Like Tree1Likes
Closed Thread
Old 11-07-2008, 05:14 PM   #3046
chicagokenji's Avatar
Originally Posted by robk View Post
If the car is scrubbing speed in the corner, forget it.
Rob, what's a racer to do to get speed in and out of corners with a TA car?
Can you post a list of things to try?
chicagokenji is offline
Old 11-07-2008, 05:36 PM   #3047
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Good point! RobK, Isn't it just road race mechanics? at the corner be outside, move inside to the apex and then back out to the edge? As straight a line as possible at the highest speed you can maintain?
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is online now
Old 11-07-2008, 05:42 PM   #3048
robk's Avatar
Trader Rating: 22 (100%+)
You can look at my first post, as that has some things in it. Quite a bit is based on traction level, like I can't say "always run a 12lb spring", but I'll try to point some stuff out I think is important. I hope some guys who have had success will post what they think is important too.
*Relatively soft car- I think the tire compound being what it is, basically from 1996 (lol), you need more mechanical traction than current TC tires. So springs at the very soft range are appropriate. This lets the tire work w/o overloading them.
I really only was able to figure this out last week, since if the tires got hot, they wrapped with fuzz from the track (too sticky). I had seen shades of this in 8 minute main races where the car would get funny handling part way thru the race if you overdrove it.
If you calmed down, it would come back. My car was too stiff, especially in front. Softer=faster, and more consistent for 8 minutes.
*Higher roll centers- I think this is dependent on the car, but if you follow with softer springs, the car will roll more. A higher hinge pin mount will take some of this out of the car. I am now starting to think the front roll center should be equal to or higher than the rear. My car rolled across the nose a lot in the main, and was loosing speed due to this.
Also, Mike Haynes (Dominator of the Gate)has the hinge pins higher in the front than the rear in his setup. Jimmy S (g12314), who was very fast last week, also has higher front pins, and my buddy Kevin K did too. Notice the trend?
I think it works well with the softer springs since it lets the car rotate off the rear end more. Probably helps the front tires from getting roasted too.
*Less Rear Camber- I'm not as sure about this one, but I think you may as well use all of that big honkin' tire. I know that my car didn't get loose at 1* of camber like it did before. Still, not 100% on this...
*Stuff that may or may not be so great....-
Sway bars-I put them on my car since it rolled a lot. I wound up removing the rear bar for the main, but I think it was a mistake. It actually helped control some of the front end roll. The rear of your car actually influences things a lot, especially rotation. The good thing about swaybars is it can keep your car flatter in the corner, but let the weight get on the nose or back to the rear dependent on throttle. Some people don't like them...
Long camber links-I wound up here more by chance than anything. The front needed it, but the rear was unchanged from when I was looking for more rear traction when my car was picking up fuzz. Longer camber links aren't as reactive.
Droop-My car seemed better when I had a lot of rear droop. Not sure why. Normally I wouldn't run a lot of droop, and the track conditions were a bit odd, so I will have to review this.
Hope this helps
robk is offline
Old 11-07-2008, 05:50 PM   #3049
robk's Avatar
What you're saying is true, but if your car is pushing, or is getting abound up in the corner, or it's loose and has no forward traction, all that good driving doesn't help. Practice on the layout will get you faster from the radio end of things. You can't pinch off corners or blow past the apex, but the car has to cooperate.
robk is offline
Old 11-07-2008, 08:55 PM   #3050
Trader Rating: 112 (100%+)
Robk,
Which chassis are you running? I never got a chance to look at your car this past weekend. Were you driving the Stealth Camaro?
Dave
dragracer72nova is offline
Old 11-08-2008, 11:42 AM   #3051
robk's Avatar
Pro4/Murdered out Camaro
robk is offline
Old 11-08-2008, 02:52 PM   #3052
Davidka's Avatar
Trader Rating: 77 (100%+)
Do the brushed guys run bearings in their 27t motors? Seems like they should since the BL motors only come with bearings.
Davidka is offline
Old 11-08-2008, 04:04 PM   #3053
reenmachine's Avatar
Trader Rating: 26 (100%+)
From the rules:
Originally Posted by the rules
Option 1: 27-turn ROAR stock motor: No FDR limit, bearings are not allowed.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline
Old 11-08-2008, 11:26 PM   #3054
roadkill's Avatar
Trader Rating: 139 (100%+)
Send a message via Yahoo to roadkill
quick ? for someone, I am going to order some tires and rims, but kinda need some help.
I have a ft tc4 chassis,with an hpi 65 shelby gt 350 body going on it, what mm wide tires and rims do i need to order, 26 mm all the way around,or 26mm in front and 31 mm in the rear, thanx for the help.
Keeper of the check book, Pit butler,(for hire) President and life long member of the Black Flag Club,
roadkill is offline
Old 11-09-2008, 12:10 AM   #3055
robk's Avatar
26mm front 31mm rear, yes it all fits
robk is offline
Old 11-09-2008, 07:26 AM   #3056
not-a-lobster's Avatar
We got our vta's on the track for an exhibition and all I can say is "Ice driving?" Most of the guys were running 27t and 4 cell. I still need tires and a shell for my tc3 so I just marshalled but it was a riot. My question is who decides what are the legal bodies? Just a question. Definately gonna try the afformentioned set-up tips, thanks.
not-a-lobster is offline
Old 11-09-2008, 07:31 AM   #3057
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
ApexSpeed is the decider of what's legal..
This class definitely has enough choices for drivers - you have bodies from HPI, Parma and Pegasus Hobbies, I think a total of 10 ro 12 all together...
what do you mean by "ice driving"?? I think just about everyone here is running some "basic" rubber setup for the respective chassis and have good luck - carpet however, is a different story
Bodies By Bean | Team Belly
k_bojar is offline
Old 11-09-2008, 08:04 AM   #3058
The vta class is very new at our small club and we are still in trial and error on set-ups hence the Ice Driving term, the cars were very loose. I was just wondering how those particular part numbers for bodies were selected. Also wondering the same thing on WGT bodies but that's for a different thread.
Old 11-09-2008, 08:12 AM   #3059
k_bojar's Avatar
Without answering for ApexSpeed, the bodies were chosed because they most represent the actual cars that ran in the TransAm Class in the late 60s and early 70s (don't remember the actual designation of the SCCA class that they ran in)
if you look thru any photos (and Doug has a few listed on the USVTA website), you'll see most of the bodies that were chosen for this class...
You aren't one of those guys that are trying to "change" the class to meet his needs are you??
k_bojar is offline
Old 11-09-2008, 08:43 AM   #3060
not-a-lobster, what traction compound are you using on the tires? You ARE using traction compound, right? If you are not, the cars will always be loose, if you are running on carpet.
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline
Closed Thread
Georgia Vintage Trans Am Racing shadow102 Georgia Racing 725 02-24-2012 09:56 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Thursday Vintage Trans Am racing at Victory in Green Bay Brian F Wisconsin & Illinois Racing 13 05-10-2008 08:37 AM
