Like Tree1Likes
Closed Thread
Old 11-15-2008, 06:03 PM   #3241
reenmachine's Avatar
Trader Rating: 26 (100%+)
OK, here's the scoop for gearing the Tamiya TB-02 for USVTA 21.5. I geared to 4.37 to start out, and the gear mesh is perfect, so I'm assuming that the other combos will work as well as the methodology to calculate them was the same.
All of the following numbers pertain to 64p gears (use the "hockey puck" spur adapter that came with the kit).
FDR 4.37:
- 74t spur, 44t pinion, motor mount position B.
- I got these from superiorhobbies.com. 44t pinion=RRP4344, 74t spur=XENG640074
- tested and meshes perfectly
FDR 4.28:
- 74t spur, 45t pinion, motor mount position C.
FDR 4.25:
- 72t spur, 44t pinion, motor mount position A.
- 72t spur may be hard to find, but PRS just started making them.
FDR 4.47:
- 74t spur, 43t pinion, motor mount position A/B.
- 3racing mount A/B position will probably work perfectly with this combo
FDR 4.58:
- 74t spur, 42t pinion, motor mount position A.
It wouldn't hurt to use the 3racing motor mount with any of these combos as it gives you finer mesh adjustment.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline
Old 11-17-2008, 08:38 AM   #3242
I'm going to run the Novak 21.5 this weekend with a borrowed Novak XBR ESC to start out with. Since I can't bump the timing in the ESC, should I crank it on the motor? How does one do this?
Pete Waydo
Old 11-17-2008, 03:16 PM   #3243
liljohn1064's Avatar
Trader Rating: 17 (100%+)
I've been told not to even try mechanical timing with the motor. It will shorten the life of the rotor. They come off a lab dyno optimized. I ran mine for the first time Sunday and right out of the package my car was extremely fast in a straight line. Probably too much so. It showed how bad my setup was in the first corner too. Way too much front spring and I was off to the boards. Fixed that and had fun in the next 2 heats and the main.
To make a long story short and quote Ron Popeil and the same time:
"Set it and forget it"
John
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline
Old 11-17-2008, 05:15 PM   #3244
BIG JIM WOODMAN's Avatar
Trader Rating: 85 (100%+)
Default FAST?
I thought the idea was to have fun not see who is the fastest.
Hi, my name is Jim and I am an RC addict!
Old Guys Rule!
Bumper tag anyone?
BIG JIM WOODMAN is offline
Old 11-17-2008, 05:24 PM   #3245
What's the point of your comment?
Do you fully charge your battery packs?
Do you glue your tires?
Do you adjust your gearing?
Do you adjust your suspension or just slap everything together?
Do you lubricate moving parts?
If you answered "yes" to any of the above, should I ridicule you for trying to be "the fastest" implying that you're not out to have fun? The car will still function and circulate around the track without doing those things.
There's nothing shady or overly-competitive about adjusting motor timing. It's just another setting within your control, like everything I listed above.
Yes, VTA is largely about fun racing over all-out competition. However, it still is racing, not a parade.
Pete Waydo
Old 11-17-2008, 05:28 PM   #3246
414MPH's Avatar
+1...
414MPH is offline
Old 11-17-2008, 05:49 PM   #3247
Scottrik's Avatar
Trader Rating: 245 (100%+)
I think the point was that if you're worried about brushless timing in VTA you're WAY overthinking it. I don't disagree with that sentiment, but we all have to find our fun threshhold where ever it may be.
As far as your observations, I can still honestly say that my VTA ride (TC3) has EXACTLY the same settings (whatever the hell that might have been) it had on it when I dug it out of the basement and blew the dust off it almost two years ago now to build our "prototype" Vintage TA car. I STILL can't honestly tell you whether or not it even HAS any oil in the shocks, much less what weight that oil might be. I think the last time the car was "seriously" raced it was stock rubber (it's sprung pretty soft...loses a lot of time in transitions), but it might have been something else. I've replaced a couple broken parts since, but no maintenance, no tuning. Throw a charge in the battery, throw the car on the track. Built with stuff laying around the house. Laugh like hell with the guys everytime we race 'em.
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline
Old 11-17-2008, 06:07 PM   #3248
not-a-lobster's Avatar
I'm with scottrick on this one. I'm currently in the process of doing the same to my tc3. I can't remember having that much fun just watching a bunch of guys just trying to make laps. Could be VTA ends up being most popular for that reason.
not-a-lobster is offline
Old 11-17-2008, 06:12 PM   #3249
Geez, never f-ing mind then. I wasn't trying to start some sort of "who has more fun" controversy here -- I just thought I was asking a simple question about a very mainstream motor tuning practice. I didn't know there were "cool points" for racing with the worst car or that I must not be having fun because I give a crap about how my car performs.
I race a plastic Tamiya TB-02 I got second-hand for fifty bucks, plastic shocks and all.
Maybe you guys are just looking for something to bitch about since Doug announced that there were no motor changes until at least next summer.
From now I'll just keep to myself. Sorry to have disturbed you.
Pete Waydo
Old 11-17-2008, 06:21 PM   #3250
Scooby Horton1's Avatar
When is the motor rule going to change in this class for 21.5?
Trinity,EPIC,Oddy Racing,IRS,Sweep racing,Brown Engineering,Mugen USA,Team Xray,RC America,R.I.P. motorsports,Tekin,Customworks,Parma PSE,Ashford Hobbies,D&K Hobbies, TQ-wire,Local 69 Woodputters Union,Big Ant get well soon!!Quinn my BFF!
Dee Lee is a nut and I don't condone what he will say next!
Scooby Horton1 is offline
Old 11-17-2008, 06:33 PM   #3251
Scottrik's Avatar
Before you get your panties all twisted up your crack, perhaps RE-read the following:
The rest was merely a response to your implication that "everybody does it", not a parade, etc. No, not everybody tunes these things to a razors edge, or even close to it, but if doing so gives YOU pleasure, have at it. THAT'S what was said.
Scottrik is offline
Old 11-17-2008, 07:00 PM   #3252
Racer X79's Avatar
Trader Rating: 30 (100%+)
From my experience (I run a GTB/21.5....same thing), the timing on the motor depends on what kind of gear ratio you want to run and how tight the track is. If I'm running on a tight layout, I'll drop the fdr to around a 4.9-5.1 and back off the timing. It adds more punch coming out of the corners, and you don't have to carry a ton of corner speed. If it's a open layout, I run a 4.5-4.8 fdr and crank the timing all the way for rip on the straights-but you have to be very careful with your corner speed. It's very easy to get the motor/speedo temp up there in a 8 minute race. The best advice I can give is to experiment yourself and see what you like, but it definately makes a diffrence.
--Ermer Racing Inc.--
IDC Precision Machining (www.idcwi.com)--Trackside Raceway (www.trackside.com)--Hounds Hobbies and RC Track In The Back--
Racer X79 is offline
Old 11-17-2008, 07:18 PM   #3253
SWTour's Avatar
reenmachine,
For OVAL racing on short tracks most of the guys have the timing all the way up...with the GTB and the LRP Shpere's I only get so much axle spin out of mine...with the LRP Sphere Comp I get about 500 more RPM
I can't see it helping much on the ON-ROAD but it may....
let me know how it works...
Joe Myers
R/C Racing since 1985 ~ Santa Maria, CA (Central Coast)
2001-2012 - South-West Tour R/C Oval Series...will the SWT be revived?
Things are headed towards a return of the SWT Series, but for
2017 the focus will be on the Encino Velodrome (and dirt oval racing)
SWTour is offline
Old 11-17-2008, 07:42 PM   #3254
k_bojar's Avatar
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Scoob - if you read back a 1/2 dozen pages or so, Doug said no changes at this time UNLESS ROAR does something about approving 21.5 motors...
He said that there's talk about it, but nothing concrete - so the novak's are it...
Bodies By Bean | Team Belly
k_bojar is offline
Old 11-17-2008, 08:00 PM   #3255
I apologize if my comments have offended anyone.
Closed Thread
Georgia Vintage Trans Am Racing shadow102 Georgia Racing 725 02-24-2012 09:56 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Thursday Vintage Trans Am racing at Victory in Green Bay Brian F Wisconsin & Illinois Racing 13 05-10-2008 08:37 AM
