Like Tree1Likes
Closed Thread
Old 06-30-2011, 08:17 PM   #11941
Trader Rating: 48 (93%+)
Originally Posted by Flying Monkey View Post
If im not mistaken, the 2 combinations are the same IF you end up with same FDR. The way it was explained to me is FDR is FDR is FDR lol. Someone please correct me if im wrong.
Not Sure. I know with a Bigger Spur Smaller Pin You Will Have More Tourq of the line thats why i was asking if there was a Diffrance. Guess That would be the only diff.
tcb22185 is offline
Old 06-30-2011, 11:55 PM   #11942
Scottrik's Avatar
Trader Rating: 245 (100%+)
Bzzzzzzt. No.
If you end up with the same ratio regardless spur size and/or pinion size you have the same torque multiplication.
Spur Pinion Ratio
20 10 2:1
30 15 2:1
40 20 2:1
100 50 2:1
Etc.
Where you get "increased torque off the line" is if you DECREASE pinion size relative to the spur gear OR if you INCREASE the spur gear relative to the pinion. In both cases you alter the gear ratio to a higher numerical ratio. Otherwise, same ratio same torque off the line with (possibly, more theoretical than measureable) efficiency trade offs at some extremes of either.
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline
Old 07-01-2011, 12:08 AM   #11943
looper's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to looper
with the same fdr but with different primary gears i could see a miniscule benefit to using larger gears to get the same ratio only because they would mesh cleaner without an abrupt sliding into mesh. 100/50 would mesh alot cleaner than say a 24/12. there would be almost immeasurable performance gain but the larger gears would last longer due to the smoother introduction to each other.
Looped Designs Paintwerks
http://ldpaint.webs.com/ Email: [email protected]
looper is offline
Old 07-01-2011, 12:54 AM   #11944
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Originally Posted by Scottrik View Post
Bzzzzzzt. No.
Spur Pinion Ratio
20 10 2:1
30 15 2:1
40 20 2:1
100 50 2:1
Etc.
Yup. The motor just sees a number. There are differences in F/R weight balance though with different combinations to achieve the same ratio because the motor will move fore/aft. This is a pretty small change in my experience though and not worth me worrying about it.
andrewdoherty is offline
Old 07-01-2011, 01:19 AM   #11945
R/C Tech Charter Subscriber
Trader Rating: 30 (100%+)
I remember years ago running a larger spur on my RC10's in the stock classes. I'am no engineer but it had something to do with the larger spur creating more leverage to the top shaft of the tranny.
Lowrance is offline
Old 07-01-2011, 06:42 AM   #11946
pejota's Avatar
All good points, but back in the day the numerical difference between spur and pinion is greater with the brushed motors compared to today's brushless motors.
The old TC3 manual recommends a 6.43 FDR with a stock motor. Today we're trying to hit an FDR of 4.0.
100/39 and and 88/34 are pretty close to the 6.43
For today's 25.5 you would need a 100/62 or a 88/55, but good luck fitting a 100/62.
(64 pitch gears)
pejota is offline
Old 07-01-2011, 07:51 AM   #11947
wwddww34's Avatar
Trader Rating: 9 (91%+)
Here's a video of the 2nd Qualifier from Thursday's VTA Race at Mike's Hobby Shop in Carrollton, TX.
http://www.youtube.com/watch?v=Sj-eg0OWvMs
wwddww34 is offline
Old 07-01-2011, 10:52 AM   #11948
(link deleted because I don't have enough posts)
Wow. As someone thinking about getting back into R/C cars, I gotta say this looks AWESOME. And from everything I've read, it really does appear accessible to novices. Gotta jump in and ask 2 questions:
1. I was recently given an old TL-01 that seems to run pretty well, essentially for free. Does anyone run these in this class? Not looking to challenge the leaders or anything, but I want to at least be able to fulfill my role as lap traffic...
2. Anyone know of any VTA racing going on in southern central PA? Essentially from Harrisburg on south to the MD state line? I'm in Chambersburg, FWIW...
thanks...
--rick
ParkRNDL is offline
Old 07-01-2011, 11:32 AM   #11949
nashrcracer's Avatar
(64 pitch gears)
Bzzzzzzt. No.
Spur Pinion Ratio
20 10 2:1
30 15 2:1
40 20 2:1
100 50 2:1
Etc.
Guys How are you Geting your FDR? Small Spur Big Pin OR Bigger Spur Smaller Pin?
along with all this there is the dynamic of rotating mass smaller pinion spur quicker acceleration larger pinion spur combo more speed through corners with the push effect of the rotation.
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline
Old 07-01-2011, 01:20 PM   #11950
pejota's Avatar
My head just exploded. Dang.
pejota is offline
Old 07-01-2011, 06:33 PM   #11951
Trader Rating: 24 (100%+)
thanks...
--rick
Glad to see you have an interest in the best class in RC !!
Sadly the TL01 may not be a reasonable choice for racing these days. Parts supply may be a bit difficult, the limited gear ratios available (because of the motor mount) would make it difficult at best, the overall handling of the TL01 has been FAR eclipsed by even very basic chassis these days.
Bottom line....it would be hard to justify sinking money into it in order to make it remotely usable.
There are LOTS of good used chassis out there. As for new...the Schumacher MI1 is one of my favorites.(165 bucks brand new ! ). The new Kyosho TF5S is reasonable also. (200 bucks at my local Hobbytown).
Welcome to our addiction !! Have Fun !!
Evoracer is offline
Old 07-01-2011, 08:04 PM   #11952
snoopyrc's Avatar
Originally Posted by robk View Post
TC spec has dynamic timing, Comp 07 has dynamic timing. As far as I know the only one that did not have dynamic timing was the original Sphere, but that was never confirmed.
Just ordered a Goose for a USGT car, but I would have used a sphere if I thought it was ok. It's laying around now.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline
Old 07-01-2011, 08:23 PM   #11953
BMenard17's Avatar
Trader Rating: 88 (99%+)
I dont think I seen 1 clean pass in the entire race.
Tekno R/C-Sweep racing tires-Rc addiction products
Lead finger racing-Hobbico-OS engines-Futaba-Odonnell
BMenard17 is offline
Old 07-01-2011, 09:04 PM   #11954
Actually there were some pretty "gentlemanly" passes and some good sportsmanship shown. I believe this group is fairly new and I'm not sure of the skill level of all the drivers but I must applaud the effort. You guy's at Mikes are doing well. Keeping the enthusiasm up is hard but you folks seem to have a lot of spirit. Keep it up !!
Evoracer is offline
Old 07-01-2011, 11:20 PM   #11955
looper's Avatar
Thanks dude!
alot of us are new at the 1/10th onroad and there are some much more experienced in the group as well.. me for instance went to vta from nitro 1/8th scale offroad.
looper is offline
Closed Thread
Georgia Vintage Trans Am Racing shadow102 Georgia Racing 725 02-24-2012 09:56 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Thursday Vintage Trans Am racing at Victory in Green Bay Brian F Wisconsin & Illinois Racing 13 05-10-2008 08:37 AM
