U.S. Vintage Trans-Am Racing >
Like Tree1Likes
Old 06-06-2011, 03:34 PM
  #11776
rednck21's Avatar
Trader Rating: 106 (100%+)
Originally Posted by byohnd
anyone have a good vta starting setup for a tc6?
anyone? id like to hear a good starting point too...
rednck21 is offline
Old 06-06-2011, 04:04 PM
  #11777
squarehead's Avatar
Trader Rating: 75 (100%+)
Like most chassis, for VTA, the best suggestion for setups is to run the baseline stock rubber setup form the manual, or whatever baseline "Team" rubber setup is preferred. There is no magic setup for VTA—most guys are running some subtle variation of the stock kit rubber tire setup, then tuning it to their own driving style and preferences.
squarehead is offline
Old 06-06-2011, 04:44 PM
  #11778
Scottrik's Avatar
Trader Rating: 261 (100%+)
+1000
That is EXACTLY where to start, then dial it in to your driving style and track specifics as Doug indicates.
DO YOURSELF THE BIGGEST FAVOR POSSIBLE, invest a whopping $15 (approximately one entry fee most places) in the XXX-Main chassis setup book and read it/use it. It is, bar none, the best spent money for going faster you can throw down. Helps sort out what causes what, etc, as you're dialing the car in. The time you'll save (and speed you'll gain) by NOT "following the herd" or following well-intentioned but equally inaccurate anecdotal information is immeasurable.
THAT is the VTA "hot setup" for any and every chassis
Scottrik is offline
Old 06-06-2011, 05:23 PM
  #11779
robk's Avatar
Trader Rating: 22 (100%+)
Rules fixed for Challenger
robk is offline
Old 06-06-2011, 05:27 PM
  #11780
robk's Avatar
Originally Posted by gofasteddy
little help please, on the front tire how low can I go before it is not legal? I notice my inside front tire goes much faster than the outer and was told as long as I have at least 2-3 lines of treads left I am good, is that a fact?
This is not a hard and fast rule. A lot of tracks/races require at least half front tread at the start of the day. The idea is to keep people from running slicks. Most asphalt tracks around here don't get on people too much because the tires do wear much more on asphalt, and a lot of guys save the old tires from the carpet season for outdoors.
robk is offline
Old 06-06-2011, 05:28 PM
  #11781
DARKSIDE's Avatar
thank you
DARKSIDE is offline
Old 06-06-2011, 05:30 PM
  #11782
Flying Monkey's Avatar
Trader Rating: 54 (100%+)
hmmmm i may have to think about changing brands for VTA lol
Flying Monkey is offline
Old 06-07-2011, 08:46 AM
  #11783
DARKSIDE's Avatar
Im painting mine now...
DARKSIDE is offline
Old 06-07-2011, 04:13 PM
  #11784
How are you guys gearing cyclone tc's? My son has a 109t spur and according to the fdr sheet I need a 66t pinion lol to get a 4.0 fdr. All the HB spurs are really high...think lowest I found was 104t. With it having a 2.4 internal im having a hard time finding a combo to get me at a 4.0 on his car.
Im also curious if I can use a spur from my tc5 in his cyclone.
Old 06-07-2011, 04:49 PM
  #11785
Trader Rating: 24 (100%+)
You can use spur gears from any number of manufacturers. Try Robinson Racing. www.robinsonracing.com. And you ARE familiar with www.gearchart.com, aren't you ??
Evoracer is offline
  #11786
R/C Tech Elite Member
JayL's Avatar
1. it can use regular pan can spurs
2. http://www.amainhobbies.com/advanced...&keywords=spur
whole page of hotbodies spurs with small numbers
JayL is offline
Old 06-07-2011, 05:00 PM
  #11787
thank you. Im not sure what pan can spurs are. I have a few here for my tc5 ill try to see if they match. if not ill order 1 form that list you posted.
Old 06-07-2011, 05:03 PM
  #11788
ive just been using the 1 i got through the VTA site. But that 1 seems to have more options to use. thank you.
Old 06-07-2011, 06:46 PM
  #11789
nashrcracer's Avatar
Trans AM race starts at 6:30 minutes in
the Imsa GTO GTU race starts at 21 minutes in (that's 17.5 21.5 together last week I ran a 10.5 in GTP )
http://www.ustream.tv/recorded/15194565
nashrcracer is offline
Old 06-07-2011, 07:29 PM
  #11790
rcko's Avatar
Trader Rating: 15 (100%+)
monkey I have two pan car styled spur gears that wont fit my xray you can have. I think it is a 116 and a 110. If they fit your car you can have them. I will be at hotshots on Wed
rcko is offline
