Like Tree1Likes
Closed Thread
Old 10-17-2010, 05:08 PM   #9406
ok! so i got to run my ballistic 25.5 motor...& it seems really slow...i had a buddy run a vta car with a silver can motor & we was about even all over the track i was a lil faster then him on the streight away..(just a tad)..i was running tc4.. fdr 4.0...is this about right..no timing in the motor................or is it that in just use to seeing my 21.5
starrx is offline
Old 10-17-2010, 05:15 PM   #9407
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Crank that jammy up with a bunch of timing!
Why don't we endurance race more often?
Greg Sharpe is offline
Old 10-17-2010, 05:56 PM   #9408
i ok ill try that...thanks
starrx is offline
Old 10-17-2010, 06:04 PM   #9409
When we had a 25.5 side by side with a track full of 21.5s, the 25.5 was about 0.2sec slower on a small asphalt track. We had the timing wicked all the way up (it was an SS) and the gearing was about 0.75FDR numerically lower than the 21.5s. Visually, it was barely slower, but it did manage to win the B-main with a consistent driver.
Old 10-17-2010, 06:12 PM   #9410
cool i just did have any other car to judge it by..other then the silver can motor....but next week i will @ the halloween classic..
starrx is offline
Old 10-20-2010, 11:32 PM   #9411
Guest
Default shocks
I want more than stock shocks ????? What kind I use??
LOSIRACER77 is offline
Old 10-21-2010, 12:16 AM   #9412
DARKSIDE's Avatar
I think the TC3 or Losi XXX-s shocks will work...Ive seen ppl switch them off the HPI S2S, not sure with what brand...you might trying the HB site for maybe the Cyclone series Tc cars
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/OTT/1UP
Apex Raceway and Hobbies
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline
Old 10-21-2010, 12:40 AM   #9413
Guest
Default shocks
Thanks man!
Old 10-21-2010, 05:58 AM   #9414
Comparing a 25.5 to a silver can is kind of moot. A good silver can will hang with a good 21.5. A really good silver can will smoke a 21.5. No timing on the 21.5 of course.
woodys3b is offline
Old 10-21-2010, 07:22 AM   #9415
2xs
A couple weeks ago I switched my VTA from my S2S to a Cyclone TC. While trying to get a good race setup on the Cyclone my car would push on/off power on left turns and would be very loose on power on right turns. I tried everything I could to get the problem to go away, different springs, lower roll center, bearings. I went back through the basic setup and corrected a couple very minor setup issues, front camber was off by .5* and re aligned the steering. I even swapped shocks side to side just to eliminate those. Nothing that I did would correct the problem. That is until I swapped tires side to side then it did the opposite of what I started with, push right and loose left. So it seems that I have a bad tire or insert on my car. I am not worried about which tire is bad because I have a new set of tire glued up and ready to go. I was just trying to wait to use them until we started to race.
2xs is offline
Old 10-21-2010, 08:12 AM   #9416
the silver can motor is all i had 2compare it to...& i thought da same thing..he should b killin me...mayb it was a bad motor or he had it gear wrong....ill find out @ the halloween classic
starrx is offline
Old 10-21-2010, 09:05 AM   #9417
jaggededge's Avatar
Getting my parts together for a VTA.
Picked up a used Xray T2, vintage wheels/tires, Mustang body from amain and a Havoc 2s/25.5 Ballistic combo from Novak.
Looks like some guys just over the border in Canada are running these so I hopefully have a place to race.
jaggededge is offline
Old 10-21-2010, 11:33 AM   #9418
Default Ride Height Question
Hey guys, we are trying to get a VTA class up and running and I have a question about ride height. I see the rules specify 5mm minimum ride height, is this measured at the lowest point on the chassis, or does it also apply to the body? The pictures I have seen seem to have the little spoiler at the front of the cars lower than 5mm.
ebruce is offline
Old 10-21-2010, 12:30 PM   #9419
HobbyPLEX's Avatar
Usually, all parts of the car would be subject to a 5mm minimum. All points of the chassis and body.
Tim Ski
www.hobbyplexraceway.com
** 2017 TLR Offroad Cup @ the 'PLEX April 28th-30th **
Tamiya Championship Series since 2009 ** J-Concept Spring Nitro Nationals
ROAR NATS - '16 & '09 Electric Offroad/'14 & '08 Carpet Onroad/'11 1/8 Electric
'16, '11, '08 BRL NOVAK National Finals
HobbyPLEX is offline
Old 10-21-2010, 12:44 PM   #9420
snoopyrc's Avatar
Tim Ski
I was going to say the bottom of the lower deck. Chassis plate. My front lip may go lower than that sometimes, but I think its usually flush with the lower edge of the foam bumper, which is perfectly in line with the deck. I believe the rule is to affect the handling characteristics of the chassis and the deck is much more crucial than the front lip. I think Tim Ski probably has a lot more experience with that than me so until you hear from Robk I would go with what he said.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline
Closed Thread
Georgia Vintage Trans Am Racing shadow102 Georgia Racing 725 02-24-2012 09:56 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Thursday Vintage Trans Am racing at Victory in Green Bay Brian F Wisconsin & Illinois Racing 13 05-10-2008 08:37 AM
