Old 01-02-2008, 05:32 AM   #16
LOSI123's Avatar
Trader Rating: 63 (100%+)
I used to race in geelong. and melbourne Sometimes.....
Normally run sorex 28 with Sorex B medium Inserts.
Or take off 27 with take off medium Inserts.
but if you say the track temp is that hot (rare for melb, well most of the year anyway) then on realy hot days i would run sorex 36 with sorex med b inserts.
Now this has all been proven so if you run these tyres and they dont work then your setup has to be wrong on the car. 100% garenteed !!!!!!!!!!!!!!!!!!!!
LOSI123 is offline   Reply With Quote
Old 01-02-2008, 05:38 AM   #17
Drifting101's Avatar
will test tomorrow as i will go to local hobby shop pick up a set or two and when i race at a private so freinds meet i will test and report.
Any tire cleaners or compounds to go with that when i use my tire warmers?
With tire warmers do i set the warmers to slightley less, the same or slightley hotter than the track?
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 01-02-2008, 05:39 AM   #18
LOSI123's Avatar
If its hot and you run a 28 or 27 tyre then you will chew it out in like a few heats.
also if your camber is wrong even buy a tiny bit, then you will also chew em out prety fast.
Old 01-02-2008, 05:41 AM   #19
i have that all set up so that it goes through tires at a normal rate of around 2 hours plus on the track, so four race meets but that doesnt include practice
Schumacher
Old 01-02-2008, 08:01 PM   #20
We ended early as my day ended early,
i tried the tires today and they worked well so i will stayed with them, i used it from around 1 and a half hours
Even though they had minimal rubber left i used them and then one came loose from the rim so i reglued it and was bumbed i messed the glue but not on the tire or the rim from what i saw and it actualy covered th air hole and when i wanted to heat them up in my tire warmers and they had just come from the a cool area so when they heated up the air expanded and exploded hot rubber and ruined my tire warmer cup and whole front right end of my car.
Schumacher
Old 01-02-2008, 08:56 PM   #21
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
GumBall tyre is suck especially d Insert...made by soft foam/sponge...
i finish 4 set tyre for 8 races.....very fast spoil d rubber which cause bt d soft insert. d tyre traction is very terrible....
kschu is offline   Reply With Quote
Old 01-02-2008, 09:02 PM   #22
thanks kschu
that what i wanted to know if they are good or bad
Much apreciated
Schumacher
Old 01-03-2008, 04:46 AM   #23
LOSI123's Avatar
Originally Posted by LOSI123 View Post
Gumballs are crapola
ok so what state or town are you in dude!!!!!!!!!!!!!!!!!!!!!!
So we can give you advise that you have asked for............................................... ...................................
its like your dodging the ??????
(it matters heaps to what tyre to run if you are in Brisbane or Perth or Hobart etc..... due to temps)
the first line of this tells you they are crapola (crap)
Old 01-03-2008, 04:48 AM   #24
sorry missed that
Schumacher
Old 01-03-2008, 10:15 PM   #25
kschu's Avatar
get paragon fx2 if u looking for tyre treatment. u wont regret using it....
or u can try Red Dot or Death Grip. both do great job too....
Old 01-04-2008, 03:12 AM   #26
I will quit RC if gumball is the only tires left in this world... May be it was a failure products actually meant for camel chewing gum in the desert....
MARKANO is offline   Reply With Quote
Old 01-23-2008, 06:51 PM   #27
kschu's Avatar
Give the best while u can !
HB Gumballs-Results TylerOwenby Electric On-Road 1 09-05-2007 08:59 PM
WTT 2.2 associated HPI slicks lot for? slufoot78 R/C Items: For Sale/Trade 4 06-25-2007 08:49 PM
Yok ZR139 Racing Slicks Charles Electric On-Road 5 04-21-2005 08:43 PM
Used Racing Slicks Up For Sale RCDRIVER R/C Items: For Sale/Trade 0 10-24-2004 03:22 PM
Used Racing Slicks Up For Sale And 2 Show Bodies RCDRIVER R/C Items: For Sale/Trade 0 10-17-2004 03:23 AM
