Like Tree1Likes
Closed Thread
Old 08-02-2008, 03:11 PM   #1951
414MPH's Avatar
I have a concern on the FDR for 21.5 / Lipo that comes from the following facts:
a)When USVTA allowed the 4 cell / 17.5 power combination, there was a final drive ratio minimum rule of 4.0 on 1/12/08.
"Next, anyone who thinks that the 17.5 on 4-cells is slower than a stock brushed motor seriously missed the gear ratios. This motor can easily be made to be faster than a brushed stocker, even on a small and tight track." (ApexSpeed)
Also on 01-28-2008 "One, not a single person racing or watching can tell what car had brushed or brushless. And the best point to make was that the two fast laps in the A-main last night were a 13.131 (brushless) and a 13.159 (brushed, and A-main winner). Both cars wheeled by fairly accomplished racers." (ApexSpeed)
b)The spec was later revised again on 02-27-2008 to NO final drive min ratio because the stock motors were still faster. (or were the brushless guys not happy getting beaten with their motor choice?)
"After much deliberating and taking feedback from many tracks and racers around the country, the 17.5 brushless motor final drive ratio limit of 4.00 has been officially removed from the USVTA rules. This includes the Nationals in April. It will allow brushless racers to be able to adapt to different sized tracks without feeling like they have no chance to keep up with well-tuned brushed motors." (ApexSpeed)
Also, on 01-23-2008, 01:57 PM Doug said "Don't bother with calculating rollout—the tires are all the same for everyone." (ApexSpeed)
Anyone who has run this class as long as I have knows the tires "break in" and expand over time, and a FDR limit will result in a very different top speed between new and "broken in" tires.
My questions are:
1) Does USVTA recognize the difference in tire diameter between new and "broken in" tires?
2) If the 17.5 needed a gear limit to even the speed at first, what changed to have the FDR eliminated for 17.5? (just more options? Optiona are good.)
3) How long will the USVTA FDR for 21.5 last, and was it established with new (small dia) or broken in (large dia) tires to compare speeds/times with the other power options?
I can only hope as we enter the new indoor season that the USVTA has gained much knowledge and experience in the past 6 months before they established the 21.5 / lipo FDR.
Marty
414MPH is offline
Old 08-02-2008, 03:29 PM   #1952
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
Marty we just had a parking lot race in chicago and some very good drivers including some National A main foam tire regulars ....
Here is the low down on all the motor and cell combos......
4 cell brushed motor was the TQ ( chris goetz ) over rob king (21.5 / lipo) and a guy from Indy named Kris( 4 cell brushed)
The winner of the 8 minute main was the 4 Cell BRUSHED motor.
I believe the FDR limit was removed from the 17.5/4 cell combo because that combo is almost identical to a 4 cell brushed motor ( freshly cut ) .. The former FDR limit of the 17.5 is still the best place to gear that motor for The Track at Harbor hobbys(IL) and Trackside as well... gearing up will give you a tad more straight away speed but you will suffer from no infield rip and same goes for gearing down ... better rip but not enough on the straight.
The 21.5 / lipo has a FDR cause it is a Lipo ( 7.4v) I am not sure it will be removed anytime soon cause the 21.5 /lipo combo was right there with the rest of the motor/battery combos.
I personally believe the 21.5 / lipo combo is the best for club racing.. i know its a little more money for the speedo, but you can use the lipo in your regular touring cars, offroad stuff , so you dont have to buy 4 cell packs just for this class. And at the parking lot race i did run the same lipo all day and it just got better through out the day as the cells got warm from the charge and then discharge( race) .
And even with all the talent in the race the club level racers at this event ( guys running all different motor/battery combos) were all very close to the higher talent level guys.
wallstreet is offline
Old 08-02-2008, 03:34 PM   #1953
reenmachine's Avatar
Trader Rating: 26 (100%+)
Man, I didn't realize there was a $100,000 prize now! Doug, when was the $100,000 prize announced? How come no one told me about the $100,000 prize?????
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline
Old 08-02-2008, 05:47 PM   #1954
IndyRC_Racer's Avatar
I ran at the Chicago race and ran a 21.5/lipo. Thinking about why I didn't do better (was about 1 lap off TQ), was that my speed was a bit too fast for my setup. I was running as close as I could to the 4.2 limit, but my car was pushing at different places. In hindsight, I think I would have been better to gear to be slower to drive the infield better than worry about the straight - which was very long. All the cars looked about the same speed on the straight.
I normally run on a very small carpet track in Indy. The ozite isn't the rubber backed "good" stuff so bite is an issue. Last night I geared my TC3 to the max FDR for 21.5 and really only ended up heating up my motor because I was over-driving the corners. I slowed the car down by dropping a few teeth and the handling and motor temp was much better. I'm beginning to think that unless I have the setup perfect, that I'm not always going to benefit from using max FDR.
Last week I ran a 4-cell/stock combo on the same car. My car was just as competitive as any of the 21.5 lipo cars. The ONLY thing that was killing me was exit speed as my car was bogging down in the corners. Other than that I was able to out-drive the lipo cars into the corners.
IndyRC_Racer is offline
Old 08-02-2008, 06:21 PM   #1955
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by 414MPH View Post
My questions are:
1) Does USVTA recognize the difference in tire diameter between new and "broken in" tires? Marty, I ran both tires that were literally about to rip themselves apart, due to age, and fresh tires. I honestly couldn't tell a *straightaway* speed difference. The car was different in the turns, but I don't remember a top speed difference. I actually blew out the tires practicing, and had to put new tires on, so it was almost back to back.
3) How long will the USVTA FDR for 21.5 last, and was it established with new (small dia) or broken in (large dia) tires to compare speeds/times with the other power options? From what I know, a couple tracks were testing this out for Doug, including Mimi's The Track in MD. The tracks both came to the conclusion that 4.2 -4.3 was the right gear. Doug would have to come up with exactly how things went down, but I know these guys were racing the 21.5 for a while. I can't imagine they were slapping fresh tires on constantly.
Marty
Having run 21.5 for the 2 day event last weekend, I'm not quite sure if brushed motors are not faster on larger tracks due to the gear rule. Certainly Chris Goetz and Kris Polonczak (hope that's right Kris) were very fast with brushed motors. I thought that the 21.5 was just as fast, and may have been better out of the corner vs. down the straight, but the racing was very tight and average laps were very close.
ave. lap
1st Round Chris Goetz 16.672 Rob King 16.876
2nd round Kris P. 16.965 Rob King 17.032
Main Kris P 16.627 Chris Goetz 16.747 Rob King 16.634
I tried to use clean runs vs. the ones where there were multi 20 second laps, but you get the idea.
robk is offline
Old 08-02-2008, 07:26 PM   #1956
wallstreet's Avatar
If you are running on a smaller track you will always wanna gear down no matter what setup your running for power...
Old 08-03-2008, 10:52 AM   #1957
414MPH's Avatar
Thank you to all that have replied.
From what I read, it sounds like natural motor tendencies regarding gearing are dictating final drive ratios for the various tracks as I would have expected.
I don't have a problem with the 21.5 FDR, just had a few questions. The Lipo / 21.5 has allways been on the horizon and is deffinatly good for the class.
Any feedback on the tia dia question?
Marty
414MPH is offline
Old 08-03-2008, 12:22 PM   #1958
sportpak's Avatar
Marty
How much difference is there between new/worn tires? 1-2mm at best? The FDR is sort of irrelevant because track size and driving style are what counts when selecting your FDR. To think you can just put the minimum FDR on and be competetive on every track is kind of crazy, so don't worry about the few cat hairs difference in rollout. Getting the car through the corners as cleanly and efficiently as possible matters the most.
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline
Old 08-03-2008, 03:39 PM   #1959
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Marty
I don't know how "typical" my results are, but here are the diameters of mine...
a Brand New, just opened and mounted set are:
64.38mm front
64.58mm rear
very, very, very used rears on asphalt -and roughly 40 mins of runtime yesterday (saturday) alone:
64.28mm front (my fronts are almost bald in a couple of places)
64.5mm rear
so hardly any wear - so tire diameter shouldn't play a part in any roll-out calculation...tire diameter is normaly ONLY for foam tires because so much wears off them run-by-run...
Bodies By Bean | Team Belly
k_bojar is offline
Old 08-03-2008, 04:59 PM   #1960
wallstreet's Avatar
Those are about the same numbers i have seen on fresh tires to old tires..
Not really enough for a pinion change especially since most cases you will actually be able to work under the fdr cause of the different track sizes.... people may find out that they cant run the fdr of 4.2 cause there track is just not big enough so then if you are down a few from the 4.2 you can make an adjustment in pinion size to go along with the very small change in tire size. I think the 4.3 might not be the best gearing for the cars indoors... remember its the max limit that doesnt mean its going to be the fastest for your track.
Old 08-03-2008, 05:13 PM   #1961
padailey's Avatar
That's interesting on the tire diameters. I'll have to check mine because my used tires are noticeably bigger. Maybe an optical illusion!
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline
Old 08-03-2008, 09:57 PM   #1962
DARKSIDE's Avatar
we are recomending a 6.0 for brushless and 9.0 for brushed...when running our club combo of 27t/17.5 and 6cell/lipo....I tried it on both my cars and my speeds were great....and very close as a result of a heat in todays race with 5-6 guys all on the same lap...its not a rule for us but seems to be the right combo for what we are running on a club level.......
ps...I would hope in the near future the USVTA changes the rules on 4cell setup and lipo....a FDR works great IMO and helps keep everyone equal without the 4cell....even running a "FASTER" setup will slow you down with the FDR...we have had awsome results with attendance and FUN factor with what we are running...you dont get this many ppl to show up if you are not doing something right...just hate going against the grain, but it is whats best for our racers and tracks...
our race director said it best......"FUN,FAIR,CHEAP"
this is just my $0.02....and hope it helps some of you get your class built-up to your liking...its a wonderful class to race in and if you get setup right..its limitless to what you can do with it...cya and thanks for listen...
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/OTT/1UP
Apex Raceway and Hobbies
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline
Old 08-04-2008, 05:18 AM   #1963
k_bojar's Avatar
but you are running nothing more than Stock TC with a restricted gearing - oh yeah, and vintage bodies and tires...its missing the point of this class...
We just run a demo on Saturday with EVERYONE running the 27/17.5/4cell combo - and we got at least 12 - 15 mins of run time from the packs...why do you need more?? I cannot think of the number of people that came out to watch that walk into the hobby shop and asked about one of the cars were running outside, I saw at least 2 people leave with kits under their arms...
Are you (or anyone) policing the the gear ratios every run to make sure EVERYONE is sitting at 6 or 9 FDR? What do you do when a chassis does not exactly make a 6.0 or 9.0 FDR?? I think from personal experience (ran/moderated a spec class at my local track for 2 years), that not every chassis get even number FDR - they are usually a little under or WAY over...and right there, you don't have equal cars - and allow room for "massaging"
k_bojar is offline
Old 08-04-2008, 07:34 AM   #1964
snoopyrc's Avatar
OK. Doesnt Darkside run with us in Calhoun? Where we follow the VTA rules? Even if he is running somewhere that runs six cells and lipo, or stock powerplant. Thats not the same as running stock TC. The shell and tires make that much difference.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline
Old 08-04-2008, 07:47 AM   #1965
Scottrik's Avatar
Trader Rating: 245 (100%+)
Hey, however people have fun they have fun. It's close enough to Stock TC, though, to be a virtually indistinguishable driving experience. That will, over time (how much remains to be seen) doom the class there to being yet another novelty class. What will give Vintage Trans Am legs is if it provides a distinct driving experience which is exactly what the 4-cell origins of the class created.
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline
Closed Thread
Georgia Vintage Trans Am Racing shadow102 Georgia Racing 725 02-24-2012 09:56 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Thursday Vintage Trans Am racing at Victory in Green Bay Brian F Wisconsin & Illinois Racing 13 05-10-2008 08:37 AM
