Old 06-14-2003, 04:37 PM   #1
Send a message via AIM to g_bruin Send a message via Yahoo to g_bruin
Default Oiling bearings
I plan on cleaning my bearings using motor spray. However, what kind of oil do you guys use to oil them? I would imagine it's a light oil but if you can tell me the kind and brand and where to get it from, that would help a lot.
g_bruin is offline   Reply With Quote
Old 06-14-2003, 04:46 PM   #2
racer's Avatar
most racers would use Royal Oil from Team Trinity. your local hobby store should carry this.
# RC4051
racer is offline   Reply With Quote
Old 06-14-2003, 06:17 PM   #3
utieh's Avatar
i heard it was not good to use WD40 to clean bearings before oiling, is it right???
utieh is offline   Reply With Quote
Old 06-14-2003, 06:29 PM   #4
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
I use an ultrasonic tank with 100% isopro. alchohol. Then i use hurricane sonic drops.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 06-14-2003, 09:45 PM   #5
fatdoggy's Avatar
R/C Tech Charter Subscriber
I just take the seals off, blast them completely with motor spray then put a drop or two of trinity royal oil and spin then for a few minutes so the oil get distributed evenly and they feel smooth. If they still feel rough I repeat the process untill there smooth.
fatdoggy is offline   Reply With Quote
Old 06-15-2003, 04:38 AM   #6
Carbon_Fibre3's Avatar
dont use wd40, i have found that when it dries, it leaves an oily substance that is quite thick.. i now just use petrol, and oil them witha light motor oil
Carbon_Fibre3 is offline   Reply With Quote
Old 06-15-2003, 07:57 AM   #7
davioh's Avatar
petrol as in from nitro cars?
davioh is offline   Reply With Quote
Old 06-15-2003, 09:11 AM   #8
utieh's Avatar
thanks Carbon-Fibre3, it s just what I wanted to hear.
at this moment i am just using alchol to clean them but it isn t efficient as a spray cos it can t remove some grease inside the bearing.
Old 06-15-2003, 09:33 AM   #9
davioh's Avatar
do you really havto take off the bearing cover? cuz i think it would be pretty hard with the metal shielded ones...and the way i do it, the bering oil seeps through the cracks.
Old 06-15-2003, 10:55 AM   #10
Nil
I tried without taking off the shields for a while and finally did. I found old grease that hadn't come out in my lacquer thinner bath and motor spray cleaning procedure. The bearings were much more free afterward. So, I'd say that , yes, you have to take them apart occasionally.
Nil is offline   Reply With Quote
Old 06-15-2003, 10:59 AM   #11
racer's Avatar
i'm sure most have seen this page before, just figured for most of you that have not can get some idea
Cleaning bearings
Old 06-15-2003, 06:17 PM   #12
davioh's Avatar
also check out http://www.balakracing.com/ under maintenece or sumthing
Old 06-15-2003, 10:17 PM   #13
Simon K's Avatar
To clean my bearings, I use a Robinson bearing blaster with a high pressure aerosol brake cleaner. After the bearings dry, then it's a couple of drops of Royal oil.
Simon K is offline   Reply With Quote
Old 06-16-2003, 02:31 AM   #14
fasterdanu's Avatar
to do my bearings i first remove the shields on both sides drop them into my egale bearing vibrator thingo with motor spray in it. then whip the bearings out oil them up heaps(5-6) drps then spin them a bit drop them back in and wait about ten min. pull them out let the motor spray evaporate the clean each sheild put 1 side on put 3 evenly spaced drops of orion free revs(it's what i use) spin it a little and put it all back to gether this way does take a little longer but i takes a hole lot more time between nesicary cleans and i've done six meets on a fairly dirty track and the car will still roll off a table tilted at like 5-8deg
only my experience
fasterdanu is offline   Reply With Quote
Old 06-16-2003, 05:32 AM   #15
Matt04's Avatar
would hpi motor spray and tri flow work?? i have herd that it does?
Matt04 is offline   Reply With Quote
Question about oiling air filters Darth Smoke Nitro Off-Road 6 06-10-2008 02:54 AM
oiling shocks BSS07 Electric Off-Road 5 04-29-2008 08:50 AM
Cleaning & oiling bearings GSM Storm Electric Off-Road 12 05-26-2007 09:17 PM
Oiling all the joints?? vti-chris Electric Off-Road 3 02-11-2005 05:04 AM
Not oiling your balls...... Mabuchi540 Electric On-Road 10 08-15-2004 03:22 PM
