Like Tree1Likes
Closed Thread
Old 11-22-2011, 11:47 PM   #12841
R40Victim's Avatar
Originally Posted by LOSIRACER77 View Post
will a hpi sprint 2 be ok for racing vta??
Yup, several people do well with them. The tricky part is gearing when using a 25.5 motor. You basically just need a huge pinion.
Racing Vids, on and off road:
https://www.youtube.com/channel/UCQMhKKcaJPscYOrsPz8x-lw?view_as=subscriber
R40Victim is offline
Old 11-23-2011, 06:25 AM   #12842
jgraham37128's Avatar
Trader Rating: 24 (100%+)
Originally Posted by jdeadman View Post
I race against a couple of guys that have 65C packs in their VTA and I still spank them with my 20C Turnigy's
Yea, I can't say I was ever beat by a guy that has a bigger C rating on their battery. Usually my losses comes with hitting a wall.
JG
jgraham37128 is offline
Old 11-23-2011, 06:33 AM   #12843
Trader Rating: 41 (100%+)
Absolutly, When we are that close in speed and power crashing at all will put you back a few places.
I find that the top 3 guys are a freight train around the track but it gets exciting when the front guy crashes as the 4th or 5th spot can become first really fast.
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline
Old 11-23-2011, 07:07 AM   #12844
Flying Monkey's Avatar
Trader Rating: 54 (100%+)
There was a long debate on this earlier in this thread. A few did testing with different C rating batteries and found no difference due to the amount of draw from the 25.5 motors. Another reason this class is great. As long as the rules are followed its all set up and driver and thats it, keeping racing close and fair.
MONKEY BUSINESS RACING
Flinging poo at a track near you! Winning hearts and minds everywhere!
www.graphicmonkeydesigns.com
Brooksphotodesign.net
Flying Monkey is offline
Old 11-23-2011, 07:51 AM   #12845
beemerfan's Avatar
Trader Rating: 34 (100%+)
Originally Posted by hotrodchevy14 View Post
Not wanting to step on toes but i have a suggestion to the powers that be in vta. There needs to be a limit set on the c rating in this class. The 5000mah limit is fine but I have talked to a few people who feel the racing would get closer if there were a say 50c limit.
C ratings don't matter that much. I did the math once to figure the average amp draw of a VTA car and came up with less than 15 amps or in other words, 3C on a 5000 pack. The only place it's a factor is the momentary surge you need under hard acceleration and I doubt that any of our cars exceed 125 amps or 25C. Point is, if you have at least a 25C 5000 pack, you are competitive. Any more is just throwing $$$ at something that you could better spend on track time for practice and tuning your suspension. I have several 25C packs that are very competitive and have won plenty of races for me. There really isn't a need for a rule here.
P.S. By the time I finished typing this, there are already a half dozen responses echoing the same thing. So yeah, what they said!
beemerfan is offline
Old 11-23-2011, 08:42 AM   #12846
snoopyrc's Avatar
I agree about the C rating, but as time goes by the 5200, 5400 and 6000 + packs are getting cheaper. A local racer recently bought a Revtech 6000 for $60. So not now, but as more of these packs get cheaper and as lower capacity packs get harder to find, I would like to see the mah limit raised. I think the point was to keep expensive packs out. I see no advantage to running a bigger pack when I am only burning out about 1100 mah of power, so it should stay fair no matter what size you run. Or we could go for smaller packs with the same capacity. They would be easier to strap into some of the older cars with room for wieght.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline
Old 11-23-2011, 08:59 AM   #12847
R40Victim's Avatar
Heck... I thought about getting a very small pack. I'm only burning about 650 mah in 5 minutes. Might be worth it to pick up a 1600 or 2200, save some weight. But then you run into balance issues, since most of the older chassis are designed around an old heavy Nimh pack.
Old 11-23-2011, 09:03 AM   #12848
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
but you need to consider the min weight requirement for the class (1550g) - unless your track doesn't follow that so strict.
you might be saving weight with the smaller, ligher pack - but you'll need to make up for the weight loss by other means...Personally, I'd rather have the weight in the pack and use less 'stick-on weights' then use a lighter pack and have to put more weights on my car..
My cyclone TC needed over 100g to meet the min weight, and I think that put me at 1551 or 1552 - legal, but a little too close for my liking...I'm almost afraid what my TCX will need once I finish getting that all setup
Bodies By Bean | Team Belly
k_bojar is offline
Old 11-23-2011, 09:27 AM   #12849
snoopyrc's Avatar
For me the idea of using a smaller pack has nothing to do with saving weight. Its all about realestate, and getting my fat fingers in there with the strapping tape. You still have to use weights, but now you have room for them.
snoopyrc is offline
Old 11-23-2011, 09:46 AM   #12850
I quite enjoy going to a Race and not having to charge at all.
2 qualifyers and a 10 min Main and I only put back 3000 mah into my 5000
Jason Deadman
jdeadman is offline
Old 11-23-2011, 11:32 AM   #12851
snoopyrc's Avatar
Our last race day was four qualifiers and an eight minute main. At a little over 1100 mah per qualifier I cant quite make a full race day on one 5000 pack. Of course we usually only run three qualifiers, but I think that is cutting it pretty close.
snoopyrc is offline
Old 11-23-2011, 11:42 AM   #12852
liljohn1064's Avatar
Trader Rating: 17 (100%+)
We should start a petition to switch it to 10 min heats and 15 min mains for next year. (or some other time variation) Since the battery is no longer a limiting factor, why not? I'd rather race a little longer anyway.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline
Old 11-23-2011, 01:08 PM   #12853
snoopyrc's Avatar
Do it locally and see how it works out. If it does well you might get Rob to take a look at it. I think the length of the race is more of a local format anyway.
snoopyrc is offline
Old 11-23-2011, 01:21 PM   #12854
robk's Avatar
Trader Rating: 22 (100%+)
I think that if longer races work for you, go for it. Really, the race times were set to make people race longer races than what was standard, so why not?
As far as the capacity limit, it's possible that may be changed in the future. Right now, we're going to stand on what we have however.
robk is offline
Old 11-24-2011, 01:37 AM   #12855
=FLIP='s Avatar
Hi here in australia we are having a vta enduro race in a few weeks only problem is tires
where can we purchase the 26mm fron tires and 31 rear???????????????? seems all online shops have no stock and ebay has not many left .
--------------------------HOBBYWING----------PROAMP LIPOS----------------------------
-EAD- Racing NEED SPEED GET SOME EAD-
=FLIP= is offline
Closed Thread
Georgia Vintage Trans Am Racing shadow102 Georgia Racing 725 02-24-2012 09:56 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Thursday Vintage Trans Am racing at Victory in Green Bay Brian F Wisconsin & Illinois Racing 13 05-10-2008 08:37 AM
