Closed Thread
Old 10-23-2009, 08:32 AM   #1306
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
I found out what my problem was....too much weight over the front. A friend set it at 53% rear, 47% front and now it grips up really well and responds to setup changes as it should. I am going to experiment with different weight bias front to rear to see how this affects the car.
All this time, something so simple, I feel like an idiot :P
Thanks for your help, I can finally enjoy my racing again
dontfeelcold is offline
Old 10-23-2009, 09:14 AM   #1307
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
paul,
do you feel that winning races has made you into the champion that you are today?
- david dorsey
*** The Gate II - Home of Mike Wise ***
seaball is offline
Old 11-02-2009, 06:33 PM   #1308
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
Originally Posted by Syber Serulean View Post
Paul...
Have you ran the Nemesis 17.5 motors by any chance? How do they compare to the Duo2 motors? I was getting ready to put in an order for 3 Duo 17.5's but this press release for the Nemesis motors just came out and got me excited. Would you say my money is better spent on the Nemesis 17.5's?
bumping for my question in case it was missed
Syber Serulean is offline
Old 11-03-2009, 02:14 PM   #1309
Default T3
Hi Paul.
Have you run your T3.
I have it in my hands and it looked good, on first look it are those little rafinements that make the top.
I like to here your story about the T3
Thanks and good luck
ED
eded1 is offline
Old 11-04-2009, 12:38 AM   #1310
ds400's Avatar
Default XII Xray
Hey Paul ,
canyou comment the new XII link you were racing? What the major improvement compared to the XII T bar?
ds400 is offline
Old 11-04-2009, 12:36 PM   #1311
MarkBrown's Avatar
Originally Posted by dontfeelcold View Post
I found out what my problem was....too much weight over the front. A friend set it at 53% rear, 47% front and now it grips up really well and responds to setup changes as it should. ...
It used to be that everybody ran more-or-less the same battery, so their cars balanced out about the same, and the ballast indications on the setup sheet were meaningful. Now with LiPo and some races running cars at 1425 grams there is a lot more variability. It would be nice for the setup sheet to indicate the grams of weight on the front tires and on the rear tires, or something like that.
Paul, can you tell us the grams of weight on the front tires and on the rear tires for the setup you ran at IIC? Is 53% rear weight typical, or is it on the high side? As the grip comes up would you tend to put more weight to the rear?
MarkBrown is online now
Old 11-04-2009, 07:21 PM   #1312
cyanyde's Avatar
Don't forget that when you turn, the wheel base on the loaded side gets a little longer. This brings the center line of the car slightly forward.
cyanyde is offline
Old 11-08-2009, 10:47 AM   #1313
Trader Rating: 35 (97%+)
Send a message via AIM to King of B Main
Default High Bite
Hi Paul,
I've been running your high bite onroad national set-up and have been having some issues when the bite gets really high. The rear wheel wants to come up when I want to carry corner speed....
So just wondering what you would of changed on your set-up ?
Thanks Paul
King of B Main is offline
Old 11-09-2009, 02:24 PM   #1314
Default Setup Question
Hi, Paul.
My son and I used your IIC rubber tire carpet setup (5.5 motor) at a fairly large high bite carpet track (100' x 80') this past weekend. It worked extremely well and the car was dialed the whole weekend using Jaco blues.
For club racing, we race at a smaller carpet track with less traction. The car doesn't seem to perform as well using this setup...it doesn't have enough mechanical grip in the front or rear.
I'm wondering what changes you would make to your IIC setup to accommodate a smaller track with less traction. We would be using a 7.5 motor with Jaco blues.
Thanks,
Bob
bobthim is offline
Old 11-10-2009, 12:05 AM   #1315
hows everyone doing? Maybe we can just change this into a "ask each other" thread maybe? Might be a bit more effective
Paulllllll. If you're busy testing the Nemesis motors please tell ussssss
Old 11-10-2009, 06:34 AM   #1316
Send a message via AIM to ERTRACHTER
guy's I think paul's been at at race in Houston Texas runnin gas
ASSOCIATED 12r5.1,REEDY MOTOR AND BATTERY, LRP SPEEDO,KIMBROUGH PRODUCTS,BIG DOG RACING,BELMONT R/C SPEEDSHOP, DENNIS LYMAN RACING, TEAM TOSO, TEAM FACTORY BITTER, SCHUUR SOLUTIONS, SIMMONS RACING, TEAM BOOZCRUZ
ERTRACHTER is offline
Old 11-10-2009, 06:37 AM   #1317
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to ToysRUsKid
Is true, he's been there most of last week. Very busy season for him and the rest of Team XRay. I'm sure he'll respond when he returns.
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline
Old 11-11-2009, 09:31 AM   #1318
Gravity RC
Hi everyone, Im sorry, i have not been on here really atall for a few weeks, it started three weeks ago when i recieved the T3 and some 12th scale stuff to test, this took a very long time to build and test perfect. then i had a nitro race in houston that i returned from yesterday. This should be the longest post in Rc tech history, lol. Thanks
Originally Posted by TimV View Post
Paul, what shock rebound % do you run on your foam tire car? Looking for a good starting point for this year. Didn't fool with it last year.
I use very little rebound with my foam car, maybe 20% at the most but many times i used almost 0%. i liked it less because i thought it made the car easier to drive.
Originally Posted by zake540 View Post
What's this Paul Lemieux Rc Driving school?!?! So where do I sign up!
Their is none but anyone who comes to trackside can work with me as much as they want. if im in town ill try and meet anyone down their, i just live a mile away.
Originally Posted by mtbboy View Post
Here you go Paulie....
$400.00 a day..
I bet you would have a huge waiting list for that.seriously.
Chase needs a new pair o shoes.
Dave.
Nice, lol im happy with a soda.
Paul...
Hi, I have run several versions of the nemisis motor. me and jim stopped testing about a month ago and sent it into production, the day that we decided to do that was when we were both very happy with its performance. if the production motors are anything like the last prototype i ran it will be the motor to have for sure. I beleive that they are do in a couple of weeks.
Im glad you figured it out!, thanks.
Originally Posted by seaball View Post
paul,
- david dorsey
LOL, we are all champions if you think about it. We all won the biggest race of our lives. to the Egg. lol
Originally Posted by eded1 View Post
Hi Paul.
ED
Hi ED, i wasnt involved a ton with the developement of the T3, the Hudys pretty much handled it themselves, I think. At first glance the car desent really look a ton different, this is because Xray has a style of manufacturing that is very noticible and everyone is very used to it. The car is quite a bit different.
I am excited about these improovements. I think that the long top deck is really nice, It even allows you to leave the whole motor mount and spur gear seperated, i think this offers the most even flex i have ever seen in a chassis. I like the new Knuckles which allows for a smaller turning radious, especially since we have the ECS shafts now and can get away with that even with a spool. I like the large pullys which are included. other changes are, rear arms, rear shock tower, new longer camber link options, I think aluminum turnbuckles, seperated suspension mounts from bulk head. and im sure their is more that im forgetting right now. the car is fast right now so i cant wait to get a couple of big races on it and see where it is then.
Originally Posted by ds400 View Post
Hey Paul ,
Right now their is not a huge market for a Tbar car in the us and growingly around the world. it seems like the thrend for cingle cell is definately a link design. Xray sent me a link chassis and pod plates to test, I then built a link car with those peces and the rest peces from the XII. the car seemed good, im not the best 12th scale guy atall but i will be racing it at cleveland and im sure when its done it will be a better car than I am.
That would be a nice feature on the sheets but i dont think too many people would fill it in. I used to keep track of my weight percentages but i would always get too cought up in it. if my car needs to drive easier i now moove weight forward, if the car needs steering i moove weight back. that is how i do it. for me it is a tuening aid, and i never have a set weight that i start on because the rest of the set up determines that also. i would say that 52%R is prolly average for TC's.
Originally Posted by King of B Main View Post
Hi Paul,
Thanks Paul
Hi, i know i already talked to you but i will post it anyways. In this case i want to stop the front end from rolling so much without using a stiffer spring, bigger front bar, wider front pins, thicker front oil, higher front pins,. Rear, narrower rear end, thinner rear bar, longer rear cabmer link, lower rear pins.
those are the things that i would look at.
Originally Posted by bobthim View Post
Hi, Paul.
Thanks,
Bob
Hi Bob, i dont usually change anything except toe and camber for lower bite, with jaco blues on low bite i will use less front camber to make the car more easy to drive. when i got home from vegas and raced at trackside (low bite) i put in 1/2deg of rear toe and reduced my front camber to -.75deg with 3deg of rear camber. that is all i have ever done and it works great for me. Thanks
Again, sorry.
Thanks Guys.
paul
Paul L is offline
Old 11-11-2009, 09:47 AM   #1319
Wow !!! Thank you Paul for answering all are questions......As you can see you've been missed.
Hope to see you in a couple weeks at KoPropo race.
Lunch is on me. Thanks
Old 11-11-2009, 09:56 AM   #1320
ToysRUsKid's Avatar
I might steal that line
Closed Thread
Custom painted Paul LeMieux DNA 1 Sean R R/C Items: For Sale/Trade 4 02-12-2008 07:24 PM
pit table cyclone Electric On-Road 1 10-29-2006 07:01 PM
Paul Lemieux exint2 Electric On-Road 9 10-17-2006 07:19 PM
Mike Blackstock and Paul Lemieux sign with Xray ctmazzo Electric On-Road 79 01-02-2006 03:01 PM
Pit Table help Joneser Electric On-Road 11 09-01-2003 09:44 AM
