Like Tree1Likes
Closed Thread
Old 12-24-2010, 05:56 PM   #9886
DARKSIDE's Avatar
Originally Posted by reenmachine View Post
I was hiding some Christmas presents under the RC bench in the garage and found some new & used VTA wheels & tires:
http://www.rctech.net/forum/r-c-item...ml#post8377509
I'd love to see them go to a good home since, alas, we couldn't make the class fly out here!
dont give up hope...dang that sold fast...wow-weee
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/OTT/1UP
Apex Raceway and Hobbies
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline
Old 12-25-2010, 10:31 AM   #9887
Trader Rating: 18 (100%+)
i have noticed (maybe its was just me) that most of the vta cars i see pix of are using the ss21.5 and not the ballistic 21.5 . curious as to why. i know you dont gain a ton of rpm by twisting the ballistic but why not if you can. if its a "top secret" thing well then maybe i know why. but was just curious as to why they are beeing used alot.
Air Support for Team CPAURL
Team Powers
CKHobby.com
byohnd is offline
Old 12-25-2010, 10:49 AM   #9888
Company Representative
They're cheap....
RMF SS Pro Motors
TeamNovak USVTA Store
NovakTwo is offline
Old 12-25-2010, 11:53 AM   #9889
DARKSIDE's Avatar
Ive goy Ballastics and SS, in my VTA and RCGT cars....they are both great
DARKSIDE is offline
Old 12-25-2010, 01:31 PM   #9890
Trader Rating: 70 (100%+)
Hey guys,
I got an HPI cuda body for drifting and I wanted to know which wheel offset do I need to get for the rear and front? Thanks in advance and Merry Xmas!!!
lnc0321 is offline
Old 12-25-2010, 04:27 PM   #9891
[QUOTE=NovakTwo;8389463]They're cheap....
+1
J. Barton
Associated B5M
Associated RC8B3E
smokefan is offline
Old 12-25-2010, 05:29 PM   #9892
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Originally Posted by squarehead View Post
Tire & Wheel Specifications:
The only tires allowed are HPI tire part #4793 front and #4797 rear, using stock tire inserts provided with tire and any HPI Vintage wheels designed to fit these tires. Five or Eight spoke wheels available in various colors. 0mm offset front wheels and 6mm offset rear wheels are intended for 26mm width fronts and 31mm width rear tires. 8-spoke Vintage wheels from #3805 through #3814, 5-spoke Vintage wheels from #3815 through #3822 and Vintage stock car wheels from #3854 through #3860 are all legal wheels.
Wow, I just quoted myself from the first post of this thread.
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline
Old 12-25-2010, 07:09 PM   #9893
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
Originally Posted by bigb11 View Post
Anyone looking for numbers and number plate decals, pm me I have about 100 sheets.
still have lots left.
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline
Old 12-26-2010, 04:59 AM   #9894
I have both a 21.5 and 25.5 in the ss flavor. After messing with the timing a bit on both motors I've returned them to the factory setting and stopped messing with it. Not anything to be gained by doing this in my opinion. If my opinion is correct, there really isn't much of a reason to spend the extra cash on the Ballistic unless you want to take advantage of it's rebuildability. With remanufactured motors available from Novak for around $40, I don't see much point in that either. Gotta love Novak!
Leave the timing alone and gear it properly for the track and be happy.
woodys3b is offline
Old 12-26-2010, 08:06 AM   #9895
squarehead's Avatar
Also, the Ballistic has a removable sensor cable, which some people find worth it by itself.
Everything depends.
Nothing is always.
Old 12-26-2010, 08:10 AM   #9896
Timbulb's Avatar
I agree, the replaceable sensor cable is very handy.
Timbulb is offline
Old 12-26-2010, 07:10 PM   #9897
My son is looking for a setup for a Schumacher MI3.5 anybody have a good one?
J. Barton
Associated B5M
Associated RC8B3E
smokefan is offline
Old 12-27-2010, 06:29 AM   #9898
Good point.
woodys3b is offline
Old 12-27-2010, 02:36 PM   #9899
PhotoGreg's Avatar
Trader Rating: 19 (100%+)
Entered my first VTA race yesterday @ MSI Racing in Roseville, MI ..
It was the first race for my TC5 I just got a hold of, and While I did OK.. I was around 1.2 seconds behind the "Fast Guys" in the class.
What I noticed consistantly, was that I was slower in the straights then most of the other guys. Right now I am at a 4.22 FDR and was contemplating going to a 3.90ish..
What I am worried about is motor temps, will the 3.90 cause the motor to overheat?
Anyhow, this class is so much fun. You actually have to drive the car, find your line and be smooth...
Greg
Team Double Tap Racing - Two in head, they stay dead!
www.hobbypartz.com | GensAce | Hobbywing
PhotoGreg is offline
Old 12-27-2010, 02:45 PM   #9900
Scottrik's Avatar
Trader Rating: 245 (100%+)
Don't be REALLY quick to assume that the reason your car is slower on the straights is gearing. That may well be the case, but there are other factors that hold sway as well, particularly if you are running any sort of temp at your current gearing.
From experience, the bearings that come in the TC5 kits are complete crap from a durabililty standpoint...and the aftermarket ones are a touch fragile too. They don't take anywhere NEAR the pounding the good ol' TC3-4 bearings did before they start dragging substantially. Not surprising as the balls are significantly smaller, etc.
Also your belt should be LOOOOOOOSE.
You indicate you just picked up the car, if you haven't had a chance to check these things this is where I'd start.
Gearing-wise, we haven't run a LOT of 25.5 yet (assuming that's what you're running if gearing less than 4.2 FDR is allowed) but on our typical 40 X 70 layout we've found that about all you add is more temp with gearing below the 4.2 we always ran with the 21.5's. They got a bit faster on the straight, but were doggy in the infield. If your track is all sweepers, etc, a lower gearing might benefit, but here we tried it and went back.
fwiw,
Scottrik
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline
Closed Thread
Georgia Vintage Trans Am Racing shadow102 Georgia Racing 725 02-24-2012 09:56 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Thursday Vintage Trans Am racing at Victory in Green Bay Brian F Wisconsin & Illinois Racing 13 05-10-2008 08:37 AM
