Like Tree1Likes
Closed Thread
Old 01-23-2010, 08:27 PM   #7861
hogmansp's Avatar
Trader Rating: 47 (100%+)
Any tracks running VTA near the Dubuque Iowa area? Thanks
Losi 22 revtech
Kyosho SC-R Big Bores revtech
hogmansp is offline
Old 01-23-2010, 08:29 PM   #7862
Immo's Avatar
Send a message via AIM to Immo Send a message via Skype™ to Immo
Check out the VTA site
http://www.usvintagetransam.com/tracks/index.html
Immo is offline
Old 01-24-2010, 11:18 AM   #7863
qcrc's Avatar
Check out www.twinbridgesrc.com .
Schumacher Cars
Speed Passion Powered
qcrc is offline
Old 01-24-2010, 06:34 PM   #7864
Applesauce's Avatar
Trader Rating: 14 (100%+)
What are you guys doing to get these tires to hook up? traction compound....etc
Applesauce is offline
Old 01-24-2010, 06:41 PM   #7865
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
on what kind of surface??
for asphalt, i've seen guys using paragon, jack the gripper, tire warmers...Personally I don't like traction compound on asphalt - to me it makes the cars more loose! I have tried warmers, and liked them but 99% of the time i use nothing on mine - saves the part of the race when the traction (compound) wears off and the car gets loose...my don't have it to begin with, so I never hit that stage
Bodies By Bean | Team Belly
k_bojar is offline
Old 01-24-2010, 06:47 PM   #7866
Applesauce's Avatar
Sorry..... on carpet
Old 01-24-2010, 06:50 PM   #7867
k_bojar's Avatar
i've only ever used Jack on carpet, and it seemed to work fairly well
k_bojar is offline
Old 01-24-2010, 06:56 PM   #7868
Scottrik's Avatar
Trader Rating: 245 (100%+)
As far as initial tire prep I make sure the tires are SECURELY glued (usually by having somebody who is better at this than I am do it) and I sand the mold seam off new tires. Beyond that, I've had good luck with new tires so no "witch doctor magic" needed.
Regular day to day on what the majority of folks are using for compound.
At our track MOST folks are using Niftech compound so I really don't do much of anything except apply the compound to the tires withing about 15 minutes of hitting the track. The Niftech does a great job evaporating off so no need to wipe. I "burn out" the front tires on the burn out pad for about 3-4 seconds to warm the front tires then do a couple warm-up laps. This give my car good balance from the start. If I don't do the front tires or do all four tires my car has a terrible push the first minute or two and puts me in a hole.
If I'm at a track where most/everybody use Jack (I HATE Jack!!) I find that I need to clean my tires between rounds or the buildup is a problem. I use a home-brew mixture to clean my tires (I don't use motor spray as I think it dries things out) and then goop 'em before each round. I then follow the same burn-out proceedure.
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline
Old 01-24-2010, 07:58 PM   #7869
Trader Rating: 49 (100%+)
Mid-America Hobbies in North Liberty, IA is starting to run them. Only had 2 races so far, but the interest is growing. http://www.midamericaoff-road.com/index.html Its about 1 1/2 hours from Dubuque or so. Only had 3 the first race day and I'm not sure how many were this past Saturday as I wasn't there... Just checked and it was only 2, but it was also a non-points day which has a significant lower turnout. One last thing, no traction compound allowed. The floor is heated and the carpet has a ton of traction.
iadevil is offline
Old 01-25-2010, 07:53 AM   #7870
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
I use paragon, the old stinky stuff, and also work the tires on a rough surface like concrete. My first set took much more work than the second set, both of which started at new.
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Cain is offline
Old 01-25-2010, 03:28 PM   #7871
Racer X79's Avatar
Like was mentioned earlier, proper glueing is very important. I like to glue the inner/outer bead to the rim (you have to hold open the outside sidewall "flap" to get in there), let the glue set and then glue the outer side wall "flap" to the rim also. Then you can remove the center molding seam, but I've had good luck just running them in without it. To run them in I just clean them very good (Simple Green seems to work pretty well), put full tire compound (I use Jack the Gripper) on all the way around and run 6-10 minutes of practice. Then clean them, full compound again, and run another 6-10 minutes. After that they are ready to go....for me anyway. Hope this helps.
--Ermer Racing Inc.--
IDC Precision Machining (www.idcwi.com)--Trackside Raceway (www.trackside.com)--Hounds Hobbies and RC Track In The Back--
Racer X79 is offline
Old 01-25-2010, 03:45 PM   #7872
DARKSIDE's Avatar
This is from my VTA tip line....go here for even more options....
http://www.nashrcracer.com/forum/vie...r=asc&start=45
TIP...this is something Im trying and it seems to work really well...for alot of "BIG" races you are required to have close to new tires..or at least alot of thread...but we all know the VTA tires are not the best new...
so what Ive done is take a new set of tires...open the package and remove the foam inserts....then take Reino Marinade and pour a hefty some into the bag....massage the tires real good..after a few mins...seal the bag with tape/staple...or just use a ziplock bag...once sealed let them soak for 2 days...if you can let the sun bake them, do so....this really helps..
after that remove from the bag and clean with Reino tire cleaner...you can try other cleaners, but I dont know if it has the same effect...once the tires are clean and dry....mount them as normal...you should have a nice set of really soft, full thread tires to use....
FYI...this TIP will be very helpful at BTH 09, Cashville Enduro, and MCC
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/OTT/1UP
Apex Raceway and Hobbies
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline
Old 01-25-2010, 05:17 PM   #7873
Applesauce's Avatar
What is Reino Marinade and where can I get some?
Old 01-25-2010, 11:31 PM   #7874
robk's Avatar
Trader Rating: 22 (100%+)
Buggy grip works just as well
robk is offline
Old 01-26-2010, 08:34 PM   #7875
flat4's Avatar
Send a message via Yahoo to flat4
sorry kinda a bit of a noob, i have not race 1/10 for along time. the venom lipo 5000 40c packs. would they be good for the VTA class? btw i am building my car for the summer season.
flat4 is offline
Closed Thread
Georgia Vintage Trans Am Racing shadow102 Georgia Racing 725 02-24-2012 09:56 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Thursday Vintage Trans Am racing at Victory in Green Bay Brian F Wisconsin & Illinois Racing 13 05-10-2008 08:37 AM
