Like Tree1Likes
Closed Thread
Old 05-02-2011, 11:43 PM   #11386
texastc's Avatar
he was taking it easy on us. We are harder to pass when we're sideways and rolling over.
texastc is offline
Old 05-02-2011, 11:52 PM   #11387
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
LOl, y'all are killing me !
Bullwinkle, you won't recognize our track next time you come. TONS of new additions and improvements. Mike has invested thousands in a new scoring booth with A/C, new speaker system, monitors, flat screens, etc. I know where i will be ALL summer!!
andrewdoherty is offline
Old 05-03-2011, 12:15 AM   #11388
bigbank66's Avatar
Fellow vta drivers....am i the only one running a hpi sprint2 in this class??? i had so much fun running this class that i want to race it more...please if anyone has a setup for the car let me know....im having trouble wit the rear being loose off throttle in turns...all help accepted...thanks..
bigbank66 is offline
Old 05-03-2011, 12:45 AM   #11389
wwddww34's Avatar
Trader Rating: 9 (91%+)
Here is a series of close-up pics of all 6 VTA cars that raced at Mike's Hobby Shop last Sunday.
wwddww34 is offline
Old 05-03-2011, 01:01 AM   #11390
Here are some general suggestions for an off-power over steer condition
Less rear droop (down to ~1 mm of up-travel min)
Move front and rear arms back
Move any static weight you have towards the front
Less front camber
More rear camber (up to ~2.5* max)
More rear toe in (up to ~3.0* max)
Sauce less of the front tires
Also be sure your tires are cleaned after coming off the track each time. They can glaze over causing a radical loss of traction. Of course also be on the look out for broken/bent/mal-adjusted components of the car. A seized bearing can make a car do what you're describing as well.
Old 05-03-2011, 03:57 AM   #11391
IndyHobbies.com's Avatar
Here's a VTA line up at R/CAR in Indy a while ago. Ready to Rock!
www.rcarindy.com
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
Member Hoosier RC Racers club - www.HRCRacers.com
USVTA #144
IndyHobbies.com is offline
Old 05-03-2011, 07:55 AM   #11392
2xs
Move front and rear arms back Can't move the arms on the S2S
Move any static weight you have towards the frontThe S2S is very rear heavy. I would start with 3 weights under the front diff and place the rest down the center line of the chassis between the steering post and the battery
Less front camber
Also be sure your tires are cleaned after coming off the track each time. They can glaze over causing a radical loss of traction.X2 Of course also be on the look out for broken/bent/mal-adjusted components of the car. A seized bearing can make a car do what you're describing as well.
Added to Andrew's
2xs is offline
Old 05-03-2011, 08:37 AM   #11393
Trader Rating: 41 (100%+)
Also The oils in your shocks may be too soft as too much weight is transfered to the front off power. If you have drag brake on that kind of thing
To test just slow down before the corner and using throttle ( not full) enter the corner and slowly accelerate if it holds the rear then you have way too much rear weight. also we have found that a technical track likes weight
Some of the older cars like to be run at up to 1650g but most of that weight is forward and as low as possible. For my TC4 I actually put about 60g in the front bumper just on the bumper mount where I ground out some of the bumper material and put it in there.
Also of your rear diff is sticking at all that can cause it as well. we run our front diffs tight and the rear ones as loose and free as possible but with no slipping.
what we find is the inside rear tire will lift on hard corners and deceleration and that will let the diff spool off the excess so the outside tire does not spin or slip.
jdeadman is offline
Old 05-03-2011, 09:18 AM   #11394
wwddww34's Avatar
Hey guys, my wife created an online photo and video album just for VTA racing at Mike's Hobby Shop in Carrollton, TX.
So if you want to see some cool VTA pics and video from last weekend's VTA race then go here...
http://web.me.com/klbwalker/mvtarc
You will see the links for Photos and Videos at the top of the page. Right now there is only one video to watch and I will get the other videos loaded up later today or tomorrow.
wwddww34 is offline
Old 05-03-2011, 12:56 PM   #11395
Here's a video of VTA racing at RCAR in Indy. The website has changed. Its now www.RCARINDY.com
+ YouTube Video
USVTA #144
Old 05-03-2011, 08:40 PM   #11396
DARKSIDE's Avatar
here are some of our line ups
U.S. Vintage Trans-Am Racing-thunder-jam-2009-061.jpg   U.S. Vintage Trans-Am Racing-wed-night-ta.jpg   U.S. Vintage Trans-Am Racing-r2008_jul_20_006.jpg   U.S. Vintage Trans-Am Racing-2008_jul_20_004.jpg
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/OTT/1UP
Apex Raceway and Hobbies
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline
Old 05-03-2011, 08:56 PM   #11397
bigbank66's Avatar
Thanks fellas ill make some adjustments an let u know whats works....thanks for all your help....
Old 05-04-2011, 01:26 AM   #11398
wwddww34's Avatar
There was some dirty racing going on....
wwddww34 is offline
Old 05-04-2011, 01:31 AM   #11399
texastc's Avatar
Attachment 747352
Got me.
texastc is offline
Old 05-04-2011, 01:39 AM   #11400
wwddww34's Avatar
Does anybody on this forum know somebody who works for HPI Racing? I would like to ship this 1972 Pontiac Trans Am Firebird to HPI Racing so that they could make a Lexan body of it for VTA enthusiasts all around the world.
wwddww34 is offline
Closed Thread
Georgia Vintage Trans Am Racing shadow102 Georgia Racing 725 02-24-2012 09:56 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Thursday Vintage Trans Am racing at Victory in Green Bay Brian F Wisconsin & Illinois Racing 13 05-10-2008 08:37 AM
