LRP Pulsar 3 VS MUch More CTX Charger. >
Old 12-27-2007, 08:45 PM
kschu's Avatar
Trader Rating: 16 (100%+)
Default LRP Pulsar 3 VS MUch More CTX Charger.
hi guys, wat d pros and cos about d above Charger...
any opinion ??
thanks
kschu is offline
Old 12-28-2007, 06:10 AM
Location: Murdoch Institute for Racing Mental Rehabilitation
any opinion ??
thanks
Definitely Pulsar 3.
More punch.
Murdoch is offline
Old 12-28-2007, 07:20 AM
AdrianM's Avatar
The new LRP charges any lipo battery. The CTX is only good for Lipo rx packs and transmitter packs since it only charges Lipo at 1amp.
AdrianM is offline
Old 12-28-2007, 08:27 AM
Have been using MM since it came out, its definitely grate charger, of course 1amp lipo and noisy fan are negative sides, but otherwise, it will do all what you want.
Set long lockout on 20 minutes and for ever forget about false peak.
MM is a good choice if you wont need to charge LiPo race packs
JanisK is offline
Old 12-28-2007, 09:41 AM
atomapapa's Avatar
Trader Rating: 92 (99%+)
It does LIPO up to 10A
atomapapa is offline
Old 12-29-2007, 02:05 AM
kschu's Avatar
would pulsar gv more stable peak than MM CTX ??
kschu is offline
Old 12-29-2007, 04:04 AM
But pulsar give a stable temperature at peak.
I check it in the same pack.
The most important is the result in race.
Simple, no need to attach the temp probe + volt out mode for mtr break in.
But since I charge AAA batt for mini Z.
Pulsar gives more punch significantly.
This is my own opinion.
Both chargers are great.
Murdoch is offline
Old 12-29-2007, 06:18 AM
Trader Rating: 44 (100%+)
CTX charges lipo up to 10A??
i don't think so ..
wyl03 is offline
Old 12-31-2007, 02:43 PM
mach51's Avatar
Trader Rating: 30 (100%+)
LRP only charges up to 3 cell lipos from what I read.
mach51 is offline
Old 12-31-2007, 02:46 PM
atomapapa's Avatar
i don't think so ..
I was talking about LRP
Old 12-31-2007, 04:48 PM
magm20001's Avatar
Originally Posted by Murdoch View Post
More punch.
lol how does a charger deliver more punch? both charge exactly the same way.
only difference is the way it delta peaks.
The MM has finer incremental delta peak setting so as not to overcharge like the LRP does.
but i guess a.hara, m.reinhard and a.Moore dont require any punch when they race
end of day both are great chargers. MM is better for NIMHs, LRP is better "allround" charger
magm20001 is offline
