Like Tree1Likes
Closed Thread
Old 03-04-2011, 12:55 PM   #10831
CSeils's Avatar
Trader Rating: 48 (100%+)
USVTA logo decals.
Thanks to Doug from Squarehead Designs for the layout.
Printed on Clear Vinyl. Red, White and Blue.
$8 per sheet.
Also, check out : http://www.rctech.net/forum/r-c-item...am-decals.html for more VTA decals.
If interested, send me an e-mail @ c[email protected]
Thanks.
Carl
You can never go wrong with a Hooters Mini. But Mini Hooters are bad.
--- USVTA National Points Series Member #122 ---
[email protected] - http://www.rctech.net/forum/painting-designs-graphics-photography/279695-usvta-trans-am-decals.html
CSeils is offline
Old 03-04-2011, 01:12 PM   #10832
IndyRC_Racer's Avatar
Originally Posted by CSeils View Post
Doug, thanks for the hint. I have 25,000+ font installed in my computer at work. I try not to memorize them all.
I do have that font though.
Good thing you aren't running on a old Windows computer or all those fonts would have used up your available memory. (I'm an IT nerd )
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline
Old 03-04-2011, 05:10 PM   #10833
Thanks for that!!
I'll try and get you an order over the weekend that will include #'s 67 in the that font with the bolder type.
Thanks again,
Lynn
Tamyia Cobra R Mustang TA02, HPI Sprint2 Sport, Super Clod Buster, Twin Detonator, AE B4.1, RC10 Gold Pan (mine)
Tamiya Super Clod Buster, Blackfoot Extreme, HPI Sprint2 Sport (My boy's)
CobraRman is offline
Old 03-05-2011, 01:26 PM   #10834
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
For USGT - is there a battery limit? Max mah?? Or just any roar approved battery pack?
Bodies By Bean | Team Belly
k_bojar is offline
Old 03-05-2011, 01:50 PM   #10835
Trader Rating: 14 (100%+)
I have a set of VTA tires i bought for the first USVTA nats. I ran them at the second one and took a few years off. They've been stored in the closet but not in a plastic bag. They have plenty of tread left but feel a bit dry. Should I pick up a fresh set for this year's nats?
thunderbt3 is offline
Old 03-05-2011, 02:02 PM   #10836
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Just get some traction compound in them and run them a few times. Older tires typically are a bit better.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline
Old 03-05-2011, 04:46 PM   #10837
DARKSIDE's Avatar
USGT Class Rules and Specifications
Chassis Specification:
Any 1/10 4wd or Fwd sedan with 4 wheel independent suspension.
Weight Specification:
4wd 1450g weight Fwd 1400g weight
Body Specifications:
Any 190mm or 200mm body. Body can be any body that is NOT on the ROAR T2 body list. NO Trucks
Any "SCALE" molded wings can be used. Lexan wings 10mm maximum height / side dam height
Scale type race liveries encouraged
Tire & Wheel Specifications:
Tires-Any treaded (non slick) non belted rubber tire available 24 or 26mm. Removing belts from belted tires is not allowed. Must used a non-molded (ex. open cell foam) insert or no insert. Grinding of tire tread is NOT permitted. Sanding of mold seam to remove seam is allowed.
Wheels- Any 24 or 26mm spoke (non-dish) type wheel
Ride Height Specification:
Minimum ride height is 5mm.
Motor Specifications:
21.5 + 2s lipo batteries No tuning rotors, must use OEM rotor 12.3-12.5mm
Approved ESCs:
ESC ROAR approved spec software or USVTA list
Race Specification:
6 minute qualifiers
8 minute mains
Battery Specifications:
ROAR approved hard case batteries
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/OTT/1UP
Apex Raceway and Hobbies
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline
Old 03-05-2011, 04:51 PM   #10838
k_bojar's Avatar
Saw all that, but is there a limit like usvta?? Or could i run a 5400 pack?
Approved ESCs:
Race Specification:
6 minute qualifiers
8 minute mains
k_bojar is offline
Old 03-05-2011, 04:54 PM   #10839
DARKSIDE's Avatar
humm...I would say its ok, due to Rob being very specific with the rules....but wait for him to chime in on here or USGT...Im running 5000 Reedy for both classes
DARKSIDE is offline
Old 03-05-2011, 07:38 PM   #10840
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
As far as what was written into the rules and talked about its any ROAR approved 2cell lipo for USGT.....VTA has the 5000mah Cap. Not that you really need anything more then a 3800 really....but its there if you want it.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline
Old 03-06-2011, 01:39 AM   #10841
ed517's Avatar
ran my first VTA race, super fun, has the novak 25.5 epoxy stator been added to the approved list for this class.
ed517 is offline
Old 03-07-2011, 08:15 AM   #10842
snoopyrc's Avatar
Huh? If it says Novak and 25.5, I am pretty sure its legal.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline
Old 03-07-2011, 08:51 AM   #10843
speedybill's Avatar
Trader Rating: 73 (100%+)
Cool
Our Local race track [OVRCCC] has adjusted our VTA requirments to allow the racers an easier way to keep racing
Saturday we had 9 VTA racers and we ran the ALL in the Main
Currently we allow 21.5, and the VTA required Speedo's
NO gear ratio limit,
We are discussing the possibly of allowing ROAR "TC SPEC" speedos
our racers feel they are very limited in Speedos so they are in favor of allowing more speedos in VTA as long as they meet the 'Blinky mode'
Now let the beatings begin!!
ROAR member #5-120259
www.speedybillsrc.com
www.ovrccc.com
Sweep Racing Tires
speedybill is offline
Old 03-07-2011, 09:24 AM   #10844
Trader Rating: 24 (100%+)
You are the devil and will burn in hell !! Is that beating enough !!??
It's still basically VTA and I'm assuming none of your racers plan on being part of a VTA sanctioned race nor is the club planning on promoting a sanctioned event.
I am curious though. "To allow the racers an easier way to keep racing"...What does that mean ?? I'm guessing EVERYBODY already has 21.5 motors?? Just a reminder and something you may not have thought about. As the speed increases, certain costs due to wear will increase exponentially. Tires in particular will wear out much faster and therefore each racer will spend more in the long run.
Evoracer is offline
Old 03-07-2011, 01:50 PM   #10845
DARKSIDE's Avatar
This thread too
DARKSIDE is offline
Closed Thread
Georgia Vintage Trans Am Racing shadow102 Georgia Racing 725 02-24-2012 09:56 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Thursday Vintage Trans Am racing at Victory in Green Bay Brian F Wisconsin & Illinois Racing 13 05-10-2008 08:37 AM
