Like Tree1Likes
Closed Thread
Old 12-03-2010, 03:43 PM   #9811
DARKSIDE's Avatar
its your "I's"...lol...31 and 26...here you go body on and off...for you Mustang'ers
U.S. Vintage Trans-Am Racing-usvta-nationals-2009-042.jpg   U.S. Vintage Trans-Am Racing-usvta-nationals-2009-045.jpg   U.S. Vintage Trans-Am Racing-usvta-nationals-2009-041.jpg   U.S. Vintage Trans-Am Racing-usvta-nationals-2009-039.jpg
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/OTT/1UP
Apex Raceway and Hobbies
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline
Old 12-03-2010, 03:55 PM   #9812
Buckaroo's Avatar
Clean looking set up!
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline
Old 12-03-2010, 03:57 PM   #9813
DARKSIDE's Avatar
thanks
DARKSIDE is offline
Old 12-03-2010, 05:00 PM   #9814
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
Default decal sheet
Anyone looking for numbers and number plate decals, pm me I have about 100 sheets.
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline
Old 12-03-2010, 10:15 PM   #9815
DARKSIDE's Avatar
those the ones I got...PERFECT!!!!
DARKSIDE is offline
Old 12-06-2010, 03:04 AM   #9816
RCknight's Avatar
Good to read your coming out with something smaller. Question is when? I hope soon. I would like to put my receiver on the chassis of my T3'11. Will one of those raised heat sinks work with a GTB?
Originally Posted by NovakTwo View Post
Here are links to some of our accessories that may be helpful in making your Novak spec esc more compact:
GTB (Orig) Cooling Plate
Havoc 2S Low Profile HS
GTB 2 Low Profile HS
Lightweight Power Trans-Cap Module - 2S LiPo
RCknight is offline
Old 12-06-2010, 07:57 AM   #9817
Company Representative
Have any of you tried our Mongoose esc with 25.5 (540) motors? It should work fine on this motor. I checked with engineering; I know that some guys are using it in other applications with high-wind motors (17.5s).
Mongoose Micro Brushless/Brush ESC
NovakTwo is offline
Old 12-06-2010, 01:48 PM   #9818
Trader Rating: 42 (100%+)
I may be converting my 416we to a vta car...
anyone have a setup they could share
Scale Speed
ShtLuck is offline
Old 12-06-2010, 02:12 PM   #9819
[QUOTE=NovakTwo;8304302]Have any of you tried our Mongoose esc with 25.5 (540) motors? It should work fine on this motor. I checked with engineering; I know that some guys are using it in other applications with high-wind motors (17.5s). It would be cool if Rob would approve it and it did work ok for VTA.
J. Barton
Associated B5M
Associated RC8B3E
smokefan is offline
Old 12-06-2010, 03:37 PM   #9820
trerc's Avatar
Trader Rating: 89 (100%+)
If these worked it would be brilliant, they are much smaller than the other available legal Novak esc's and cheap to boot.
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline
Old 12-07-2010, 05:16 AM   #9821
RCknight's Avatar
I would be curious on how setting curves for brakes and etc are comparable to the GTB. I wonder if the load and power of touring car would over heat it? Do you need the large power cap? I would rather see something small compact and specific built for VTA from Novak.
RCknight is offline
Old 12-07-2010, 04:21 PM   #9822
DARKSIDE's Avatar
Body Specifications:
Late '60s to early '70s American pony car Vintage Trans-Am bodies only.
Bolink part numbers:
BL2262 '68 Chevrolet Camaro
BL2263 '65 Ford Mustang
HPI part numbers:
17510 - 1970 Plymouth AAR 'Cuda
17519 - 1966 Ford Mustang GT
17508 - 1965 Ford Shelby GT-350
7494 - 1968 Chevrolet Camaro
17531 - 1969 CHEVROLET CAMARO Z28 BODY
104926 1966 FORD MUSTANG GT COUPE BODY
Parma part numbers:
10143 - 1969 Z28 Camaro
10141 - 1970 Boss Mustang
10113 - 1970 'Cuda
Pegasus Hobbies part numbers:
PGH4001 - 1970 Camaro SS
PGH4002 - 1970 'Cuda
PGH4003 - 1970 Mustang
DARKSIDE is offline
Old 12-07-2010, 10:05 PM   #9823
Pete Vitale's Avatar
Does the 25.5 Ballistic have a label/color on the stator to indicate its a 25.5? I'm looking to change a 10.5 to 25.5 but on Novak's website the stator looks to me the label is black and not indicating its a "spec" wind. I don't want to look like a cheater! I'm sure it will be obvious by the speed that I'm not running a 10.5! I hope I put this in the right forum. New to VTA and touring cars.
In search of a faster transponder.
Pete Vitale is offline
Old 12-07-2010, 10:22 PM   #9824
Scottrik's Avatar
Trader Rating: 245 (100%+)
Without going out to look at my motors, iir there is a colored block integral with each stator that keys with the motor can. Each wind has it's own color, these are basically a replacement for the colored rings on the SS motors for the spec classes. 10.5 is blue, 13.5 is orange (reddish), 17.5 is yellow, 21.5 is green and now the 25.5 is black.
I don't know if the black distinguishes itself from the "mod" (low wind) stators, but to your point it will be pretty obvious if you show up with a 7.5 or whatever. It would be a pretty tremendous trick of throttle control to not reveal you were running anything THAT low.
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline
Old 12-08-2010, 05:09 AM   #9825
trerc's Avatar
The stators are color coded for the spec winds, the (25.5) is black. The blue ring can be ordered from Novak if you want it, but you don't have to run the blue ring, it would be for cosmetics only.
trerc is offline
Closed Thread
Georgia Vintage Trans Am Racing shadow102 Georgia Racing 725 02-24-2012 09:56 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Thursday Vintage Trans Am racing at Victory in Green Bay Brian F Wisconsin & Illinois Racing 13 05-10-2008 08:37 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
