Old 01-02-2008, 11:15 AM   #16
Leodis's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Wild Cherry View Post
Check motor & try this ...
I`v seen a few motor bearing`s spin oil on the sensor inside..
Try cleaning sensor with q-tip with rotor removed from can...
+1
If it's not the new speedo, that would be my guess too...Sometimes the factory puts way too much oil on the bearings and once they even put a plastic shim in there. The only time my 7.5 behaved in the manner posted above, I just cleaned out the motor, popped some new bearings in there, and the motor came back to life.
Leodis is offline   Reply With Quote
Old 01-02-2008, 11:29 AM   #17
razzor's Avatar
i had the same problem the motor would only run when i gave the car a push and as soon as the car came to a standstill if have to do the same.
Thought it was esc but turned out there was a hassle with the motor.
Swapped another motor in and all is good.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 01-02-2008, 07:30 PM   #18
Still Bill's Avatar
Default Updated User Guides
My User Guides that originally came with my Sphere 2007 and TC ESCs are outdated. Go to the following LRP link to get updated User Guides and Specs for your ESCs. You may well find more detailed info than what you now have.
http://www.lrp-electronic.de/
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 01-02-2008, 07:41 PM   #19
Maybell's Avatar
Originally Posted by wallyedmonds View Post
they dont
i mean i like my sphere's better
there goes Wally again...balls always on the mind...
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 01-21-2008, 08:38 AM   #20
woozer71's Avatar
Trader Rating: 23 (96%+)
I have the LRP Sphere TC esc and the fan and the heatsink have fallen off. What is the best way to reattach the heatsink back on?
Fraser Coast RC Car Club/FCRCCC
VBC D06 / Xray T4 2013
Yokomo BMax2 ver 2 - Tamiya F104 x1
Sanwa MT-4
woozer71 is offline   Reply With Quote
Old 01-22-2008, 07:55 AM   #21
woozer71's Avatar
Sanwa MT-4
Old 01-22-2008, 09:33 AM   #22
turboxrayt1fk05's Avatar
Trader Rating: 27 (100%+)
samething happen to me , speedo would lock up and heat up the motor
SERPENT S811 AND S811T, FUTABA 4PKS , viper rc solutions
OS SPEED WORLDS EDITION 21 , OS 2060 PIPE
BYRON %30 FUEL , PROTEK 2300 LIPO RX PACK
SAVOX SERVOS 1268MG HV , 1267MG HV
turboxrayt1fk05 is offline   Reply With Quote
Old 01-22-2008, 09:27 PM   #23
Still Bill's Avatar
Contact Team Associated and see if they sell the special heat-transferring tape to reattached the heatsink. This tape also comes in the LRP upgrade kit that includes the add-on heatsink and fan (for the Sphere 2007 version).
Old 01-22-2008, 09:30 PM   #24
big al's Avatar
Do you guys find that you need to have the fan when using a 13.5 motor? I believe seattle indoor raceway runs 6min?--Al
big al is offline   Reply With Quote
Old 01-22-2008, 10:04 PM   #25
Still Bill's Avatar
I use both the LRP Sphere 2007 (no heat sink or fan) and the TC version. Can't tell any difference using a 13.5. ESC temps are in the 80s with both.
Whenever I finally kill the fan on my TC ESC, I probably won't replace it.
Old 01-22-2008, 10:22 PM   #26
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Cool check again
Yeah dude! Check the sensor wire to ensure it's fully pluged in.
My Sphere TC ROCKS!
Make sure blue=a; yellow=b; orange=c
John St.Amant is offline   Reply With Quote
Old 04-28-2008, 12:36 PM   #27
HB
Hi
can some one help me out
i got a new LRP sphere 2007 no heating and no fan on top
and a new orion 4.5 for 1/12
when i finish my race
my esc get verry hot like 107C
and my motor 65c cells 75 c
my rollout is 29mm
i'm driving in a small trace
i don't what to do or what i do wrong
HB is offline   Reply With Quote
Old 04-28-2008, 12:49 PM   #28
bs6ef's Avatar
Originally Posted by HB View Post
Hi
my rollout is 29mm
hi HB
what setting do you have on the ESC? And Have you setup the esc to your handset?
steve
You have to watch the TechnoViking http://www.youtube.com/watch?v=_1nzEFMjkI4
bs6ef is offline   Reply With Quote
Old 04-28-2008, 01:16 PM   #29
HB
my settings are
#1 @2
#2 @4
#3 @0
#4 @0
yes i have set the esc to my handset
Thank u
Old 04-28-2008, 01:57 PM   #30
bs6ef's Avatar
my settings are
#1 @2
#2 @4
#3 @0
#4 @0
Thank u
HB
try setting #2 @3 instead of 4 and make sure that Throttle Exponential is set to 0, also check that your rear axial is running free and that the bearing aren't binding. This should help cool your esc and motor down abit, i run a 5.5t motor on a small track and my esc only gets to around 50degrees C. If your motors and esc is still getting really hot try driving the car abit less aggressively, this will also help.
steve
lrp sphere 2007 bj4racer25 R/C Items: For Sale/Trade 8 08-14-2008 09:04 PM
LRP Sphere, Sphere 2007 or TC NT Australia Wanted to Buy 1 06-08-2008 04:39 AM
lrp sphere 2007 john stu Electric Off-Road 9 01-04-2008 08:27 AM
Sphere 2007 Ryan McBee Electric Off-Road 5 01-03-2008 01:47 PM
lrp sphere 2007 stinky cheese Australia For Sale/Trade 1 12-04-2007 08:55 PM
