Like Tree1Likes
Closed Thread
Old 02-14-2011, 03:02 PM   #10531
Jay Boyd's Avatar
How about a GTB2/25.5 Ballistic USVTA combo? That's the one I was waiting for.
Originally Posted by NovakTwo View Post
This week we are releasing 6 new combos with the GTB2:
. GTB2 / SS pro 25.5T--USVTA (includes Traxxas battery (??), bullet motor plugs, low-profile heat sink, no fan, and smaller trans-cap module) $159.99
. GTB 2 / SS Pro 8.5T Traxxas (includes Traxxas battery, bullet motor plugs, low-profile heat sink, no fan, and smaller trans-cap module) $159.99
GTB 2 / SS Pro 17.5T Traxxas (same)
GTB 2 / Ballistic 13.5T (no plugs, low-profile heat sink, no fan (?), and smaller trans-cap module) $169.99
GTB 2 / Ballistic 17.5T (same)
. GTB 2 / Ballistic 550 4.5T combo for the Traxxas Slash 4x4 (includes Traxxas mounting plate and 32P gear. Standard HS/fan.
The GTB2 w/LP/HS should look like this. When used with a spec motor (8.5T and above) this GTB2 configuration is perfect. I would like to offer this GTB2 "Spec" version in our store.
Jay Boyd is offline
Old 02-14-2011, 03:16 PM   #10532
Company Representative
We can certainly add such a combo; our experience has been that USVTA racers are bargain hunters....
A GTB2/Ballistic 25.5 combo would be 169.99---a 20.00 saving over purchasing the items separately.
NovakTwo is offline
Old 02-14-2011, 03:19 PM   #10533
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
2wks ago, put a 008 with lipo kit up to 1550 for a vta enduro fairly easily. that was with a RS on the other side as well. heck i think couple yrs ago in local club they had rewards weight for top 3 each wk and the guy who kept winning was close to 2000g when the rule was abandoned b/c by then it was tough to find space on car. scary part was for most of those increases, the car got faster.
R
UltegraSTI is offline
Old 02-14-2011, 04:07 PM   #10534
nashrcracer's Avatar
R/C Tech Charter Subscriber
this one is money! that's sweet with the cap and all...
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline
Old 02-14-2011, 04:17 PM   #10535
trerc's Avatar
Trader Rating: 89 (100%+)
For an extra $10 you can get a Ballistic/GTB2 combo, That to me is a no brainer...
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline
Old 02-14-2011, 04:20 PM   #10536
DARKSIDE's Avatar
and FREE PARAGON !!!!!!! just for you....if you order in the next 1 second?...oh well you missed it, but its still a sweet deal..
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/OTT/1UP
Apex Raceway and Hobbies
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline
Old 02-15-2011, 08:40 AM   #10537
Your wish is my command; I will direct that we add the new GTB2/Ballistic 25.5 combo to our store....
While, I have your attention, should we continue to install Tamiya battery connectors or install Traxxas to our USVTA escs? We are releasing additional TRA-compatible combos for our SCT customers (Plug 'n Play). Do most USVTA guys run TRA-harnessed batteries---enough to switch over to the connector---which is more expensive than the Tamiya. Most racers remove the Tamiya and add some other plug---we install the Tamiya for our internal testing procedures (we run all electronics as part of our factory testing.)
Another thing I have suggested is installing the low profile HS on our (USVTA-versions) Havoc 2S escs and combos. Then, both our GTB2s and Havoc 2Ss would be more compact to install.
NovakTwo is offline
Old 02-15-2011, 08:57 AM   #10538
Trader Rating: 24 (100%+)
How about keeping costs as low as possible. I've never touched a Traxxas connector. Everything is bullet style that I soldered on. Just curious though....if a customer wanted a Traxxas or a Tamiya connector or even a Deans...could you offer it as a option and charge for it's installation ?? Pro Match offered that (and still might ) and I always thought it was very useful.
Regarding HS....the smaller the better. (not gonna hear that often.)
And speaking of....Did you mention the Mongoose is also an effective option? If so....maybe it should be added to the list of combos. I'm considering it now that I have a chassis where space is at a premium.
Evoracer is offline
Old 02-15-2011, 09:14 AM   #10539
We can not offer special harnessing; that's why I would like to offer product versions in our store that appeal to the most racers. I have already set up a meeting about converting all of our VTA escs and combos to the low profile HS---which requires no fan.
The gold-plated plug-in motor and battery connectors are probably the best choice and we sell both in our store, but they do require soldering....
PM me regarding Mongoose.
NovakTwo is offline
Old 02-15-2011, 09:16 AM   #10540
kwkride's Avatar
I don't know anyone that runs Traxxas connectors either.
I would guess that it's at least 95% Deans plugs.
You could make it simpler and just put no connector on it.
It would just save us a step before we solder on the Deans plug.
Jim
"If God had meant for us to drive through the front wheels, he never would have allowed us to invent the ring & pinion"
kwkride is offline
Old 02-15-2011, 09:21 AM   #10541
The main reason we still install the Tamiya connectors on Sport/Spec controllers is our factory final load testing, before shipping.
NovakTwo is offline
Old 02-15-2011, 09:27 AM   #10542
snoopyrc's Avatar
The Tamiya Battery plug, unchanged since I used it as a kid. A temperamental connection that cuts out, usually when you need it the most. It is unable to hold up against any amperage without a total melt down and fusion of parts. Yet for some reason it is still standard on All Tamiya and loads of non Tamiya parts. It stands as a monument, reminding all that you can offer a crappy feature and make it endure for generations.
Yeah I know you have to put something on there. Just do what you have to to save the money. I will put Deans on it when it gets here. Or for five bucks more you can sell it with the Deans attached.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline
Old 02-15-2011, 09:59 AM   #10543
I forgot to say that !! But it make the most sense. And if you ARE offering the Traxxas plug....I hope they're paying extra so the cost isn't passed on to those of us who don't need it. Hope that doesn't sound rude but if soldering isn't a skill you have then you should pay to have it done for you.
Evoracer is offline
Old 02-15-2011, 10:15 AM   #10544
What I really want to know is " Where the hell is Dale Epp from Protoform !!?" he said Feb. 15 and I want it now !!
Evoracer is offline
Old 02-15-2011, 11:34 AM   #10545
JCarr's Avatar
My thoughts almost exactly.
Gorilla Size Racing
R10 USGT, TRF416 USGT, DB10R, TA05R VTA, R40, RS4 3SS, RS4 super, Savage, Hellfire.
Youthful enthusiasm only rules until old age and common sense exert themselves
JCarr is offline
Closed Thread
Georgia Vintage Trans Am Racing shadow102 Georgia Racing 725 02-24-2012 09:56 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Thursday Vintage Trans Am racing at Victory in Green Bay Brian F Wisconsin & Illinois Racing 13 05-10-2008 08:37 AM
