Like Tree1Likes
Closed Thread
Old 01-14-2011, 03:56 PM   #10081
Team Tekin
Tekin Prez's Avatar
Originally Posted by woodys3b View Post
The only advice I would give you is that since you are starting from scratch, adopt the rules as written. It's easier than making allowances for other motors/speedos/bodies now and then trying to get back to the rules as written later.
You could allow people to use any esc's they might already have and motors they might already have to reduce barriers to joining up and having some fun.
The fact is there is very little difference in ROAR approved motors and even less difference, if any, in esc's with spec settings or non boosting esc's.
Wide open doors, more people, more fun!
Tekin Prez
[email protected]
Smarter, Smaller, Faster....
www.teamtekin.com
Tekin Prez is offline
Old 01-14-2011, 04:09 PM   #10082
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Though that is really "wide open no-spec rules" right from the beginning and that has proven itself to NOT work long-term anywhere in the country. It will take 2 weeks for people to be using $200 ESCs and motors that aren't easily teched (rotors, ceramic bearings, etc.)
Wide open rules is NOT spec racing and doesn't work. You can't put the toothpaste back in the tube. Don't waste your time with "open" run-whatcha-brung VTA classes.
If Tekin wants to be a part of USVTA spec racing, you should consider producing a small, true zero-timing spec ESC under $100 and stop trying to convince everyone to bypass the spec class rules to allow your computer programmable ESCs in "spec" mode.
Harsh, maybe, but like I recently said here, I use Tekin in everything except VTA. I would use a Tekin for VTA if one was made for this application, and not something that can be hooked up to a laptop. Make a legal piece of electronics for spec classes like this (that are getting more an more popular for a very good reason). The fact that the "spec" setting on previous programs was NOT zero timing—or false zero timing—leaves a bad taste in everyone's mouth about the commitment to level playing field racing without electronic aids like "cheat" or Turbo mode from Tekin.
Build it, get it approved by the USVTA and people will use it. Simple as that. Until then, trying to convince people to bypass the spec class rules to run "open" rules defeats the whole purpose of this class, and makes Tekin look bad.
Just my government cheese 2˘.
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline
Old 01-14-2011, 04:23 PM   #10083
trerc's Avatar
Trader Rating: 89 (100%+)
Amen! I would dump brand x like yesterday for a tasty little TRUE Spec offering from Team Tekin! Build it Tekin, It will be a hit I guarantee, we all want it!!!
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline
Old 01-14-2011, 04:28 PM   #10084
snoopyrc's Avatar
What keeps people in the class is the tight racing and speeds that aren't intimidating for the noob.
That being said, maybe a GT class that uses GT bodies and HPI X-pattern belted tires could be what you need. For all practical purposes, these tires are the rubber touring car equivalent to the HPI VTA tires. If you use USVTA rules with just these two changes, you essentially have VTA that appeals to the younger crowd.
Originally Posted by Evoracer View Post
At present, we're offering exactly what you're suggesting. We just re-started the club though and have only had our first get together recently.As of now we offer a GT class using 21.5 no timing and either the x pattern or solaris tires. I really like the stability of VTA and ,as many of you know, GT racing (or whatever iteration you have locally) has been a cluster for awhile and is now basically whatever each group decides it to be.
I'm not real comfortable with that prospect. I like the idea of being part of a larger group and so do many other drivers, especially newer ones. That's why I was asking how others have promoted it. I need to make that commitment now though, before I've asked people to invest in motors and other items they don't need.
Thank you two for finally making me NOT be the only person who has suggested this. Actually I think RobK came up with a similar class not to long ago.
I have wanted a "Sports Car" class for a long time. Slow and reasonable like VTA but with more body and wheel choices. At first I was trying to get VTA to meet me there and it caused a big riff between me and those guys. Now I appreciate VTA for what it is, but I still would like something with more loose rules to go with it.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline
Old 01-14-2011, 04:32 PM   #10085
squarehead's Avatar
RCGT, Kent, a great class and a wonderful sister class to the USVTA.
Everything depends.
Nothing is always.
Old 01-14-2011, 05:24 PM   #10086
robk's Avatar
Trader Rating: 22 (100%+)
robk is offline
Old 01-14-2011, 05:38 PM   #10087
DARKSIDE's Avatar
Originally Posted by robk View Post
2011
OH HE77 YEAH!!!!! LETS DANCE...."A" MAIN HERE I COME...WHOOOOOOO!!!
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/OTT/1UP
Apex Raceway and Hobbies
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline
Old 01-14-2011, 05:56 PM   #10088
rcwanaB's Avatar
Trader Rating: 14 (100%+)
Default servo torque?
Hey guys im looking to upgrade to a faster servo. How much torque does a car need running the rubber HPI vta tires. Fast digital servo's are around 130oz. of torque give or take and weigh around 55 grams. I see some with around 50 oz. of torque that weigh less than 30 grams. Right now on my tc5 i have 35 grams of balance weight on battery side of chassis opposit of steering servo. Sure would be nice to eliminate a lot of that balance weight and lighten the car up overall.
rcwanaB is offline
Old 01-14-2011, 06:01 PM   #10089
trerc's Avatar
I've ran many of the Futaba s9551 or S9550 (Same servo) for a looooong time with no issues from any of them and they can be bought pretty cheap used to if you wanna go that route. They are about 20 grams lighter than a standard size servo too, FYI.
trerc is offline
Old 01-14-2011, 06:14 PM   #10090
DARKSIDE's Avatar
Ive got the 9551 and 9550 in my TC5's(vta/tc) and have had nothing but the best luck with them...got the 9550 used, and the 9551 new when it came out...havent removed either since..
FUTM0661 Futaba S9551 Digital Low Profile Servo $84.99
DARKSIDE is offline
Old 01-14-2011, 06:18 PM   #10091
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
THAT RCGT BELT WILL HAVE TO BE PRIED FROM MY COLD DEAD RADIO HAND!
BRING IT!
"PREPARE TO QUALIFY"
g12314 is offline
Old 01-14-2011, 06:32 PM   #10092
DARKSIDE's Avatar
sorry about your hands....
DARKSIDE is offline
Old 01-14-2011, 07:33 PM   #10093
snoopyrc's Avatar
Yeah... I agree. I saw somewhere there was a track that was running RCGT with VTA powerplant rules. But that was the previous generation of rules. I am SOL for onroad anyway. Nashville is the best option for me there, and it is really good racing, but at 2.5 hours away, I just can't do that very often.
About the servo. I have a SAvox that is blister quick and very torquey. It was less than $70, if you want another option than the futaba.
snoopyrc is offline
Old 01-14-2011, 08:54 PM   #10094
jgraham37128's Avatar
Trader Rating: 24 (100%+)
Why not have one speed controller that will be competitive in all classes not just one. I've seen year after year where we race one class this year and change the next year. My Tekin will handle all classes rather VTA or 17.5 spec or boosted, and that was the main reason I bought it. I know you think people don't leave our sport because someone changes the rules but they do. We're tired of changing all this crap out to be compliant with the new rules. I have a vta car that was ran all summer with a Tekin and a 21.5 motor. I had a blast and truly liked this class the most, but I'm not buying another speed controller when mine is capable of running in spec mode. If you're saying my speed controller in spec mode is not actually spec then call Tekin out and prove it's not. They can either make it compatible or say they aren't able to comply with the requirements.
Again my complaint is these rules change all the time. 17.5 one year, 21.5 motor the next year, then half way thru the year Novak produces the ballistic 21.5 motor. I buy one those and now this year I need new speed controller, and a 25.5 motor to race, cmon..............
jgraham37128 is offline
Old 01-14-2011, 09:11 PM   #10095
trerc's Avatar
It's been discussed over and over. Suck it up, conform and comply or simply don't run the class...
trerc is offline
Closed Thread
Georgia Vintage Trans Am Racing shadow102 Georgia Racing 725 02-24-2012 09:56 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Thursday Vintage Trans Am racing at Victory in Green Bay Brian F Wisconsin & Illinois Racing 13 05-10-2008 08:37 AM
