Old 04-28-2008, 02:06 PM   #31
HB
i will try the setting #2
there is no bearing banding on my axial
the car sound verry good when i'm driving verry silents
the motor timming is standerd on B do i have to set the timming between B and C???
HB is offline   Reply With Quote
Old 04-29-2008, 12:09 AM   #32
burito's Avatar
For sure you run too high timing on the motor, which can cause excessive heating to both the motor and the speed control. No extra power is generated, just "evaporetes" into heat...
Most guys with Orion (or other Feigao based motors, such as SP,Trinity,GM,etc) have the timing set to somewere from middle of "C" tab to in between "C" and "B". Having it in the centre of "B", as you have it now, is definitely far too much with our speedos.
Decrease the timing and try again, I'm very confident this will solve your problem.
Reto Koenig
burito is offline   Reply With Quote
Old 04-29-2008, 02:45 AM   #33
HB
thanx i will try it saterday
Old 04-29-2008, 03:22 AM   #34
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
sphere cannot use SP motor with timing 2...it's make d esc hotter n also ur battery also hotter....sphere 2007 is reconmended to be use with 5 cell with 3.5r n 4.0r....using 6 cell will cause thermal cut or worse to worse esc blow up...
Give the best while u can !
kschu is offline   Reply With Quote
Old 04-29-2008, 03:51 AM   #35
HB
i'm driving 4cells with 4.5 1/12
lrp sphere 2007 bj4racer25 R/C Items: For Sale/Trade 8 08-14-2008 09:04 PM
LRP Sphere, Sphere 2007 or TC NT Australia Wanted to Buy 1 06-08-2008 04:39 AM
lrp sphere 2007 john stu Electric Off-Road 9 01-04-2008 08:27 AM
Sphere 2007 Ryan McBee Electric Off-Road 5 01-03-2008 01:47 PM
lrp sphere 2007 stinky cheese Australia For Sale/Trade 1 12-04-2007 08:55 PM
