Like Tree1Likes
Closed Thread
Old 05-20-2011, 10:41 AM   #11566
Flying Monkey's Avatar
Trader Rating: 54 (100%+)
How does the SS and Ballistic compare? I have a Ballistic in my VTA car but Im needing to buy 2 more set ups for my sons. Was looking at the SS motors to save a little $$ but dont want them to be at a disadvantage.
MONKEY BUSINESS RACING
Flinging poo at a track near you! Winning hearts and minds everywhere!
www.graphicmonkeydesigns.com
Brooksphotodesign.net
Flying Monkey is offline
Old 05-20-2011, 10:55 AM   #11567
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Identical motors, performance-wise. The Ballistic is nice because it is fully rebuildable, and it does have removable sensor wires, which I find to be worth it by itself. Plus, with a $35 stator in, you can change the 25.5 to be a 21.5 if you wanted to do a different spec class (or any other motor wind you want).
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline
Old 05-20-2011, 11:31 AM   #11568
good deal thank you
Old 05-20-2011, 11:37 AM   #11569
Trader Rating: 77 (100%+)
Originally Posted by slashdriver View Post
I'm working on setting up a TC3 as a spare/loaner VTA car, have a few questions for the TC3 wizards.
1) I have the composite plastic shocks, which I've installed the VCS2 upgrade kit on, and I am using a rear shock tower on the front per the more modern TC3 setup sheets.
I'm running into an issue where the shocks are just too long, especially on the front. I had to shim the front shock tower up 3mm AND take the uptravel limiters off the shock shaft (the VCS2 kit says these are required to prevent the piston from hitting the bladder) just to get enough uptravel to be able to push the chassis of the car flat to the ground. I had to remove the uptravel limiters on the rear as well. The pistons don't seem to hit the bladders, but the uptravel is still quite limited because the shocks don't compress short enough (the bottom spring retainer hits the bottom of the shock body and that's the shortest they can get).
Do the aluminum/factory/FT shock bodies compress shorter, or are they the same?
2) any tips on being able to run the diffs looser than the manual setting without having them slip obnoxiously? They are extremely tight compared to what I"m used to on other more modern TC chassis, and even when they are tight they slip.
slashdriver is offline
Old 05-20-2011, 02:15 PM   #11570
texastc's Avatar
Like davidw said we are about 50/50 SS to ballistic on our track at Mikes, we are all about same speed. I run an SS and I have a bit more speed at the end of a straight than a guy with a ballistic but we are also geared different ever so slightly. But all in all I'd say they are pretty equal.
Exotek F1Ultra Tamiya TRF101 Speed Passion SP1 and Exotek F1UltraX Prototype.
"TexasTC, the single Greatest RCF1 racer I have ever known" - My mom
"you are a disgrace to RC" - everyone else. TCdoesRC
texastc is offline
Old 05-20-2011, 04:34 PM   #11571
squarehead's Avatar
Novak has stated that they are all absolutely identical. Any speed differences in motor types is in gearing/timing differences, and nothing else.
Everything depends.
Nothing is always.
Old 05-20-2011, 04:39 PM   #11572
GasGod's Avatar
^^+1 I have a ballistic and it's not any faster.
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline
Old 05-20-2011, 04:51 PM   #11573
DARKSIDE's Avatar
I ran the Goose 25.5 reman and its just as fast as my Havok Ballastic...
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/OTT/1UP
Apex Raceway and Hobbies
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline
Old 05-20-2011, 05:13 PM   #11574
Chaz955i's Avatar
Try a TC3 thread.
At The Gate Bizzos
Chaz955i is offline
Old 05-23-2011, 09:09 AM   #11575
Trader Rating: 32 (97%+)
What kind of gearing are the guys that are using a tc4 chassis in USGT running? Im assuming you all have made the jump to 64 pitch?
Hotshot Rc Raceway
kikcaffine is offline
Old 05-23-2011, 09:45 AM   #11576
wwddww34's Avatar
Trader Rating: 9 (91%+)
Thumbs up
Here's a pic of the VTA Line-up at last Saturday's race in Mike's Hobby Shop...
wwddww34 is offline
Old 05-23-2011, 09:55 AM   #11577
Default Suspention help
We have built a couple of VTA cars on Xray 007 platform,need to know a starting point for shock piston,shock oil weight,and springs.We will be running on carpet.Any help will be appreciated.
TWILL is offline
Old 05-23-2011, 01:44 PM   #11578
Trader Rating: 24 (100%+)
Unless a driver who has a 007 jumps on here with a good setup, it's always best to start with the "box stock" setup for the car. Do you have the original included setup sheet?? If not, I'll bet the stock setup is available on XRay's website.
looked it up for you...maybe this link can help:
http://forum.teamxray.com/xsheets.ph...d48855c3de591e
Evoracer is offline
Old 05-23-2011, 03:41 PM   #11579
multi-bash's Avatar
Originally Posted by Evoracer View Post
Don't panic ! They're talking about USGT ...not VTA.
Its driving me nuts. Indoor around here is VTA, while outdoor is USGT...
My wife is isn't going to understand if she sees I have three motors for my on-road car (drift, VTA, USGT)...
Raincity Raji Kon - hit me up to drift in the 206/425 -- RWD W.U.N. Nervis 2.0, RWD dlike RE-R Hybrid, RWD Sakura D4, 50:50 StreetJam OTA-R31, Slash 4x4, Slash 2wd, Subaru Brat Scaler, Emaxx dual brushed motors lol
WTT: my HPI MRS4 with exotex and more
multi-bash is offline
Old 05-23-2011, 04:00 PM   #11580
nashrcracer's Avatar
Funny Enough I had real good luck with Drew Ellis 2006 roar pave nats setup on my 006 xray on carpet with 21.5 vta should be good to go with a little less rear toe to start.
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline
Closed Thread
Georgia Vintage Trans Am Racing shadow102 Georgia Racing 725 02-24-2012 09:56 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Thursday Vintage Trans Am racing at Victory in Green Bay Brian F Wisconsin & Illinois Racing 13 05-10-2008 08:37 AM
