Like Tree1Likes
Closed Thread
Old 03-01-2011, 09:35 AM   #10771
CSeils's Avatar
Trader Rating: 48 (100%+)
Thaks for the heads up. Seems to be working now.
Carl
You can never go wrong with a Hooters Mini. But Mini Hooters are bad.
--- USVTA National Points Series Member #122 ---
[email protected] - http://www.rctech.net/forum/painting-designs-graphics-photography/279695-usvta-trans-am-decals.html
CSeils is offline
Old 03-01-2011, 09:48 AM   #10772
Originally Posted by DARKSIDE View Post
its going to be USGT...and the rules are on the USVTA site here...
http://www.usvintagetransam.com/events/index.html
not sure about the Mini or F1 classes this year....
Hey Rob its a month away...how about some info please...
Hmmm..... I called the track and they told me it was RCGT with 17.5. I guess they are in the dark with the rest of us. I'm real happy to learn it's actually USGT rules. I may have to run two classes now.
woodys3b is offline
Old 03-01-2011, 09:53 AM   #10773
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Many tracks use RCGT general rules of 17.5, but those cars are as fast as Stock Rubber, and with no difference other than the body lately, it seems relatively redundant.
The Scale Nationals (USGT) will be using 21.5 motors, and personally I think it's a really good idea for a National class. But then again, I still hope for racing as slow as 4-cell 1/12th scale carpet cars from 1988.
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline
Old 03-01-2011, 11:17 AM   #10774
Trader Rating: 23 (100%+)
I'm looking for a little help I have searched the the tread but I am unable to locate a setup for the tc4 with vta tires. Would anyone be willing to share?
pete8541 is offline
Old 03-01-2011, 12:48 PM   #10775
i have been running a tc4 for about 2years & im in the top 3with it most of the time
my set up i run is
blue springs 40wt oil
silver springs 30wt oil
spool in the front
ntc3 cvd's...for two reasons..the spool will brake the plastic ones & the blue aluminum......the shaft part is thinner & it will reduce the chatter & bindind up then the other cvd's
i have a low roll center...to reduce traction roll
5.5mm ride height & 2 or 3mm over right height
4* caster blocks
1* camber in the front
2* camber in the rear
front shocks layed in next to the last hold
rear shocks standing up
if this dont work for you..i did find that the box stock set up works pretty good
hope this helps!!
starrx is offline
Old 03-01-2011, 12:56 PM   #10776
squarehead's Avatar
Thumbs up
Generally, most of the proven Stock Rubber setups are working well in VTA, with very few exceptions that I know of. Many people start with the kit/manual suggested setups, as well. If you can find a good carpet rubber setup for your car, you'll be right in the ballpark.
Everything depends.
Nothing is always.
Old 03-01-2011, 01:05 PM   #10777
if you have a 4600-5000 lipo its legal....you cant run anything over 5000..
I was talking about possibly 4600-5000 NIHM's being legal ... I can't afford to make the jump to lipo and all it's needs at the moment.
Lynn
Tamyia Cobra R Mustang TA02, HPI Sprint2 Sport, Super Clod Buster, Twin Detonator, AE B4.1, RC10 Gold Pan (mine)
Tamiya Super Clod Buster, Blackfoot Extreme, HPI Sprint2 Sport (My boy's)
CobraRman is offline
Old 03-01-2011, 01:26 PM   #10778
Trader Rating: 24 (100%+)
Not likely Lynn. VTA used to allow 4 cell nimh use but times they are a changing. Then again, as has been mentioned, your LOCAL rules can be different. If you choose to allow 6cell nimh that's fine. No worries unless you try to attend or promote your own VTA sanctioned event. Then everything has to be by national rules.
BTW, the other part of the rules you could play around with 'locally" is the ROAR requirement for batteries. I use Zippy Flightmax hard case 4000mah lipo's and you can buy them for around 25 bucks a piece.
Evoracer is offline
Old 03-01-2011, 01:31 PM   #10779
the USVTA Camaro has stickers that came from the same sheet...large and small was on it...thats the sheet we have...
But the one on the pace car door looks bigger then the one on the #4's quarter though. Unless it is just perspective, it looks twice as big.
Lynn
Old 03-01-2011, 03:59 PM   #10780
DARKSIDE's Avatar
Lynn
one is bigger than the other...but mine came on the same sheet...and I thinks TQ's did also
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/OTT/1UP
Apex Raceway and Hobbies
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline
Old 03-01-2011, 04:41 PM   #10781
squarehead's Avatar
Thumbs up
I designed the logo and did the original decal sheet, that was to be printed in red, white and blue on a clear backing. It wound up being red and white on a white backing with a die cut. The truth is, they can be a lot better. Carl does great work, and I have no doubt that his decals will be fantastic.
The original layout was this:
The large was 3.4" x 1.8", the medium size was 2.4" x 1.3" and the small shields were 1.2" x .625" give or take.
Everything depends.
Nothing is always.
Old 03-01-2011, 05:08 PM   #10782
DARKSIDE's Avatar
BINGO!!!!...THANKS DOUG
DARKSIDE is offline
Old 03-01-2011, 05:29 PM   #10783
DARKSIDE's Avatar
for the VTA guys that went to the Indy race...my wifey took a few pics...Ive posted them here
http://www.rctech.net/forum/racing-f...ml#post8731087
DARKSIDE is offline
Old 03-01-2011, 05:57 PM   #10784
DING DING SING....
This is the one I want.
Carl, can this one be the one you offer FS it is OK with the maker?
Lynn
Old 03-01-2011, 06:16 PM   #10785
squarehead's Avatar
I can provide the original artwork to Carl if that's what the peeps want from the decals...
Everything depends.
Nothing is always.
Closed Thread
Georgia Vintage Trans Am Racing shadow102 Georgia Racing 725 02-24-2012 09:56 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Thursday Vintage Trans Am racing at Victory in Green Bay Brian F Wisconsin & Illinois Racing 13 05-10-2008 08:37 AM
