Like Tree1Likes
Closed Thread
Old 11-24-2011, 02:01 AM   #12856
Guest
Default lipos
what is the rule on lipos and can i run the new short 2s lipo in this class???
LOSIRACER77 is offline
Old 11-24-2011, 08:09 AM   #12857
Originally Posted by =FLIP= View Post
Hi here in australia we are having a vta enduro race in a few weeks only problem is tires
where can we purchase the 26mm fron tires and 31 rear???????????????? seems all online shops have no stock and ebay has not many left .
I found some HERE and HERE
Rojna is offline
Old 11-24-2011, 08:38 AM   #12858
MD
MD's Avatar
Trader Rating: 119 (100%+)
Tower has the fronts.
http://www3.towerhobbies.com/cgi-bin...tage&search=Go
RC Shack has both.
http://www.thercshack.com/hpi4793vin...-compound.aspx
http://www.thercshack.com/hpi4793vin...ompound-1.aspx
Hobby People has the fronts.
http://hobbypeople.net/hpi-vintage-r...-compound.html
There are other web sites that show them, but they don't tell if they are in stock and there is also Ebay.
MD is offline
Old 11-24-2011, 10:06 AM   #12859
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Originally Posted by robk View Post
As far as the capacity limit, it's possible that may be changed in the future. Right now, we're going to stand on what we have however.
I race sportsman spec truck on carpet (1s, 17.5 no timing, spec tires) and I see a similar problem. We have a 5000 MAH limit in that class too, but the battery vendors continue to creep the 1c sizes larger and larger. I know the folks at Thunder Power wanted to discontinue the 5000 size once they introduced the 5600 because sales of the smaller capacities dropped to almost zero (the only people buying them are running the spec class, and we don't buy very many).
While it's not a problem now in 2c, I suspect it will be at some time in the future. I would politely suggest that when it does, the capacity limit be lowered so it forced racers to run batteries in the sub 4000 range.
Then again, I may be imagining things that don't/never will exist because vendors must sell an exponentially larger number of 2s batteries compared to 1c.
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline
Old 11-24-2011, 11:39 AM   #12860
R40Victim's Avatar
Wouldn't a lower capacity force people to add weight to make the minimum? Do you want to tell a noob he not only has to buy a specific battery, but also has to add weight to it?
Racing Vids, on and off road:
https://www.youtube.com/channel/UCQMhKKcaJPscYOrsPz8x-lw?view_as=subscriber
R40Victim is offline
Old 11-24-2011, 12:42 PM   #12861
CraigMBA's Avatar
Well...
First, I had to add almost 100 grams to my car to make legal weight, and I have an antique sedan with all steel screws, so I don't see that being any different.
Second, we already are telling noob's they have to run a specific battery. If somebody buys the wrong battery (anything bigger than a 5000) from the hobby shop, what's the difference?
I suggested that the powers that be think about decreasing the battery capacity if they choose to change it. If the object is to run older, but no longer state of the art, carpet gear then the capacity needs to go up at some point, but it doesn't have to increase to keep it in the spirt of the rules.
I'm going to run the class either way.
CraigMBA is offline
Old 11-24-2011, 01:13 PM   #12862
Trader Rating: 77 (100%+)
my two cents.
decreasing the battery capacity will make it that much harder to find batteries to run VTA. it won't be too long before nobody is making sub-5000mah stuff as there just won't be a market for it.
so, my suggestion would be to open the rules to any 2S lipo. we've already established there is no advantage to running a higher-C, higher-mAh lipo; and they are going to be easier and easier to get...so why set the barrier for entry higher than it needs to be?
I race at:
SpeedWorld Raceway
Roseville / Sacramento, California
VTA, 1/10 nitro, touring, USGT, F1, and more!
www.speedworldraceway.com
slashdriver is offline
Old 11-24-2011, 03:13 PM   #12863
R40Victim's Avatar
Originally Posted by slashdriver View Post
my two cents.
My thoughts exactly. It doesnt make sense to limit anything but voltage on the batteries.
Old 11-24-2011, 07:11 PM   #12864
Guest
Default need help
i got an hpi sprint 2 sport with all the graphite chassis and towers, ball diff. i need the right cvds for the front an the rear, the rear is different than the front. i need the correct front cvds for my car, thats all i need for the chassis. i will be run a novak system. and a shorty 2s lipo unless u guys know of a very thin 2s lipo to run cause of the belt clearance.
please help!!!!!!!!
Old 11-24-2011, 08:21 PM   #12865
CraigMBA's Avatar
my two cents.
I think that's a reasonable position too.
CraigMBA is offline
Old 11-24-2011, 09:51 PM   #12866
Guest
please help!!!!!!!!
help me!!!!!
Old 11-24-2011, 10:01 PM   #12867
DesertRat's Avatar
help me!!!!!
To my knowledge the Sprint 2 was made for saddle packs. You can get those in 2s Lipo just about anywhere.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. Losi 22 4.0, CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is online now
Old 11-24-2011, 10:36 PM   #12868
Scottrik's Avatar
Trader Rating: 245 (100%+)
please help!!!!!!!!
If you're hoping for someone to sell you parts (cvd's, etc) your best bet is to post in the "wanted to buy" section.
I was not aware that the cvd's are different front-rear, but that's certainly not unheard of with HPI. The MT2 has marginally different cvd's front and rear.
As far as battery, the Sprint "vintage" Camaro I set up as a demo for our hobby shop it takes a standard 2-cell pack (I've been using an old Orion Carbon 3200) and I've not noticed the belts interfering. The belts DO seem to rub on the motor, but it's more a graze than "rub" and after two race days doesn't seem to be having any effect.
The motor installs in these cars without modifying the aluminum plates (as someone previously mentioned) but it goes in exactly ONE way. If you look at the uprights that support the top plate that are immediately ahead of the motor you'll see that the one on the motor side has a mounting boss that nothing screws into. This same boss on the other side carries the lower front of the motor mounting plate. Pull that upright out and cut that boss off flush with the posts.
Then bend the taps from the motor straight back bending down as close to the endbell side as possible AND making damn sure you make the bends parallel to keep the tabs from touching. Feed the motor in and mount it with the now bent tabs pointing straight forward, solder it up and install the sensor harness.
I installed a 100t spur and 53t pinion (64pitch) to give right at 4.0 FDR and threw a basic touring car alignment on it. The car has run with the factory radio, servo, etc. Handling is EXCELLENT, top speed is a little light but PLENTY fast enough for the rookies that have been driving it. If I was going to race it myself I'd go larger on the pinion a couple steps and see where I got.
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline
Old 11-24-2011, 10:59 PM   #12869
Guest
i was tring to see if anyone has ran in to the cvd problem befor.
Old 11-25-2011, 01:09 AM   #12870
redron123's Avatar
Trader Rating: 87 (99%+)
Anyone else run a xray t3 10 or 11 for vta car? I am ordering new wheels,rubber and i see that hpi has different offsets. I wanted to know which offsets to order and still stay legal? I also wanted know if it would help the car at all or should i stick with the 0 offsets?
check it out ----> www.ddatvinc.weebly.com D & D ATV PARTS INC.
redron123 is offline
Closed Thread
Georgia Vintage Trans Am Racing shadow102 Georgia Racing 725 02-24-2012 09:56 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Thursday Vintage Trans Am racing at Victory in Green Bay Brian F Wisconsin & Illinois Racing 13 05-10-2008 08:37 AM
