Old 12-23-2007, 11:32 PM   #1
Default TC4 steering problem
i am having problems when i turn my front wheels, its vibrating about every other time and nothing appears to be loose,and the bearings are good
mnapp69 is offline   Reply With Quote
Old 12-24-2007, 12:06 AM   #2
BIG DADDY8's Avatar
Trader Rating: 62 (100%+)
Send a message via AIM to BIG DADDY8
That would be your CVD"S. Try rebuilding them(if there not bent). I did and it stopped. Use the black grease.
BIG DADDY8 is offline   Reply With Quote
Old 12-24-2007, 01:16 AM   #3
Default Tc4
Check the out drives that they are not worn beyond use also check the cross pin in the cvd hasnt come loose it might be rubbing on the inside of your steering block.
If you are using a one-way check the bearings.
Make sure none of the bearings is binding from wheels bolted on too tight.
Check the diff ring gear for broken or chipped teeth also the bevel pinion gear in there also.
yeahyeah is offline   Reply With Quote
Old 12-24-2007, 01:22 PM   #4
yea i did re grease the cvds and they werent bent but it still does it
Old 12-25-2007, 05:20 AM   #5
Default tc4
check the rim and tyres are glued correctly?
centre shaft bent
change wheels
chassis screws loose
body touching the wheels
how to fix the problem in steering? Potter Micro and Mini Scales 2 10-18-2007 06:19 PM
Steering Problem jmdv Nitro Off-Road 8 06-28-2007 08:23 AM
Steering problem... joe of loath Micro and Mini Scales 5 03-21-2007 01:24 PM
MI2 Steering problem brakkie Electric On-Road 6 02-13-2006 07:01 PM
