Like Tree1Likes
Closed Thread
Old 06-26-2009, 12:15 PM   #5371
Trader Rating: 17 (100%+)
Originally Posted by home13oy75 View Post
I'm in the process of transforming my car for VTA racing. I'm sure this info might be in the 358 pages but was looking for a quick reply so I can order my motor today. Is the Novak SS21.5 Pro brushless motor the only approved 21.5 motor?
Yes
billb60 is offline
Old 06-26-2009, 12:22 PM   #5372
Originally Posted by billb60 View Post
Yes
Thanks for the quick reply.
home13oy75 is offline
Old 06-26-2009, 01:07 PM   #5373
Coulda got one here yesterday. Otherwise try St. Charles or Strictly, I am sure they have them on the shelf.
Team Novak,Gravity RC,
ercwhtsd is offline
Old 06-26-2009, 02:18 PM   #5374
IndyRC_Racer's Avatar
Decent grip asphalt + VTA tires + front spool??
What is the benefit of running a spool when racing with rubber tires on asphalt? Do you get better steering response (like a one-way), but still have front brakes?
I'm also going to post this question on the VTA setup thread here on RCTECH.NET (http://www.rctech.net/forum/electric...-tuning-q.html).
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline
Old 06-26-2009, 02:40 PM   #5375
speedsterblade's Avatar
I just dropped a spool in my 17.5 tc (running jaco blues which are not much softer than good worn set of ta tires) and it really made a big difference, had to adjust my style a little (to stay on the throttle more) but not as much of a change to a one way! The advantage is on power steering... my corner speed went up. definitely worth trying IMO. I got one for the TA but haven't dropped it in yet...I've just been running a diff but super tight, almost like a spool. We haven't had alot of hard braking areas with our layouts, but did have to soften the braking some.
tc3/4 owners: if you are running the plastic cvds/dogbones you prolly want to go with alum. ones if you use a spool....the spool isn't as forgiving as a diff and the plastic cvds won't last long...
i tried it on the carpet track just to see... was a touch harder to drive over the diff... it'd spin out too easy if I let off the throttle too much.
______________________________
#47 MoneyShot Racing
www.nashrcracer.com
http://thunder.rc50.com/
SMC - Customer Service 2nd to None! (thanks Dan!!)
speedsterblade is offline
Old 06-26-2009, 02:51 PM   #5376
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
With a spool on asphalt you get better breaking and more on power steering. Also on asphalt a spool is generally easier to drive then a 1-way.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline
Old 06-26-2009, 04:01 PM   #5377
DARKSIDE's Avatar
Ive ran both, in my TC5's..and dont see to much difference...still diffs in the TC3...it seems to still be the best car for asphalt..the 5 for carpet...my $0.02
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/OTT/1UP
Apex Raceway and Hobbies
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline
Old 06-28-2009, 06:42 PM   #5378
Do you guys just run your tires till there bald then buy new? Or is it better to have a couple sets and switch back and forth.
J. Barton
Associated B5M
Associated RC8B3E
smokefan is offline
Old 06-28-2009, 06:51 PM   #5379
Trader Rating: 21 (100%+)
Default tires
bald, better traction.
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline
Old 06-28-2009, 07:02 PM   #5380
Lapcounter's Avatar
How often are the approved bodies reviewed or updated?
The new HPI vett body looks like a good fit.
http://www.hpiracing.com/products/en/17526/
Lapcounter is offline
Old 06-28-2009, 07:58 PM   #5381
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
stop - please don't try this again...read back about a dozen pages or so, and you'll see that its already been discussed...
the vette never ran in the original TransAm Series...
so just let it go don't need to have another 2 or 3 pages of discussion/flaming...
Bodies By Bean | Team Belly
k_bojar is offline
Old 06-28-2009, 08:43 PM   #5382
pejota's Avatar
Interesting factoid...
If you look through the Trans Am box scores during that timespan there was ONE Chevy II/Nova that appeared in one or two races.
http://www.scca.com/documents/Pro%20...ns-Am/1970.pdf
Just change the year at the end to search all of the box scores.
pejota is offline
Old 06-28-2009, 09:01 PM   #5383
Lapcounter's Avatar
Sorry, I used the RCTech search function to see if it had already been asked about. It didn't find anything.
Old 06-28-2009, 09:01 PM   #5384
There is no reason why some of the period correct (but not USVTA legal) bodies couldn't be run in an exhibition class, a novice/beginner class, the RCGT class, or any local class that would allow them.
It would be up to a local track director if they would allow an exception for the Corvette for example. However based on the experiences of many racers, one exception invariably leads to more. And if you make exceptions, then you really aren't running VTA any more.
Old 06-28-2009, 09:59 PM   #5385
k_bojar's Avatar
try here:
http://www.rctech.net/forum/electric...ml#post5392736
and read forward Actualy it was about 70ish pages ago
k_bojar is offline
Closed Thread
Georgia Vintage Trans Am Racing shadow102 Georgia Racing 725 02-24-2012 09:56 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Thursday Vintage Trans Am racing at Victory in Green Bay Brian F Wisconsin & Illinois Racing 13 05-10-2008 08:37 AM
