Old 01-02-2008, 07:08 PM   #16
Mr RCTech's Avatar
Thumbs up
Take a good look at the Snowbird race that draws racers from around the world every year.
Its the biggest and most popular race of the year.
What classes and rules do they use?
ROAR should look at the Snowbirds rules and consider them for guidelines.
Its my favorite race of the year!!
Mr RCTech is offline   Reply With Quote
Old 01-02-2008, 07:10 PM   #17
Trader Rating: 45 (100%+)
IMO...Keep it simple with only two brushed\brushless motor classes...We all know brushless will prevail in the end so might as well gear the classes towards brushless now.
Stock - 13.5 or higher and 27T
-Going any higher and experienced racers will get bored with Stock
-Run Brushed 27T in the same class.
Mod -13.5 or lower (for TC - go to 5 cells)
-Run 5 cells in Mod TC like the rest of the world and slow the Mod cars down
-Run whatever Brushed motor you want.
Also, make TC's run only rubber tires on all surfaces. Leave foam racing for 1:12 and GP cars.
Apex is offline   Reply With Quote
Old 01-02-2008, 07:11 PM   #18
Scottrik's Avatar
Trader Rating: 245 (100%+)
Originally Posted by jiml View Post
Stock racing was supposed to be everyone had the same motor, and the same power. Replacing brushes or springs means you have changed, or modified, the motor. Kinda defeats the purpose.
Guess maybe it's because I started out in a different part of the country than you when I entered the hobby in '86. Yeah there was less that could be done to a Stock motor, but there were always alternate brushes available and folks playing iwth spring tensions, etc, while hunched over their Shinwa Motor Dressers. I've still got mine...may as well have used it as a hammer for all the good I could get out of the darn thing.
Originally Posted by SWTour View Post
And MANY of them have found the 13.5s are quite abit faster than STOCK was, and they are having a hard time with NEWBIES getting their cars under control.
Don't GET RID of 13.5, but add 17.5 as an option for a more 'entry' level class.
MOST people don't currently run MOD - which I feel is one of the reasons many were pushing for 4 cell and 5 cell - to give MORE control to OPEN mod motors (instead of restricting the motors in the first place)
With 4 options
17.5
13.5
10.5
OPEN MOD
you have 4 choices that will cater to virtually any speed range needed.
Oh and if you want a REALLY SLOW NOVICE bound motor - try the 21.5 we're using on the Ovals as OUR Stock Replacement for '08 (EVEN THAT MOTOR is faster than what STOCK was)
I'd agree with MOSt of this. I'd propose:
17.5--let's at least TRY to get back to a power level beginners can handle (heck, I wouldn't be opposed to 21.5 since I've seen for YEARS that less power = closer racing)
10.5
Open/Mod
And do away with the 13.5 level. OR create an 11.5 or 12.5 that creates more gap between that class and Open/Mod and maintains a reasonable performance step up from the "entry" class.
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 01-02-2008, 07:11 PM   #19
Trader Rating: 16 (94%+)
Originally Posted by C_O_jones View Post
If all the current 13.5 motors become obsolete to create a spec BL for stock, why not just make it a 17.5 that will be able to run with current stock brushed motors?
Because of the gearing issue. The 17.5 motors only turn about 2,200 rpm's per volt, or about 16,000rpm's. A 13.5 motor turn about 3,300 rpm's per volt, which can reach 25,000 rpms on average. This would mean running pinions in the 50+ tooth range for a 17.5, needing to run around a 2.5 to 3.0:1 FDR.
kn7671 is offline   Reply With Quote
Old 01-02-2008, 07:13 PM   #20
Because a good brushed motor can run with the 13.5 motors at least in touring. We have had racers with certain tuners motors(Tag )run as fast or faster than the 13.5. If you use the 17.5 as the stock replacement it will not compete with the stocks in most conditions. If you get to 13.5 with Lipo against Stock with NiMH the stock will stomp the 13.5 in most conditions.
tarheelquality is offline   Reply With Quote
Old 01-02-2008, 07:16 PM   #21
AdrianM's Avatar
Originally Posted by Ike View Post
Just about every track in the country that allows BL has been using 10.5 as the replacement for 19T and 13.5 as a replacement for stock. In other words, many people already have those systems, ROAR changing that fairly widely accepted format will make things more expensive for those that already have systems. Yes, I know people would just have to buy a new motor, but BL motors aren't cheap. Plus, I've heard of people having issues even being able to gear high enough with a 17.5 in a pan car. Which then all of the sudden means there may be certain cars that will become obsolete in favor of car designs that allow for more pinion, people buying pinions they wouldn't normally use, etc.
It just doesn't seem feasible to find a close match with a stock motor and a brushed motor at this time with what is currently available. Doesn't it seem likely that if 13.5 was allowed to run in stock class that brushed motors would become obsolete (it's already happening), at least for a while... If 17.5 is allowed to run with stock brushless motors will be dumped in favor of a good brushed stock motor. Does ROAR feel comfortable with either of those things happening? It seems to be that weight allowance is the one thing that could help even up the current technology of brushed vs. brushless. It's something that many real racing series use as an equalizer and it's cheap... Increase the weight required for 13.5 and or decrease the weight for 27T. The problem is those weights need some time to be researched, I don't see it as something that can get worked out in a couple weeks time.
Here the deal....
Racers bought into BL because it was new, cool and made racing more fun. Rules were not in place to govern these motor because no one...not even the manufacturers of these motors knew what would end up being equivalent to existing brushed motors.
If you recall 2 years ago the Novak 4300(10.5) was supposed to be a stock motor and the 5800 (8.5 was supposed to be a 19T. Both were too fast.
Then it was 13.5 and 10.5 with bonded rotor but the rotors were a problem and they went to sintered rotors. The 13.5 became faster then stock but the 10.5 was right at 19T level.
Now finally it seems 17.5 is the right equivalent to a 27T stock motor.
The racers that bought BL motor were on the bleeding edge of motor development. I know I was aware that the BL motors I was buying my not be legal in the future and would need to be replaced at some time. I have mentioned this time and again over the last two years. Well...experiment time is over. Its time to write the best rules we can even if it is inconvienent.
ROAR has 2 responsibilities.
1. Look out for the racers interests
2. Look out for the health of our hobby
Sometimes these two goals are at odds with each other.
In this case racers have bought motors that may not be in the best interests of the hobby. Its pretty clear that 13.5 is too fast for stock class racing and for novices getting into the hobby. 17.5 are much better.
Here is my suggestion:
I believe that ROAR should make rules for to govern BL racing that are ideal for Regional and National level racing. This means BL motors that are equivalent in speed and power to the existing core National level classes. This keep things similar to what we are running now and doe not add new unnecessary classes.
17.5T/27T Stock/Spec BL
10.5T/19T Spec Mod/Spec Mod BL
BL/BR Open Modified
Those racers with 13.5T motors can continue to race them happily at the club level for as long as there is interest in continuing to run them. The rules for 13.5 will not be written but will be controlled by local race directors with guidance based on the ROAR rules just like everyone is doing right now.
We really don't need more classes.
Adrian Martinez
Old 01-02-2008, 07:17 PM   #22
ASM
ASM's Avatar
Trader Rating: 21 (100%+)
The 10.5 needs to stay as an available class.
Scott Meeks
2016 & 2017 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 01-02-2008, 07:21 PM   #23
SWTour's Avatar
WOW 16 classes for the '08 SNOWBIRDS
Looks like this years BRUSHED classes may be over taken by the Brushless..time will tell...but I bet NEXT year you'll see MORE LIPO (This year only gets LIPO in 4wd Oval TRUCK I believe)
Joe Myers
R/C Racing since 1985 ~ Santa Maria, CA (Central Coast)
2001-2012 - South-West Tour R/C Oval Series...will the SWT be revived?
Things are headed towards a return of the SWT Series, but for
2017 the focus will be on the Encino Velodrome (and dirt oval racing)
SWTour is offline   Reply With Quote
Old 01-02-2008, 07:23 PM   #24
AdrianM's Avatar
I think even if you can make a 27T run faster then a 17.5 27T motors will be history in one year. 27T motors are a pain to keep in top condition. You have to cut and rebrush every run and if you get them too hot outdoors in the summer you need a magnet zapper or a new motor to be fast again.
17.5 BL will rise to the top over 27T even if it is a bit slower.
Here is a similar example:
Its pretty clear that IB4200's are the fastest cells out there...but...racers are buying EP4200's and LiPo's like crazy because even though they are a little slower racing is cheaper and more enjoyable with them.
Let ROAR make the rules that are best for the long term longevity of our hobby.
Adrian Martinez
Old 01-02-2008, 07:24 PM   #25
RBLove's Avatar
Trader Rating: 72 (100%+)
I agree with Adrian.
"17.5T/27T Stock/Spec BL
BL/BR Open Modified
Those racers with 13.5T motors can continue to race them happily at the club level for as long as there is interest in continuing to run them. The rules for 13.5 will not be written but will be controlled by local race directors with guidance based on the ROAR rules just like everyone is doing right now.?
RBLove is offline   Reply With Quote
Old 01-02-2008, 07:28 PM   #26
SW your right a lot of classes that cover 2 completely different forms of racing. If you put two club races together you would have more classes than the bird dont drag a good race down
Leon McIntosh
PRO-LINE--XRAY--RCAmerica--FX Engines--NitroPro Fuel--Kustom R/C Graphics--Schelle Racing
******* DialedSetups.com ****** Check it out!!!!!
punkracer24 is offline   Reply With Quote
Old 01-02-2008, 07:29 PM   #27
This seems to hold true in Sedan but is a 10.5 still equivalent to 19T in 1/12th?
Old 01-02-2008, 07:34 PM   #28
SWTour's Avatar
Dang LAG and Double Post
Joe Myers
Old 01-02-2008, 07:34 PM   #29
SWTour's Avatar
...I understand the concern about the 13.5.
While 13.5's were getting popular for On-Road early in '07, several of our OVAL Racers wanted something SLOWER than the 10.5 and closer to STOCK
(Which is why I got involved in SLOWER MOTOR TESTING)
I told them (AND Showed them) that a 13.5 would run SO close to what a 10.5 would...that the TOP 13.5 guys would qualify in the top 3-4 positions in the 10.5 class almost EVERY time.
One of the really cool things though about BRUSHLESS MOTORS, unlike a Brushed Motor - they have a better RESALE value.
To do all the testing I was involved with this year - I bought 12 brushless motors. MOST of them I bought HERE on RCTech USED. Average Price 45-65 dollars. I used them, tested with them...learned as much as I could about them..and even dyno'd them....and just recently I sold 5 of them (For the same 45-65 each) 2 of these were 13.5 motors, one was a 5.5, one was a LRP motor and one was an OLD Style 4300.
So even IF a racer has a 13.5 motor and has NO use for it...it can be ReSOLD, or if it's a NOVAK motor..it can be traded in toward the purchase of a NEW motor of your desire. (Unless it's burnt up - SELLING it will usually get you MORE $$)
Joe Myers
Old 01-02-2008, 07:35 PM   #30
RBLove's Avatar
We run this combo together every weekend and they are very close. The BL is more efficient so it ends up being a touch faster toward the end of a race. BL is just easy horsepower. You do not have to run the best motor and battery in the building to be in the hunt.
Speaking in terms of road course racing. Oval is completely different.
A 15.5 would have been a great motor for the stock equivalent. 17.5 is a touch slower and 13.5 is faster.
19t and 10.5 are as close as it gets.
Roar Brushless motor debate thread. *Chrominator* Electric Off-Road 173 01-18-2008 10:52 AM
New ROAR rules Rfury Georgia Racing 9 01-16-2008 12:58 PM
Roar Rules rollagen Nitro On-Road 1 08-06-2007 06:04 PM
? on ROAR rules gator Electric On-Road 2 11-23-2002 12:13 AM
ROAR rules LooseCannon Nitro On-Road 18 09-08-2002 11:03 PM
