Like Tree1Likes
Closed Thread
Old 02-02-2009, 05:53 PM   #4186
Scottrik's Avatar
Trader Rating: 245 (100%+)
IIR that shallow "hollowing" of the pinion shaft is on the non-sintered and "spec legal" sintered rotors to make them readily identifiable for tech and that the non-spec (larger diameter) rotors don't have that "hollowing". Don't recall where I'd read that, but it seems to me that's what the story was.
As far as TRUE tech (and we sure don't get this tied up about it) it is comparatively easy to use a inductance meter. Novak HAD a very informative dealio about this on their site but now it shows "coming soon".
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline
Old 02-02-2009, 05:55 PM   #4187
RCFREAK's Avatar
Trader Rating: 17 (100%+)
WOW!! ask a question and get the TOP DRIVERS to answer.. good stuff.
I had to ask because, of the race coming up in Feb. and teching motors for VTA needs to be implemented.
I guess the racer was wrong if the 17.5 is also "hollow" pinion shaft.
thanks for the responses!!!
See ya this month!!
Arv.
Arv.
EA MOTORSPORTS// KO PROPO// ORCA// 180 RACEWAY
RCFREAK is offline
Old 02-02-2009, 06:20 PM   #4188
SWTour's Avatar
Guys,
On the NOVAK Motors (SS Pro) ie: 21.5 and 17.5's for this application...
The STANDARD 'Sintered' rotor has the slightly hollow end. This is the Standard (NON TUNING) sintered rotor.
I believe the TUNING (larger rotor) that is not legal for SPEC applications has two grooves in the shaft just outside the can for I.D. purposes.
The 21.5 and 17.5 motors were built originally for our series, and we didn't know what kind of OTHER uses they would get, so we weren't concerned about the COLOR rings on the back like the 13.5s had gone to. However, they have both caught on widely in MANY types of racing now...so I.D. has become needed.
These motors were also ONLY available in the SS PRO version W/ Sintered Rotors. (we didn't feel there would be a need for a NON PRO version to dilute and confuse consumers.)
Joe Myers
R/C Racing since 1985 ~ Santa Maria, CA (Central Coast)
2001-2012 - South-West Tour R/C Oval Series...will the SWT be revived?
Things are headed towards a return of the SWT Series, but for
2017 the focus will be on the Encino Velodrome (and dirt oval racing)
SWTour is offline
Old 02-02-2009, 06:55 PM   #4189
RCFREAK's Avatar
ok cool, the 21.5ss pro does have a hollow pinions shaft.
i dont have a 17.5 to see the ID markings... i just wanted to find a way to check motors without teardowns, if we can avoid it..
thanks everyone!!
Arv.
Arv.
RCFREAK is offline
Old 02-02-2009, 10:09 PM   #4190
nashrcracer's Avatar
R/C Tech Charter Subscriber
and to think no one got video of my first 2 qualifiers at snowbirds
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline
Old 02-03-2009, 04:01 PM   #4191
Wouldnt the only gain with the bigger rotor at the same FDR be lower Temps? With that being said wouldnt it be better to just tech FDR?
RugRunner is offline
Old 02-03-2009, 04:15 PM   #4192
RCFREAK's Avatar
my question was to "TECH" motors visually without teardowns, and of course tech FDR also....
Arv.
RCFREAK is offline
Old 02-03-2009, 05:00 PM   #4193
I wasnt questioning what you had posted but rather asking wouldnt the only gain w/the bigger rotor be lower temps at the same FDR? I was actually agreeing w/ you and asking a question at the same time.....
Old 02-03-2009, 05:22 PM   #4194
DARKSIDE's Avatar
will we see any updates on the upcoming events section on the USVTA web page?
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/OTT/1UP
Apex Raceway and Hobbies
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline
Old 02-03-2009, 05:32 PM   #4195
Thats a good point.....I dont see anyother possible advantge either...
NUCRPTRACER is offline
Old 02-03-2009, 06:03 PM   #4196
RCFREAK's Avatar
understood...
Arv.
RCFREAK is offline
Old 02-03-2009, 06:21 PM   #4197
miller tyme's Avatar
Bigger Rotor would provide more torque. That would allow more punch out of the corners and mean that you could be more forgiving with freeing the car up and could also drive a much tighter line with-out bogging the motor down.
I've been thinking about an easy FDR check. With all the interchanging of pulleys checking the gearing and "knowing" the stock drive ratio doesn't work. I think a small paint mark on the spur and roll the car 1 revolution of the spur ie: 1 motor rev. The car if legal should roll a predetermined distance or less. Quick and easy.
Ken Miller
RCTarget - Capricorn - Pro Level RC - MAX Power - Maxima Fuel - EA Motorsorts - TQ Wire
LONG LIVE OPEN MODIFIED
miller tyme is offline
Old 02-03-2009, 06:34 PM   #4198
reenmachine's Avatar
Trader Rating: 26 (100%+)
One revolution of the spur isn't 1 motor rev. One rev of the pinion is.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline
Old 02-03-2009, 06:38 PM   #4199
Scottrik's Avatar
Correct, BUT one revolution of the spur compared to how much of a revolution the tire makes will give a rough idea of the diff ratio. Then multiply that by the spur/pinion ratio for an approximation of FDR. Probably easier to push one full revolution of the tire and check how many revolutions the spur makes. The TC5 should do 2 revs, the TC3-4 should do 2-1/2, etc.
Scottrik is offline
Old 02-03-2009, 06:52 PM   #4200
Scottrik's Avatar
Originally Posted by ApexSpeed View Post
Wow, I didn't expect that type of FUD from you, Scott. Have you ever seen this flaming geyser outside of YouTube? Fact is, it doesn't happen from over charging these packs. The next ROAR-approved LiPo fireshow I hear about will be the first.
btw Doug...was visiting with a friend who just returned from Snowbirds. There were THREE LiPo fires there (and a close call during the endurance race with someone cooling a motor with canned "air" duster and a spark plugging in the battery--imagine a 3 foot diameter fireball centered on the car. But that's another story...).
One of the battery fires took out the guy's car, laptop, and some other stuff. I bet HE wishes he'd dropped $25 on a LiPo sack!
So yes, FUD indeed. Right? Maybe time to re-evaluate those "facts"? I'm pretty certain the 'birds require ROAR-approved LiPos.
I concede (and did long ago) that LiPo is here to stay, but taking minimally invasive safety precautions is only being smart.
Scottrik is offline
Closed Thread
Georgia Vintage Trans Am Racing shadow102 Georgia Racing 725 02-24-2012 09:56 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Thursday Vintage Trans Am racing at Victory in Green Bay Brian F Wisconsin & Illinois Racing 13 05-10-2008 08:37 AM
