ackerman shims on the inner tie-rod ball studs, but the problem persists.
Any suggestions of things I may be over looking? The car has 0 toe in and 1.5 degrees of front camber...
andrewdoherty is offline
Old 12-18-2011, 10:15 AM   #13030
cherokee95's Avatar
I had a similar issue with my TC5. Try +1mm hexes or even washers. That's all it took on my Associated to get the clearance I needed.
Sioux Falls RC Crawlers
*Futaba*Hitec*Savox*Tekin*Castle Creations*i-Charger*Team Brood*Holmes Hobbies*
~Axial~Tamiya~Locked Up RC~RC4WD~Rogue Element~
cherokee95 is offline
Old 12-18-2011, 10:21 AM   #13031
cherokee95's Avatar
Some more USVTA fun! I actually got my car going. Thanks to Matt and Scott for running the camera.
+ YouTube Video
+ YouTube Video
Old 12-18-2011, 02:41 PM   #13032
GP40X's Avatar
Andrew,
Are you using one hole or two hole front arms? On my T2 007 they are very close to the shock lower spring retainers and I have the shocks in the inner holes. If I go from the inner to the outer hole the wheels will rub. if you have the stock one hole arms, you might try the 302165 2 hole arms with the shocks mounted in the inner bottom arm hole. You also might try the 1.5mm wider front hexes too.
HTH,
Bill
"I used to be disgusted, now I'm just amused."
Team Qik
CustomWorks Outlaw Sprint Car
Xray T3 2012 USVTA
GP40X is offline
Old 12-18-2011, 03:29 PM   #13033
Trader Rating: 24 (100%+)
LORD I love this class ! Had beautiful weather and a great day of club racing.
It was classic VTA...close and controllable.
Winning a race by driving smooth and clean is a thing of beauty.
Evoracer is offline
Old 12-18-2011, 04:56 PM   #13034
jayh50's Avatar
Default worst day racing
I am happy for you, and wish I had the day you had. Yesterday I had probably the worst day ever racing VTA and T/C. I think I hit every wall and other racer at least once until I broke both cars in their respective races, another week or two of racing that bad and I will quit. I am so disgusted with my driving right now!
CUSTOM WORKS GBX2, GBX3, LOSI 22 Buggy, 22 SCT, LOSI 8IGHT E BUGGY.
GO FAST, TURN RIGHT, LEFT, RIGHT, LEFT, OHH CRAP!!!!!!!!!!!!
TURN IT OVER, TURN LEFT, RIGHT, LEFT, RIGHT, LOL
jayh50 is offline
Old 12-18-2011, 05:02 PM   #13035
On the other hand, another week or two of practice and you'll be less likely to hit the walls as much! Don't let the boards get the best of you!
Closed Thread
Georgia Vintage Trans Am Racing shadow102 Georgia Racing 725 02-24-2012 09:56 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Thursday Vintage Trans Am racing at Victory in Green Bay Brian F Wisconsin & Illinois Racing 13 05-10-2008 08:37 AM
