Like Tree1Likes
Closed Thread
Old 10-13-2010, 04:29 PM   #9376
Scottrik's Avatar
Trader Rating: 245 (100%+)
Originally Posted by Cain View Post
wouldn't that logic still then apply now?
Or, is there something else about batteries beyond 5000mah limit that is an issue?
No, because now everybody who is participating already has "Sub-5000" batteries. If the limit were raised now it would run exactly contrary to the purpose of the limit in the first place...to eliminate the perception that a new battery is needed every time mfr's offer bigger batteries.
And face it, NO one is at any sort of advantage (or disadvantage) under the existing rule. There is no shortage of legal batteries, either new or used. Really no need to change anything.
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline
Old 10-13-2010, 04:30 PM   #9377
Scottrik's Avatar
Originally Posted by smokefan View Post
Ok so what are some good lipos then other than TP, had 1 it puffed. So I went back to my old SMC 5000 28c packs and would like to know what some other good packs are.
Why not just stay with your SMC pack? It should be just about perfect.
Scottrik is offline
Old 10-13-2010, 06:04 PM   #9378
LOL its starting to get tired and SMC doesn't make the pack anymore
J. Barton
Associated B5M
Associated RC8B3E
smokefan is offline
Old 10-13-2010, 08:23 PM   #9379
IIICJACKIII's Avatar
Check out Team Phycho Cell batts. Just go to web site and e-mail him. He has 1/10, 1/12 1cell, and 1/18 lipos. He also has some life packs for nitro cars and one for 1cell pan cars.
Team Psycho Cells
IIICJACKIII is offline
Old 10-13-2010, 08:35 PM   #9380
MD
MD's Avatar
Trader Rating: 119 (100%+)
The site is under construction.
MD is offline
Old 10-13-2010, 11:05 PM   #9381
robk's Avatar
Trader Rating: 22 (100%+)
Got a quick question why was the 5000 mah limit set on the packs?? There are alot of great packs out there in the 5500 range used.
Most people pull less than 1200 mah out of a pack in a race with a 21.5. It should be even less now with 25.5.
I didn't see any reason to raise the limit. As time goes on, it might be reconsidered on the basis of availability, i.e. you can't get anything less than 5000. This year it won't change.
robk is offline
Old 10-13-2010, 11:52 PM   #9382
I think the e-mail address is: [email protected]
I will double check with him to make sure.
He is on here also, look up Psycho Man.
Team Psycho Cells
Old 10-14-2010, 09:45 AM   #9383
Just an FYI, last night on my newly built SS 25.5 car, geared at 3.6 with a weight of 1643g, we ran about 9 minutes and it used less then 1000mah. The temps were around 120.
Team Novak,Gravity RC,
ercwhtsd is offline
Old 10-14-2010, 10:04 AM   #9384
Last time I ran 25.5 in a parking lot, geared at ~3.4, I pulled just over 800 mAh in an 8 minute main.
BNiels707 is offline
Old 10-14-2010, 10:06 AM   #9385
Company Representative
A customer PMed about problems replacing his Ballistic sensor harness, so I am posting this here:
Ballistic Sensor Harness Removal
In order to ensure that the replaceable sensor harness doesn’t easily fall out of the Ballistic motor accidentally, the end bell was designed to snugly retain the end of the sensor harness in its connector.
As such, removal of the harness requires special attention so as to not damage the harness itself.
1. Note and mark the factory timing setting on the motor.
2. Using a 1.5 mm wrench, loosen the three flat head screws holding the end cap and sensor assembly in place.
3. Once loosened, grasp the sensor harness as close to the connector as possible.
4. Gently “walk” the sensor harness connector out of the motor’s connector by wiggling the connector side to side.
a. NOTE: You may need to pull up slightly on the harness as there is a small lip on the endbell that may impede the removal of the sensor harness connector in certain circumstances.
5. Once the harness is removed, it can easily be replaced.
6. Next, re tighten the three 1.5 mm screws in the end cap, ensuring that the timing setting is set to where it was noted before the sensor harness removal process was begun.
NovakTwo is offline
Old 10-14-2010, 12:03 PM   #9386
Guest
Default gear ratio
What is the gear ratio of the hpi sprint 2 sport.
What novak motor and speedcontrol do I need to buy, 21.5?? 25.5??
Why can't I find a 25.5 motor anywhere for sale?
LOSIRACER77 is offline
Old 10-14-2010, 01:52 PM   #9387
2xs
2.13
GTB, Havoc or Havoc Pro - 25.5
Order the combo direct from Novak.
2xs is offline
Old 10-14-2010, 01:53 PM   #9388
TeamNovak USVTA Store
Dealer participation is invited; information on page linked.
NovakTwo is offline
Old 10-15-2010, 09:04 AM   #9389
hotrodchevy14's Avatar
Trader Rating: 112 (100%+)
Venom has a 3800mah 35c for under $60 and its "roar" approved
hotrodchevy14 is offline
Old 10-15-2010, 09:58 AM   #9390
JCarr's Avatar
That's what I am using, it's a great pack.
Gorilla Size Racing
R10 USGT, TRF416 USGT, DB10R, TA05R VTA, R40, RS4 3SS, RS4 super, Savage, Hellfire.
Youthful enthusiasm only rules until old age and common sense exert themselves
JCarr is offline
Closed Thread
Georgia Vintage Trans Am Racing shadow102 Georgia Racing 725 02-24-2012 09:56 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Thursday Vintage Trans Am racing at Victory in Green Bay Brian F Wisconsin & Illinois Racing 13 05-10-2008 08:37 AM
