Old 12-27-2007, 12:08 PM   #1
Default Atlas blue can vs red can
Could someone please explain to me the difference between the Atlas-based blue and red can motors?
Thanks,
Kane
Kane-o is offline   Reply With Quote
Old 12-27-2007, 12:23 PM   #2
stuey's Avatar
one is blue one is red
stuey is offline   Reply With Quote
Old 12-27-2007, 03:07 PM   #3
Matt Howard's Avatar
The blue can is torque based and the red can is RPM based
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 12-27-2007, 03:44 PM   #4
morris's Avatar
Trader Rating: 40 (100%+)
nice avatar......
AE/VIPER/XPERT/DIRTCHEAPRC.COM/JCONCEPTS
A big thx to all the tracks that I race at:cause if it wasnt for these guys..we wouldnt have a place to race our r/c cars!!!
morris is offline   Reply With Quote
Old 12-27-2007, 04:18 PM   #5
Thanks for the quick response.
-Kane
Old 12-27-2007, 07:38 PM   #6
tandman's Avatar
Send a message via Yahoo to tandman
Kane...from my experience the blue can you would gear about the same or a tooth lower than the checkpoint 19. The red can motor seemed to be right between the Komodo and the checkpoint as far as torque/rpm goes.
Dwayne Flodell
Team Mad Scientist
-When you need mad rip.....call the Mad Scientist
Team Sweepracing-R1 Wurks Team Canada
tandman is offline   Reply With Quote
Old 12-27-2007, 09:50 PM   #7
Grenade10's Avatar
Trader Rating: 37 (100%+)
I've been able to get HUGH torque and RPM out of this motor, but you better have some very good batteries. My best red can one ( I have 4 red and 2 blue) will draw over 11 amps at 3 volts and no, the arm is not bound up in the bearings!
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 12-27-2007, 11:50 PM   #8
tandman's Avatar
The atlas motors both make good power....red can is just more rpm based than the blue can....I just tried to explain it through gearing as I race with Kane at some series races and knew that he would have ran the other motors that I had mentioned. One red can motor I have actually pulls over 12 amps at 2volts on my Muchmore Motormaster, makes big power on the dyno and pulls very hard on the track......I am always playing around and testing different combos....the Komodos when geared and tuned properly can make really good power aswell....they just seem to have a smaller gearing window to run the fastest. The hemi Chameleons have a little wider gearing window to be fast but still have a sweet spot. I find that the Atlas motors are a little harder to gear correctly because they seem to be relatively fast within a couple teeth. Still the motors to beat seem to be Trinity based. For a big flowing track go for the Komodo....for a smaller tighter track go for the Hemi C2's. For the Komodo gear around a 6.8-7.0fdr and the C2 hemi around 6.2-6.5fdr both with 58.5mm tires....always use lap times for the proper gearing as temp does not always tell you correct(max) gearing. Some motors like to run hot and some seem to run cooler.
Dwayne Flodell
Team Mad Scientist
Old 12-28-2007, 05:44 AM   #9
stuey's Avatar
the atlas red do seem to draw more amps and give a very good bottom end without compromising top end rpm as for comparing to a kd on the track they are not much diffrent but you have a little piece of mind as the kd are renouned for blowing up (epic quality).
Old 12-28-2007, 07:21 AM   #10
Ryan14's Avatar
My blue atlas that I bought 2 years ago is by far the fastest 19t I have ever owned/tested. Ran like this since the day I bout it
Its only fast if you know how to drive it.
TeamAHK | Horizon Hobby | Umbrella Hobby | Action Hobbies Kingsville | Edward Jones Investment | CIBC | Hobbywing | Cerberus | SkyRC |
Ryan14 is offline   Reply With Quote
Old 12-28-2007, 12:23 PM   #11
Thanks Dwayne. I am going to give the T-bang torque-based Hemi and the Atlas red can a try at our next club race and see what I like. I have been racing an Atlas blue can thus far this year and have been very happy with it. If only I didn't have to chose between running just 1/12 scale or TC on club nights! I think I will gear the T-bang the same as the blue can and drop two teeth for the red can.
Thanks,
Kane
New Atlas 19 OEM Blue Can Motors $10 ea. Tempest2000 R/C Items: For Sale/Trade 1 07-12-2007 07:34 AM
MOTORS MOTORS MOTORS EPIC C2,INTEGY BLUE ATLAS 19,AN MORE DENNIS STORTI R/C Items: For Sale/Trade 18 01-06-2007 09:44 AM
Atlas 19t (Blue Can) rinkrat99 Electric On-Road 1 04-23-2006 02:21 AM
BLUE dish Helios wheel with blue grip pad TFR R/C Items: For Sale/Trade 12 07-31-2005 09:15 PM
TC3 Graphite Chassis, Blue FT Motor Clamp and Blue Battery Brace Brian McGreevy R/C Items: For Sale/Trade 16 03-11-2004 03:43 PM
