Like Tree1Likes
Closed Thread
Old 11-16-2011, 11:26 AM   #12796
wwddww34's Avatar
Trader Rating: 9 (91%+)
Questions?? How can we get a VTA Class at 2012 ROAR Carpet Nationals
Hey Guys, I have a question for all of you. The 2012 ROAR On-Road Carpet Nationals are going to be held at my LHS on Spring Break, March 15-18, 2012. The planners have not solidified all of the classes for the race just yet. Since I am only involved in VTA racing, I would like to see a VTA Class offered at the ROAR Nats. Now depending on who you ask, some people say that there will never be a VTA class at the Nats., and others say that if enough interest is there then there may be a VTA class at the ROAR Nats. So how does a ROAR Planning Committee Member go about gauging interest for a VTA class to determine if there will be VTA offered at the Nats., or not?
wwddww34 is offline
Old 11-16-2011, 12:12 PM   #12797
robk's Avatar
Trader Rating: 22 (100%+)
The Roar guidelines for a national have mandatory classes which must be run, and the track gets a say on an optional class..they have been having a 7th class in a lot of cases.
1.2.3. Required classes are in bold as they are IFMAR classes. The other classes listed are
highly recommended.
1/12th Stock
1/12th Super Stock
1/12th Modified
1/10th Stock
1/10th Super Stock
1/10th Modified
12.2.3 A recommended maximum of six classes may be offered at any single National
event. These classes must be applied for by the Host Club in their bid for the
event, and must be published on all advertising, and on the event entry form.
robk is offline
Old 11-16-2011, 01:34 PM   #12798
wwddww34's Avatar
Questions??
Robk, does this mean that a ROAR On-Road Carpet Nats. event is more than likely not going to have a VTA class?
wwddww34 is offline
Old 11-16-2011, 02:06 PM   #12799
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
it may or may not - if the host track wants to offer it as an optional/exhibition class, then ROAR will allow it...if not, then there won't be a class
VTA is not a permanent class at ROAR nationals...matter of fact, its only been offered at 2 nationals - with Jackson, NJ being the most recent
also remember, ROAR specs for VTA is different then that of USVTA
Bodies By Bean | Team Belly
k_bojar is offline
Old 11-16-2011, 03:09 PM   #12800
wwddww34's Avatar
Lightbulb
Ahh, so there is a chance that VTA could be offered as an optional/exhibition class at the 2012 ROAR Nationals if the host track is willing to do it.
wwddww34 is offline
Old 11-16-2011, 05:36 PM   #12801
GP40X's Avatar
David,
We will need to talk to Mike and Andrew as a group (All of the local VTA drivers) about a VTA class since it is an exhibition class. Also see if Mike can get a hold of Gary O Brien (our region 9 ROAR rep) to see what is necessary for adding an Exhibition class to a Nationals race. Hopefully ROAR will add 25.5 with no FDR to the current motor and battery rule set (allow both 21.5 with a 4.2-4.6 FDR & 25.5 with no FDR limit at level 3, 4, & 5 events). Otherwise I see a Trinity D3 21.5 in my future (will be mainly for a USGT fun car but will go into my VTA for ROAR rule VTA events only). And remember "NO Sharpies"!
Bill
"I used to be disgusted, now I'm just amused."
Team Qik
CustomWorks Outlaw Sprint Car
Xray T3 2012 USVTA
GP40X is offline
Old 11-19-2011, 02:22 AM   #12802
snoopyrc's Avatar
If a racer can have a VTA car and a USGT car using the same kind of chassis, or at least something with the same post hole locations, then it would become fairly easy to just swap your VTA wheels and body to your USGT ride for running ROAR VTA. Unless I am overlooking something. I guess its not that big of a deal to just keep the extra motor in the box, but if you run USGT then you will already be comfortable with your gearing and setup for that motor.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline
Old 11-19-2011, 10:49 AM   #12803
GP40X's Avatar
The plan right now is to pick up another T2 007 for parts compatibility and set it up for USGT just for fun (we are not running USGT at our local track at this time). I plan on getting a EU spec car to go with the US spec car I currently have and use them interchangeably depending on the track I am running at. If that does not pan out, I just may pick up an Exotek XR07 Lipo chassis for my VTA car and swap motors depending on the race I am running at (I will usually only run one class at a race).
Bill
Team Qik
Xray T3 2012 USVTA
GP40X is offline
Old 11-19-2011, 11:08 AM   #12804
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
Here's a pic of the top 9 from the VTA Race during the 5th Annual Fall Classic at Mike's Hobby Shop on Nov. 13, 2011.
Hay I know those guys . Lol wonder who won? Lol
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline
Old 11-19-2011, 04:05 PM   #12805
snoopyrc's Avatar
Our local track is 80%VTA with a little left over for some TC and F1. I have a handful of people that would start USGT here if we could do it. So far the only time I can get enough for a heat is with larger races that call for out of towners.
I never understood the differrences between the US and EU spec. Is the US better on carpet?
snoopyrc is offline
Old 11-19-2011, 05:33 PM   #12806
Regional Moderator
CarbonJoe's Avatar
The US spec was designed for foam tires. It has a thicker chassis than the EU, and has two ball diffs instead a diff and a spool. Usually harder arms as well.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline
Old 11-19-2011, 05:59 PM   #12807
GP40X's Avatar
LOL Congratulations Justin. Hope you make it to the warm up race for the Carpet Nationals in late January/early February.
Bill
Team Qik
Xray T3 2012 USVTA
GP40X is offline
Old 11-19-2011, 06:39 PM   #12808
snoopyrc's Avatar
See I'm running VTA on Asphalt so I would want the thinner plate, but I would want the spool and diff.
snoopyrc is offline
Old 11-19-2011, 11:22 PM   #12809
I hope that someone from USVTA is on this thread and can help me clear up something.
Tonight I went to our local rc track and someone showed up racing with either a Pegasus or HPI 1970 Mustang body with a large touring car wing on the back. I didn't get close enough to it to confirm which brand of body it was. I pointed out to one of the racers that the wing was illegal according to USVTA rules. I was told that since it came with the body that it is legal.
Who is right? The way I read the rules, only decklid spoilers and scale wings are allowed. The wing on this body was NOT scale!
Team Lotus is offline
Old 11-19-2011, 11:29 PM   #12810
cherokee95's Avatar
The HPI comes with a deck spoiler and a wing, but only the deck spoiler is legal.
"Body provided deck lid spoilers allowed (not wings)."
Sioux Falls RC Crawlers
*Futaba*Hitec*Savox*Tekin*Castle Creations*i-Charger*Team Brood*Holmes Hobbies*
~Axial~Tamiya~Locked Up RC~RC4WD~Rogue Element~
cherokee95 is offline
Closed Thread
Georgia Vintage Trans Am Racing shadow102 Georgia Racing 725 02-24-2012 09:56 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Thursday Vintage Trans Am racing at Victory in Green Bay Brian F Wisconsin & Illinois Racing 13 05-10-2008 08:37 AM
