Like Tree1Likes
Closed Thread
Old 08-28-2010, 07:25 PM   #9091
2xs
The HPI bodies have the best detail.
2xs is offline
Old 08-29-2010, 12:36 AM   #9092
Timbulb's Avatar
The Parma bodies are kinda wacked out versions of the real cars. But they're the strongest.
My latest HPI Cuda body that I got a couple weeks ago however, was stronger than previous ones. I'm hoping HPI has started making them stronger.
Timbulb is offline
Old 08-29-2010, 05:29 PM   #9093
Firefox's Avatar
Default Xray T2
Thanks for the rplies on the body.
Is anyone using the Xray T2 chassis ?
Will the HPI wheels fit on it ?
thanks
Firefox is offline
Old 08-29-2010, 06:16 PM   #9094
DARKSIDE's Avatar
yes they will
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/OTT/1UP
Apex Raceway and Hobbies
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline
Old 09-01-2010, 04:18 PM   #9095
robk's Avatar
Trader Rating: 22 (100%+)
TODAY IS THE DAY
http://www.usvintagetransam.com/rules/2010rules.pdf
robk is offline
Old 09-01-2010, 05:00 PM   #9096
And the peasants rejoiced.
Originally Posted by robk View Post
BNiels707 is offline
Old 09-01-2010, 08:45 PM   #9097
Aaron P's Avatar
I love VTA. We do something different for the start of our mains every week.
Has anyone tried a "lawnmower racing" style start? You could have the drivers stand on the side of the track opposite the drivers stand with the cars lined up LeMans style and the drivers could run across the track and turn on their radio and car, then hop on the drivers stand and take off. Hmmm....we might have to try that one of these times!
Aaron P is offline
Old 09-01-2010, 09:10 PM   #9098
so no more gear FDR limit ?
Rojna is offline
Old 09-01-2010, 09:35 PM   #9099
snoopyrc's Avatar
[QUOTE=robk;7885892]TODAY IS THE DAY
21.5 for sale. Just kidding.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline
Old 09-01-2010, 09:46 PM   #9100
snoopyrc's Avatar
Originally Posted by Firefox View Post
Just wondering, is there any particular brand of body that is prefered, has better detail, over other brands ?
thanks
As far as VTA goes, I think I agree with 2xs. I love HPI shells. I am an absolute fan. I think that HPI shells have the best mix of detail and usable durability, making them the all around best producer of Lexan body shells for RC cars. But if you are going on detail alone then I would have to say Tamiya and then ABC. Who dont make anything legal for VTA, but geez their stuff is nice.
snoopyrc is offline
Old 09-02-2010, 05:21 AM   #9101
pejota's Avatar
Nope. But be prepared to go awfully big on the pinion. I've heard that 3.5 FDR is a good place to start. But that is all relative to track size, layout, etc.
pejota is offline
Old 09-02-2010, 07:13 AM   #9102
beemerfan's Avatar
Trader Rating: 34 (100%+)
If your car is up to the 1550 g weight specification, then don't be afraid to gear shorter. With a 100% USVTA rules compliant car, I got much better performance and lap times from a 4.2 than a 3.6 FDR. And the motor stayed cool enough that no fans were necessary. This was on a typical parking lot layout about 100' x 40' with a single straight and a curvy infield. Gearing too tall will kill your corner exit speeds where you need it the most. Just because the gearing restrictions have been lifted doesn't mean your old gear ratios won't work and weight is a factor. I'd say that whatever you were doing with your 21.5 motor, start with a pinion that is about 2 teeth larger and work from there.
Also, I suspect there will be much cheating, both intentional and out of ingnorance in regard to weight going on at the local level where cars typically aren't checked. However, the cheaters will be missing out on the handling benefits of a car that's 3.5 oz. heavier than the old standard. More weight = more traction on those slippery parking lots. Especially ones that are not treated with any kind of traction compound. I'll stop now before I give away all my secrets!
beemerfan is offline
Old 09-02-2010, 07:24 AM   #9103
snoopyrc's Avatar
Also in a field of cars with mixed levels of experience, you fair better if you happen to rub fenders with a lighter car. There is less getting bullied off your line.
HPI struggled with this because you lose the sharpness and detail when you pull the shell from a thicker lexan. The Cuda has really nice undercuts in the front end, but that made it weaker in that spot and it shows if it takes a lick on the nose. Since the shell was being raced frequently, they decided to go ahead and make the production run from the heavier material. I think its only 37 grams heavier than the previous shell, but that measurement was on a painted shell. Most VTA racers need to add weight anyway, but a heavier shell doesnt help the center of gravity. I think it was a good move. The shell still looks great and it holds up much better to the rigors of racing. I dont think the added weight is much of an issue under the conditions that it is being used.
snoopyrc is offline
Old 09-02-2010, 07:52 AM   #9104
kwkride's Avatar
Yes, I'm sure the layout and size of the track makes a difference. I was running a 4.2 FDR and my motor was hitting 160f at the end of the main.
Jim
"If God had meant for us to drive through the front wheels, he never would have allowed us to invent the ring & pinion"
kwkride is offline
Old 09-02-2010, 07:54 AM   #9105
kwkride's Avatar
The heavier Cuda shell is great. My "original" Cuda shells were only lasting a couple of months. My current "heavy" one has lasted almost a year now.
Jim
kwkride is offline
Closed Thread
Georgia Vintage Trans Am Racing shadow102 Georgia Racing 725 02-24-2012 09:56 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Thursday Vintage Trans Am racing at Victory in Green Bay Brian F Wisconsin & Illinois Racing 13 05-10-2008 08:37 AM
