-   -   Bit for integy super lathe 3 (https://www.rctech.net/forum/electric-road/196654-bit-integy-super-lathe-3-a.html)
hirosaki 12-20-2007 09:19 PM
Hi, i want to buy carbide bit for integy super lathe 3, which one should i buy AR 4 or AL 4? I search on enco website they have enco and usa, which one is good quality bits?
Trips 12-21-2007 06:05 AM
Looking at the picture on Integy's website, it looks like the super lathe 3 takes an AR4 bit. THe easy way to tell, is when the armature is in the lathe, and the lathe is sitting in front of you as if you were about to do a cut, is the comm to the left side, or the right? If the comm is to the left side (Twister, some old Trinity lathes), then that lathe takes an AR4. If the comm is on the right side (Cobra, Hudy, Orion), then that lathe takes an AL4.
echo 12-21-2007 10:46 PM
I have integy super lathe 3 and use AL4... but now i have a problem when cut my comm. help...
hirosaki 12-21-2007 11:32 PM
So i need AR4?:confused:
Trips 12-22-2007 07:35 PM
By looking at the picture of the super lathe 3, yes, you need an AR4 bit for it.
Powered By: vBulletin v3.9.3.6
