Old 01-03-2008, 08:12 PM   #301
corallyman's Avatar
Trader Rating: 99 (100%+)
1/12th scale hasn't used 7.2 volts in ages. With the cells out now, with the voltage numbers and the low IR, I can't see the Josh Cyruls or Mike Blackstock, Dumas' of the world keeping them on the carpets.
They would be like the indoor Heli's
Steve
corallyman is offline   Reply With Quote
Old 01-03-2008, 08:14 PM   #302
Ike
Ike's Avatar
Originally Posted by Unregistered View Post
The colored "ring" on the Novaks is the plastic ring on the endbell. It's not removable. Also, you can check the inductance of a BL motor as a check for wind.
I've run a 3.7vLiPo in 12th. Used a standard Novak 4 cell speedo and it didn't have any problems. All you need for "new" equipment is a receiver pack. They're really not all that expensive. Personally I would prefer 2 cell voltage in mod 12th
What motors did you try with the Lipo? Seems to me like 17.5 would be painfully slow.
Ike is offline   Reply With Quote
Old 01-03-2008, 08:16 PM   #303
Ike
Ike's Avatar
Steve
Think Mercedes CLR...
http://www.youtube.com/watch?v=rQbgSe9S54I
Old 01-03-2008, 08:17 PM   #304
The 7.4v LiPo that I used was slower than 4 cell. It had a lot less capacity so it would dump if you drove it hard. It might even dump a 13.5 in 8 minutes.
Again, I think LiPo for 12th is a ways off.
Unregistered is offline   Reply With Quote
Old 01-03-2008, 08:25 PM   #305
corallyman's Avatar
Originally Posted by Slapmaster6000 View Post
This may not be the proper time to chime in with this, but I have been working on a 12th scale project that uses Mamba motors, esc, a 1550mah 2C lipo and a $19 9 gram servo. Just to see if it would work. I chose an 8kv motor, which was a mistake. It's the fastest thing I have ever driven. Here's the kicker, it only weigh's 14.5 ounces! I plan to pick up a 4.6kv motor and retest. When I say this car is faster then todays mod cars, trust me, it is. The wear and tear on this car is far less then our 30 ounce equivelants. I don't have all my testing done, so there is no reason to get too excited yet. But if we are going to wipe the slate clean and draft up new rules for the 12th scale guys, this is really should be considered. I know there are going to be many that are going to say: "I can't use any of my old equipment". To a degree, that will be true. But if we are going to look at the health of a class, would lower cost with equal speed not be worth talking about? You will be able to put this car on the track for 2/3's the cost of todays car, plus you will not need all the peripheral additional equipment.
This was posted last night, its just something he is playing with. I will see this car soon I am sure but Brian has been doing RC for 15 years so he has a little experience
I think we need to back of on the 12th scale worries as I doubt that much in the rules will change for 2008.
Steve
Old 01-03-2008, 08:41 PM   #306
TVMRocket69's Avatar
Send a message via AIM to TVMRocket69 Send a message via Yahoo to TVMRocket69
IMO. U need to keep 27t BR motors in competition. Just findout which BL is close that way newbies can have a choice and your not forcing veterans to change or quit.
Bob Walker Jr.-Sponsor's-
AnswerUSA-RC Team Driver, G's R/C Raceway Team Driver, RBMods Team Driver, Kosmic R/C Fuel Team Driver, MurfDogg Motorworks Team Driver, Serpent S811B, Serpent S811t, MurfDogg Powered V-Desizn Carpet Ripper 5
TVMRocket69 is offline   Reply With Quote
Old 01-03-2008, 08:43 PM   #307
Scottrik's Avatar
Trader Rating: 245 (100%+)
Then I was racing with his double almost 20 years ago. And, I'm pretty sure, YOURS. Raceway in Edmonds ca. 1988-90, Dave and Georgia Steen...possibly the nicest people in RC. Ah...those were the days. 1200 SC's, Trinity "mod" motors with those eensy-weensy little brushes and even smaller springs. Getting lapped (and lapped, and lapped) by Chris White...
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 01-03-2008, 08:56 PM   #308
Mason's Avatar
Guys, with 7.4v in 12th scale the motor would be something far slower to compensate. Steve could figure out roughly just how many winds they really could go with the current wire size, and if possible/needed, something thinner. Can also change rotor magnet length. There are numerous somewhat simple ways to offset the voltage increase. capacity can be had with different configurations. magically orion has 3 batteries nearly identical size but 1600mah in difference. 3200 - 4800. Either they're not using the space or the batteries are some how magically getting better. polymer can be made into literally any shape. Don't be surprised if somebody lays out a chassis with a battery going as far forward as the servo while mounting the receiver and speed control on top of it. Could really shorten those motor wires.
stuff like this should be standard reading for anyone involved in this conversation.
http://en.wikipedia.org/wiki/Lithium_polymer
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 01-03-2008, 09:30 PM   #309
corallyman's Avatar
Dave, Georgia and the legend Ron. Yep I was there, even before Brian B.
Chris White is the first person I met, when we moved back to Wash. The best of times.
Steve
Old 01-03-2008, 09:36 PM   #310
Bob-Stormer's Avatar
I'm with "Slappy" on this. I've done similar testing with smaller BL motors, and I'm positive Cyrul has too. It makes a HUGE amount of sense. I'm more of a higher voltage kind of guy too. And if Lipo were to be a logical path for 1/12th, then let's up the voltage. Less radio drop outs, easier power. Potentially longer races, lighter car=less damage. Lot's of positives.
www.stormerhobbies.com "Where the world shops for radio control."
www.facebook.com/stormerhobbies
www.twitter.com/stormerhobbies
looking for....vintage 1/10-1/12 pan, need Schumacher 1/12th cars and parts.
Bob-Stormer is offline   Reply With Quote
Old 01-03-2008, 09:38 PM   #311
skypilot's Avatar
Trader Rating: 14 (100%+)
having being one of the few that had the opportunity to see brians stupid fast 1/12 scale, all i can say is what the..... it is doable, only need to install a tamper proof voltage regulator. actually a 7.4 volt lipo with a 13.5 brushless might be driveable.
skypilot is offline   Reply With Quote
Old 01-03-2008, 09:55 PM   #312
Skruger's Avatar
Trader Rating: 16 (100%+)
Just great ,Restrictor Plate's in Electric RC Racing
ROAR # 11-118753 / MATT #11-118754
MECH # 11-118755 / RYLEE #11-118756
RIP :Loretta Plueard 2017
SUPPORTING NORTHWEST HARVEST --- WWW.NORTHWESTHARVEST.ORG THE HUNGER STOPS HERE
Skruger is offline   Reply With Quote
Old 01-03-2008, 09:55 PM   #313
[QUOTE=TVMRocket69;4036035]IMO. U need to keep 27t BR motors in competition. Just findout which BL is close that way newbies can have a choice and your not forcing veterans to change or quit.[/QUOTE
I can't help but think the majority of racing gripes I've heard through the years are based on 27t BR motors. His is faster, mines a dog, what brushes are those? etc...etc... Nobody complains more frequently or loudly than the stock racers that aren't "in the hunt".
That's my personal observation. Doesn't make it right or wrong.
Also, anybody that might feel they were forced out, or had to quit over something with a value of say $75, just how committed to the hobby are they? Especially if the item was designed to bring equality to that persons race program. ALSO, in the case of a motor, there is no reason a racer couldn't sell the old equipment that is not useful for their race class, and very likely be into the new equipment for free.
Brushless may or may not be the answer, but it's likely to lead us to the next thing that is. Just like Solar power and full size electric cars, and computer processors. Anybody that's ever paid over $2500 for a one gigabyte hard drive knows what it's like to pay to improve the items they love, or to improve the technology for their hobby and general interests.
I paid $1500 for my first in home CD player... We were the first company in the state of Montana to have a 2 gig drive for a Mac Quadra. Don't even ask me what we paid for that. My phone now has more memory, and on a card the size of my fingernail.
I'm not on a crazy tangent. Just trying to point out that we are in an interesting spot now with RC. Technology has got us to a point where 99% of us have WAY TO MUCH POWER, and we can actually electric race vehicles at good race speeds for up to 20 MINUTES!
The question is, where do we go with it? Races are to short for one thing. That makes it a poor value if you compare it to things like owning and riding a four wheeler, or dirt bike, etc.
And making things cheaper is not the right answer. If it was, paper airplane competitions would attract massive crowds. What's it cost to fold up a paper airplane? How much is a good dirtbike, about $6 grand.
We don't need a stock equivalent motor. We need a BL motor that is SUBSTANTIALLY slower than stock. Stock is NOT A CLASS, it's a motor. So we need a motor that works for people that don't want to go as fast, and for people to learn with.
The other thing those people need is track time. You don't develop a lot of skill with 15 minutes of practice a week... Nor is it a good "value".
Not sure I did anything here but ramble... but there it is anyway.
Old 01-03-2008, 09:57 PM   #314
It's been discussed. The item has to be BIG, it's not that it has to carry a lot of voltage, it's the current, and subsequent heat that is the killer.
Old 01-03-2008, 09:59 PM   #315
Still waiting for my pic on your site. lol Any chance you making it to the birds. The pig will be there...
Team Associated, Reedy, Tekin, Futaba, Putnam, Protoform, BSR, SXT, Reflex Racing, McPappy Racing, TQ Wire, Swifty Designs
Jeff Cuffs is offline   Reply With Quote
Roar Brushless motor debate thread. *Chrominator* Electric Off-Road 173 01-18-2008 10:52 AM
New ROAR rules Rfury Georgia Racing 9 01-16-2008 12:58 PM
Roar Rules rollagen Nitro On-Road 1 08-06-2007 06:04 PM
? on ROAR rules gator Electric On-Road 2 11-23-2002 12:13 AM
ROAR rules LooseCannon Nitro On-Road 18 09-08-2002 11:03 PM
