Like Tree1Likes
Closed Thread
Old 11-29-2010, 07:53 PM   #9766
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Originally Posted by DARKSIDE View Post
details....come on share...also link isnt working..
Basically, about a hundred people paid in advance to race the most basic car in existence, rain or shine, for 24hrs straight. Even two months on, I still have trouble putting the event into words.
+ YouTube Video
Quite frankly, the USVTA rules are extremely well suited to endurance racing. As long as the tires can go a reasonable distance on the event's track surface, a VTA enduro like our TT01E event would be a no-brainer.
Why don't we endurance race more often?
Greg Sharpe is offline
Old 11-29-2010, 08:17 PM   #9767
hanulec's Avatar
Trader Rating: 27 (100%+)
you can read more about the event here -- it was a truly amazing and tough event that i'm happy to say my team won -- http://racerlog.com/wiki/Tight_Shirt_Racing
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline
Old 11-29-2010, 09:14 PM   #9768
DARKSIDE's Avatar
Im "J"
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/OTT/1UP
Apex Raceway and Hobbies
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline
Old 11-30-2010, 07:07 PM   #9769
Big Midget's Avatar
Trader Rating: 100 (100%+)
Originally Posted by Greg Sharpe View Post
No, you should use the 0mm offsets up front otherwise you may have issues the the tires rubbing the fenders while turning. Even with the 26mm wide 0mm offset tires/wheels up front, the tires will be quite close to the fenders with the bodies slammed down low.
Thanks Greg, are there any updated rules for running a brushed set up?
27t and 2s lipo....
UltralineHobbies.com
Ultraline Raceway Topeka Ks
Dee & Mee Hobbies RickyRacer Lidz,Absolute Tattoo,Fuzzy Dice Decals
Big Midget is offline
Old 11-30-2010, 07:18 PM   #9770
Scottrik's Avatar
Trader Rating: 245 (100%+)
There has never been a LiPo/Brushed combo officially recognized for VTA. Check with your local club to see if they've made up some sort of "parity" option, but I'd be surprised if anybody has done so. 27T brushed was always run with 4-cell NiMH which is a bit slower than the current 2s/25.5 official spec. A 2s/27T should be much faster.
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline
Old 11-30-2010, 07:34 PM   #9771
Big Midget's Avatar
ah....Our local track must have made up some kind of brushed rule.
Its an asphalt track out doors.
I'll be racing in door carpet VTA.
Thanks for the heads up.
Old 11-30-2010, 07:44 PM   #9772
DARKSIDE's Avatar
if you really need help with that, we have the magic formula...pm me if needed
DARKSIDE is offline
Old 11-30-2010, 07:50 PM   #9773
Big Midget's Avatar
sent.
Old 12-01-2010, 04:06 AM   #9774
IndyHobbies.com's Avatar
I was able to get new body done for my VTA over Thanksgiving. I know its got "neon" on it, but I just couldn't help myself. Base coat is airbrushed white Faskolor backed up with Rustoleum Crystal Clear so that I can wash it if needed.
U.S. Vintage Trans-Am Racing-vtacamaro2010versionih.jpg   U.S. Vintage Trans-Am Racing-vtacamaro2010version-016r.jpg   U.S. Vintage Trans-Am Racing-vtacamaro2010version-021r.jpg   U.S. Vintage Trans-Am Racing-vtacamaro2010version-022r.jpg
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
Member Hoosier RC Racers club - www.HRCRacers.com
USVTA #144
IndyHobbies.com is offline
Old 12-01-2010, 05:06 AM   #9775
Buckaroo's Avatar
Nice and clean. Good work!
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline
Old 12-01-2010, 05:30 AM   #9776
RCknight's Avatar
When will we see Novak's more compact esc design? December when it's released? I would like to run Novak but it's size won't work for me.
Originally Posted by NovakTwo View Post
We will want to test the GTB 2 as configured for a more compact install anyway--just to see how well it works with the high-wind motors. Upthread, there was a complaint about the difficulty of installing our GTBs in TC chassis---which led to the discussion of offering the GTB 2 with these modifications.
The soldered-in switch suggestion was offered because the switch's PCB plug is taller than the LP HS I mentioned. You can also install the GTB on its side, especially if no fan is required. If approved, we will configure the GTB 2 the way USVTA racers want it. We are also in the process of updating and Beta testing our Havoc Sport 2S esc----same specs, new case, HS and expanded (on-board) programming---just like the GTB 2.
Someone also commented about preferring to plug-in a new switch harness rather than soldering the wires. I believe an "unsung" and often unmentioned, advantage of our escs is the ability to perform needed repairs without returning the item to us for service. Input harnesses, switches, power capacitor harnesses, power wires---all replaceable without soldering to the internal PCB.
RCknight is offline
Old 12-01-2010, 06:02 AM   #9777
Trader Rating: 41 (100%+)
We have had some guys wanting to run 27T with a 2s lipo and we have pushed their FDR Up into the 7 range to try and make it similar. The only real issue is they have got loads more torque but since we only allow simple green for tires the traction is quite low which a softer motor is better.
For those running a standard traction compound it will be an issue. I would say a 1S lipo might be tried with unlimited gearing but again that is getting away from the keeping things standard purpose to this class
jdeadman is offline
Old 12-01-2010, 06:40 AM   #9778
pejota's Avatar
2s/27 turn is about the same as 17.5 on the very early, NO BOOST, brushless speed controls.
I used to run a 27 turn for fun at my local track in RCGT over a year ago. It was fun while it lasted.... and then performance dropped off and i went back to brushless.
I guess the real question you should pose to your club members is why do they want to hold on to old technology? Brushless motors last pretty much forever with little to zero maintenance. Their power and efficiency BARELY drops off over time.
Now that 25.5 is the brushless motor of choice my club discovered that we could run two and sometimes three 5 minute qualifiers back to back (to back) without charging and with minimal loss of performance.
I understand change can be scary for some, and maybe it's a money issue since 27 turn motors can be had dirt cheap. But brushless is very, VERY nice.
pejota is offline
Old 12-01-2010, 07:03 AM   #9779
DARKSIDE's Avatar
what chassis are you running that the esc wont work?
DARKSIDE is offline
Old 12-01-2010, 08:02 AM   #9780
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
I found them to be usable, but a massive PITA in most chassis I ever used them in. Not my first choice, when everything else out there is much smaller in footprint now.
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline
Closed Thread
Georgia Vintage Trans Am Racing shadow102 Georgia Racing 725 02-24-2012 09:56 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Thursday Vintage Trans Am racing at Victory in Green Bay Brian F Wisconsin & Illinois Racing 13 05-10-2008 08:37 AM
