Like Tree1Likes
Closed Thread
Old 09-15-2008, 09:09 AM   #2401
Tubaboy's Avatar
Originally Posted by snoopyrc View Post
Just cut the old tires off with a knife and then clean the rims up with a tire truer and some sand paper.
This only works for foams... not rubber tires.
www.wyomingrc.com | www.wyomingmodelerspark.com
Tubaboy is offline
Old 09-15-2008, 09:35 AM   #2402
padailey's Avatar
Does anyone do a manufacturers points championship? I've been doing one unofficially but just wondering how someone might calculate the points. I've been just adding up the points of each car for each race. Gives quite and advantage to the teams with the most cars... maybe that's how it should be just wondering what other places might be doing.
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline
Old 09-15-2008, 09:42 AM   #2403
Ray Murray's Avatar
Originally Posted by padailey View Post
Not sure what goop is but I've tried Shoo Goo. Worked for awhile but couldn't outlast the tires so I ended up having to use so CA anyway. So it ended up wasted effort.
Here is a link with a photo of what it looks like....I'm not sure if Shoo Goo and Goop is the exact same product. It comes in the same type tube, and probably made by the same manufacturer....
http://homepage.mac.com/rasprague/Pe...adhesive3.html
Ray Murray is offline
Old 09-15-2008, 10:10 AM   #2404
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
that would be a cool thing, but you'd have to get the drivers to comit to run only 1 body for the entire series - ie, I run a mustang now, so I'd use the mustang for the entire series...or else the points would get skewed if someone had a different body each race
Bodies By Bean | Team Belly
k_bojar is offline
Old 09-15-2008, 10:22 AM   #2405
padailey's Avatar
That's true but it hasn't been a real big deal so far mostly just adds a little interest over the course of a series. People are starting to get into it a little more which is why I'm trying to figure out the best way to score the points. Example is we had Mopar score 16 podium finishes but only had 3 cars... but Chevy won the points with only 9 podiums but had 6 cars. Probably need some different scoring or Chevy will pretty much always win.
So only score the top 3 finishes? Only score the top 3 (or top 5) finishers of the race? A main finishes?
Tamiya TRF416X
padailey is offline
Old 09-15-2008, 11:38 AM   #2406
IndyRC_Racer's Avatar
While there are some differences in bodies and handling characterics, I think a more interesting points series is a "constructors" or chassis series. This wouldn't limit a racer to a specific body but would be an interesting way to generate some healthy rivaly between different brands and eras of chassis.
For example last Friday at my local track, the top 4 racers were qualified on the same lap within 4 seconds of each other and were as follows:
1. Assoc. TC5
2. Assoc. TC3 (me)
3. Xray
4. Losi JRXS.
I think in R/C racing that people are more loyal to their chassis than a body. I also think that some people would be more willing to drag out an old chassis to earn some bragging rights. I've gotten as much enjoyment out of beating newer cars with my HPI RS4 Sport 2 (with gear diffs) as anything else in this class.
I'm not suggesting that we all run old junk or prevent racers from buying new cars. But I think if you had a point series based on chassis and showed newer/currently inactive racers that you don't have to use the latest and greatest or most expensive to have fun it will help the further success of this class.
IndyRC_Racer is offline
Old 09-15-2008, 05:02 PM   #2407
414MPH's Avatar
What I really love about this class was front and center at the Hurricain race at Trackside last weekend. The top two qualifiers ran the same chassis and it has been out of production for over 7 years.
A well balanced and tuned chassis is as capable at T/A speeds as the newest out there.
Marty
414MPH is offline
Old 09-15-2008, 05:05 PM   #2408
TwoTone's Avatar
Guy more advice please.
Well I sold my XRAY after I realized it was way more car then I needed for TA.
Just picked up a used TA 05R for $76. Any one running one of these, need set up advice. If I need something, I want to get it coming.
It's basically stock
TwoTone is offline
Old 09-15-2008, 05:14 PM   #2409
Micro-Man's Avatar
But for the most part it already is like that.....Around my part of the country the VTA is bringing out both old and new cars and also both old and new drivers.....I have seen them all in the last two months.....The best thing this class has going is the vintage look, being able to run any tc chassis and the mix of combos and FDR that keeps the Field close and intense (as long as you drive clean and smooth).....No matter what chassis you use the main goal is to keep everything freed up and in good condition.....
On another note....dose the 21.5/lipo set up only limit you to using a 2c 7.4 5000mah or can you run 6 cell nimh with the 21.5 motor....asking this to answer a question that just came up locally......Thanks for the help
Many Thanks to all my great sponsors:
CASTLE CREATIONS / MAXAMPS.COM / GQ AMERICA / PARMA / THETOYZ.COM / EXOTEK / TEAM SCREAM / BROWN ENGINEERING / BIG SQUID RC / SK MOTION / HB TEAM DRIVER
"MICRO RACING FOR LIFE".....SUPPORT YOUR LOCAL TRACKS AND HOBBY SHOPS
Micro-Man is offline
Old 09-15-2008, 05:18 PM   #2410
reenmachine's Avatar
Trader Rating: 26 (100%+)
I run a regular TA05 in sedan, and everything it needed you pretty much already get with the R model, especially at USVTA speeds. What surface are you running on? A typical asphalt starting setup is blue front and yellow rear springs, 60wt. oil front 40wt. rear, 1-2 front toe out (depending on your needs), 2 rear toe in, 1-2 negative camber in front (I run 2), 1 negative camber in the rear, 5mm front ride height and 6mm rear ride height. Everybody does it differently of course, but that will get you going. I also like to run a front spool on asphalt.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline
Old 09-15-2008, 05:18 PM   #2411
Micro-Man's Avatar
Right On.....414MPH......Well said.....I agree 100%
Old 09-15-2008, 05:38 PM   #2412
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
TA has been the best breath of fresh air to RC since Tamiya TCS races. and i still havent raced yet. maybe some year.
R
UltegraSTI is offline
Old 09-15-2008, 05:38 PM   #2413
TwoTone's Avatar
Thanks for the setup, but I'll be running indoor high grip carpet
TwoTone is offline
Old 09-15-2008, 05:44 PM   #2414
Scottrik's Avatar
Trader Rating: 245 (100%+)
The easiest way is to award "points" only to the relative placing of the top finisher for each mfr. Say your finishing order was:
Camaro
Mustang
Mustang
Camaro
Mustang
'Cuda
Then Chevrolet would get 3 points for the highest finish that day, Mustang woudld get 2 points for the next highest "relative" position among the three, then Plymouth would get 1 point for the third relative placing. The second, third, etc. from each marque don't figure into the equation.
This is, actually, very much how points were kept for the first several years of the TransAm, though I think it was points from the top two placing cars for each mfr and it had to do with actual finishing position. That gets quickly corrupted, though, when you have a dozen Mustangs, half dozen Camaros, and one 'Cuda.
There wasn't a "Driver's Champion" in TransAm until 1971 or so. The preceding years "Champions" that show up in the literature (1966-Horst Kwech/Gaston Andrey[tie], 1967-Jerry Titus, 1968-9 Mark Donohue, 1970-Parnelli Jones) were "named" after the fact by going back to the record books and applying points. None won any sort of "Trans Am Champion" trophy, etc, in the day.
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline
Old 09-15-2008, 06:04 PM   #2415
weracerc's Avatar
Trader Rating: 36 (100%+)
Default pink paint for cuda
who has done a panther pink cuda? what paint did you use?
weracerc is offline
Closed Thread
Georgia Vintage Trans Am Racing shadow102 Georgia Racing 725 02-24-2012 09:56 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Thursday Vintage Trans Am racing at Victory in Green Bay Brian F Wisconsin & Illinois Racing 13 05-10-2008 08:37 AM
